#43 |
Drives: 2013 DGM BRZ Limited
#44 | |
Drives: '23 BRZ
MT getting 100.5 in a stock AP1. 94/95 for the FR-S/BRZ and 100/101 for the AP1 are pretty representative of what these cars can do bone stock. 98 for the AP1 is an outlier on the low side, 95.5 for the brz is an outlier on the high side. |
#45 | |||||||||||||||
Drives: '23 BRZ
Of course the power curve matters. But the FA20 and F20C power curves are *similar enough* that peak power does a good job of indicating performance. Ancient equation for peak hp from 1/4-mile trap speed (aka "ricer math" in recent decades...): hp = (trap speed/234)^3 * weight FRS/BRZ: (95/234)^3 * (2750 lb. +200 lb.) = 197 hp AP1 S2k: (100/234)^3 * (2800 lb. +200 lb.) = 234hp Quote:
But still, when I know I need to accelerate in the S2000, I keep the revs up. No biggie. I am practically never in a situation where I go from just cruising to WOT randomly, and in any case downshifting the s2k trans is more of a snick-snick joy than a CHUNK-CHUNK chore.Quote:
![]() the end Last edited by ZDan; 07-24-2013 at 07:52 AM. |
#46 |
This is somewhat amusing... because I actually agree with both of you...
@ZDan: Have you purchased a FRS/BRZ yet? I have a pretty good amount of seat time in them
#47 |
Drives: '12 C63 P31, '23 GRC
Somehow in one issue of Road & Track they cranked out a 0-60 time for the AP1 S2000 of 4.9 seconds.
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#48 |
My VTEC fluid is full
Drives: EFF JAY
#49 |
4g63>rotards
Drives: 98'GSX 11'Tundra 10'Wrangler
I'm pretty sure the point someone was trying to make was that in the case of the op, being constricted to break in revs ~4k and under the fa *should* feel peppier than a f20 (also under break in assuming ~4k)
either way I have enjoyed reading the banter, good to know some other people on here actually understand mechanical theory.
#50 |
Drives: Subaru BRZ Sport Tech Satin White
Anybody noticed that the Honda engine doesn't produce significantly more torque than the Subaru?
Acceleration is a function of torque to weight ratios. Power to weight ratios are just shorthand for torque. Only torque accelerates. This is why supercharged engines punch so far above their weight if power to weight ratios are used. Of course poor low end torque can be compensated for by gear ratios but drivability suffers big time. Anybody look at the 50 and 100 cc TT motorcycle numbers? 14 spd gearboxes and a very narrow torque band. Rpm makes more power for any given torque at that rom but generally speaking moves the torque curve up the rpm range. Since volumetric efficiency for emission certified street engines is getting pretty uniform these days this is no surprise. Bmep is the holy grail. Can you get high bmep at low rpm and at high rpm! Hello variable valve timing. |
#51 | |||||
Drives: '23 BRZ
Torque at higher rpm is BETTER than torque at lower rpm, because at higher rpm it is making more POWER. This is why the heavier S2000 is quicker than the FR-S/BRZ despite making less engine torque. Power is the ability to apply torque *at the rear wheels*, where it matters, at a given speed. Torque at higher rpm puts more torque *at the rear wheels* than torque at lower rpm, because at higher rpm it is getting more torque multiplication through gearing. Power is the rate of doing work. It is force multiplied by velocity, or torque multiplied by rotational speed. This is what *accelerates* things. Torque moves things, but it doesn't tell you how FAST you can move them. With engine torque, you have to multiply by the gear ratios to get rear wheel torque and then thrust at the rear wheels (what pushes the car forward) from that. Engine power, on the other hand, is directly related to thrust at the rear wheels. Power is force * velocity. Engine power is rear wheel thrust multiplied by road speed. You can easily calculate thrust at the rear tires in pounds from engine rwhp and road speed without knowing gear ratios or tire diameters. 1 horsepower = 550 lb * ft/sec Thrust = 550*rwhp / road speed in ft/s. Quote:
#52 |
Agree. If only Subaru could have found a way to implement active valve lift on the FA20. Maybe with the STI version.
2022 BRZ Build 2013 FR-S Build |
#53 |
F = ma. Power is not relevant. F means torque in the case of an engine.
Indeed, power is just torque x time and bhp is a derived figure. The horsepower curve is not measured but calculated. The torque curve is measured and converted into bhp (that's the origin of the b for brake) It is a common misconception that power to weight ratio is a helpful number and comes from a time when horsepower was the only figure the engine manufacturer published. Power is indeed the rate at which Work is done and Work is just not related to acceleration. Power is a constant speed factor and is a good indicator of top speed, but not acceleration. With two vehicles compared and each has the correct gearing power to weight can be considered to be useful for comparing predictions about acceleration intervals but only as a stand in for torque. Look at the torque curves and the weights and you'll literally see the acceleration curve differences. This is especially true when comparing supercharged engines or diesel to gasoline for example. |
#54 | |||||||
Drives: '23 BRZ
The force F that is accelerating the car is *directly* related to engine POWER. F = 550*power/speed in ft/s Quote:
It is torque multiplied by rotational speed. It is also force multiplied by linear speed (thrust * road speed). Quote:
Power is not a "constant speed factor", it determines acceleration potential. Quote:
#55 | ||
Drives: '23 BRZ
If limiting to 6000rpm, of course the S2000 suffers! Quote:
![]() Maybe next year... |
#56 | |
1 liter = 75lb/ft +-5, roughly Power is work over time. Put it this way. If you give us weight, drivetrain configuration, and horsepower, we can accurately predict a 1/4 mile time. However, if you give us weight, drivetrain configuration, and torque, it could be anywhere. |
| FR-S VS S2000 on the track - Initial D Style | trueno86power | FR-S / BRZ vs.... | 44 | 09-19-2013 10:49 PM |
| Ground Control Complete Kit Install and Initial Thoughts | Eric1855 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 33 | 03-21-2013 10:52 AM |
| aFe Takeda intake installed and initial thoughts | omgwtfbbqsauce | AUSTRALIA | 6 | 10-16-2012 08:25 AM |
| initial thoughts from a super credible source | fatoni | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 06-02-2012 04:56 PM |
| 3rd Gen Honda Prelude Pics | WheelFast | Other Vehicles & General Automotive Discussions | 11 | 04-05-2012 01:41 PM |
