Old 07-25-2013, 03:57 PM   #883
ML
ML's Avatar
Drives: 13 White MT FR-S
try a fuel out
Old 07-25-2013, 03:59 PM   #884
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Originally Posted by husker741 View Post
What fuel are you using?
91oct fuel is best I can get at the pump. Didn't think a single octane point would give me a bad read. I'll give a fuel out map a shot. Should I notice the CEL disappear immediately? Or will it take some miles?
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 07-25-2013, 04:00 PM   #885
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
This might be a novice idea, but maybe reset your ECU, then apply the different map.
husker741 is offline   Reply With Quote
Old 07-25-2013, 04:07 PM   #886
enwave
enwave's Avatar
I've been meaning to reset the ECU anyway since I drove relatively casually for the first 1500 miles. First I'm gonna flip the map down to the 89oct neutral drop-ins when I drive it home today to see what happens. If nothing, I'll probably reflash the Unichip with the 92oct fuel-out neutral timing all drop-ins map, reset the ECU, and see how everything goes from there. If anyone else has different advice, let me know!
The Following User Says Thank You to enwave For This Useful Post:
Mike86 (07-27-2013)
Old 07-25-2013, 04:09 PM   #887
husker741
Let us know how this goes!
Old 07-25-2013, 08:30 PM   #888
xcelir8brz
Drives: 2013 BRZ Limited
My Unichip and BRZ is continuing to keep a smile on my face even when I have a bad day at work. No issues. But I do have a lot of experience with it too.
Sent from my SCH-I545 using Tapatalk 4 Beta
xcelir8brz is offline   Reply With Quote
Old 07-25-2013, 10:01 PM   #889
enwave
enwave's Avatar
I haven't noticed any negatives while driving... I love the thing -- definitely registers some major points on the butt dyno. I just want that pesky engine light to turn off
Old 07-26-2013, 04:46 AM   #890
Nickse30
Unnecessary Boost
Nickse30's Avatar
Drives: E30 M3, Evo 8mr, GT 86 Aero kit
Got a CEL after ~500miles with a Unichip. About to re flash the Unichip after work today and if that doesn't fix it I'll take it into an Autozone or something to get the OBD code. Makes me a little nervous... Hopefully it's just running a little lean or something.
EDIT: have codes, running rich and TDC -- P0172 P117B... Any advice from anyone here?
With the flux unit u can clear all codes!
Nickse30 is offline   Reply With Quote
Old 07-26-2013, 02:26 PM   #891
mtimney
mtimney's Avatar
Question for Jack-- Is the AFR reading coming through the OBDII port accurate with a Unichip installed? I just installed a P3 gauge setup that reads through the port and was wondering if any of the readings (boost, afr, etc.) would be off because of the piggyback.
mtimney is offline   Reply With Quote
Old 07-26-2013, 02:31 PM   #892
enwave
enwave's Avatar
Update: took off the Unichip and drove the car to the dealership this morning just to make sure the issue is actually with the Unichip. If the dealership comes back with no issues, I'll start playing with maps again. If they fix something, I'll likely just run the same maps as they were performing beautifully even during the CEL. So far potential culprits are a mis-seated air box after the drop-in, a bad sensor, a bad map, or bad map choice for my high altitude. I'll keep this updated in case anyone else has a similar problem. Also, driving without the Unichip really helped me realize how much the Unichip helps -- it's very noticeable ha.
TLR; Making my decision based on the dealer's assessment with the stock ECU non-piggybacked.
Old 07-26-2013, 05:10 PM   #893
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
mtimney... thanks for the post.
The MAF and ignition advance values will not be accurate. Otherwise, everything should be as the data stream shows.
Cheers
Unichip Jack is offline   Reply With Quote
The Following User Says Thank You to Unichip Jack For This Useful Post:
mtimney (07-26-2013)
Old 07-26-2013, 05:41 PM   #894
enwave
enwave's Avatar
For sake of update -- dealership came back with a warranty repair for faulty DI seals. Completely unrelated to Unichip.
Thanks! Excited to put the 'chip back in after I get her back.
Ammonia (07-26-2013)
Old 07-26-2013, 06:33 PM   #895
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
@Unichip Jack , Please read the rest of the old posts and answer our questions. There are more than just the last posted question we would like answers to.
Mine are
When will the FA20Club CAI files be uploaded?
How can I stop the flux display from asking me to accept that I wont be an ID ten T and stare at the Flux?
Now that the AZ sun has heated up the window mount, how do I tighten up the hinge at the suction cup to arm joint?
Would it be possible to buy the female and male connectors from you (the ones the wire harnesses connect to the Flux Display)? I want to use a coiled (Old School telephone type) multi-wire to go from the dash to the Flux Display as I do not like the way the wires flex while opening and closing the door.
Thanks.....
IceFyre13th is offline   Reply With Quote
Old 07-26-2013, 08:26 PM   #896
mtimney
mtimney's Avatar
I also had an old, unanswered question: Are there any Unichip tuners in New England who I could visit for a couple of custom maps? Thanks!
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 03:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 04:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-04-2013 12:05 AM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 06:31 PM
