Old 07-24-2013, 01:28 AM   #29
GH05T
Undercover Batman
GH05T's Avatar
I think the new RX7 is going after the new Toyota/BMW Supra that'll supposedly be coming out the same time.
"He who shall be last, shall be sideways and smiling." - Jeremy Clarkson
GH05T is offline   Reply With Quote
Old 07-25-2013, 09:40 AM   #30
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
my first car was a rotary, my first track car was a rotary, my first race was a rotary, my first win was a rotary, and, oddly, so was my last. but ANYWAY, the rotary engine is a fantastic engine, though it had several inherent design flaws as mentioned.
What isnt mentioned here, is that with todays tolerances, and what is known about modifying the ports and reinforcing the seals, it would not be inconceivable for a 3 rotor 2l +- engine to break 300 with 25-30mpg. The real kicker and pain in the design, and its fatal flaw, is how to keep the seals lubricated. Yes, injecting oil works, or using 2stroke solution, however it is impracticle in todays market.
If you can figure out a way to keep the seals lubricated without injecting oil, you may revive the rotary.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 07-25-2013, 12:03 PM   #31
njccmd2002
Toyota Freak
njccmd2002's Avatar
Drives: Whiteout FRS
and here you are all yapping about rotaries on a boxer forum, ironic...
njccmd2002 is offline   Reply With Quote
Old 07-25-2013, 10:19 PM   #32
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
We're yapping about rotaries in a RX7 thread. Not really ironic.
I have to ignore the Rotary fanbois... sorry, there's just not enough of you for the economics of it to pan out and the rotary engine absolutely doesn't appeal to anyone outside your itty bitty demographic.
Hence the comment: Want to make sure it fails, put a rotary in it, holds true.
Mazda was smart to drop it and should keep it dropped. They are making massive progress forward with their SkyActiv lineup and for every 1 person you could find me that likes rotary Mazdas, I can find you 50 that that like non-rotary Mazdas and while were at it, I could find you many that can't wait for the diesels. The (under $80k) sports car demographic is very small to begin with, putting an undesirable power plant in one makes the economic equation that much worse. You can talk about the numbers all day long: "the engines revs to this, and sounds so good and makes this much HP"... but it just doesn't do the job it needs to well enough nor does it appeal to enough. Period, end of story.
From an economic stand point, the low budget sports car is already a mathematical struggle for these companies but a low budget sports car with a triangle... Does not compute.
Now if it's a high-budget sports car (80k+) with some really big triangles might be a better equation but then again, if I have 80k to spend on a sports car am I really buying a Mazda, am I really buying a triangle?
SCCA T4 - FRS
Old 07-25-2013, 10:37 PM   #33
edboc
Drives: 1999 10AE MX-5, 2010 CX-9
Would there be a market for a RWD SkyActiv 4-Cylinder Coupe based on the ND Miata that would compete against the FR-S/BRZ?
edboc is offline   Reply With Quote
Old 07-25-2013, 10:43 PM   #34
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by Trashed675 View Post
Considering the 1.3L RX-8 only got 16/22mpg with 250hp, i'm doubting the 1.6L with 300hp will get much closer to the 30mpg mark. Rotaries have always been too thirsty for my particular tastes, maybe i'm just a cheap skate
They actually downrated the hp figures several times over and finally ended up at 232 hp...even then many rx folks we're saying that figure was off
Old 07-26-2013, 01:53 AM   #35
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
An engine that has 3 moving parts and can fit in a backpack is very unique. If gas and oil consumption are priorities maybe a sports car isnt in the cards.
chulooz is offline   Reply With Quote
Old 07-26-2013, 07:36 AM   #36
ZDan
ZDan's Avatar
Drives: '23 BRZ
Which is cool and all, but I wouldn't build a car around it unless the major issues (fuel consumption, reliability/longevity) are mitigated.
To me, the first thing a *real* sports car should be is light weight. A small, lightweight, aerodynamic car should get decent fuel mileage. Not enough real minimalist lightweight sports or sporty cars on the market, too many oversized/overweight monstrosities.
I remember quite a while back that for years the highest observed fuel efficiency in the car spec summary in the back of road and track was a 1st gen Elise that they got 35mpg with.
I sincerely hope Mazda builds a new RX-7, but unless they can do some kind of magic with the rotary to make it fuel efficient, they should make that an optional powerplant. I've always thought they should make a rotary version of the Miata as well. Keep that part of the Mazda identity while allowing "normal" people to enjoy piston-engine versions at the same time.
Old 07-26-2013, 10:41 AM   #37
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Listen, i want a rotary. A I4 with a nice turbo on it isn't special anymore and hasn't been in a long time.
Old 07-26-2013, 11:40 AM   #38
chulooz
Registered you sir
chulooz's Avatar
Do you think you should ask ferrari to build a *real* sports car? Their lightest is +3,200lb. And their flagship is +4,000.
I prefer light sports cars, but I realize many models easily overcome their heft.
Rotary heads get rx8s into the +200k, but if you treat it like a piston engine forget it.
Old 07-26-2013, 12:46 PM   #39
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yes, I think they should build a car closer to the 206/246 Dino, that's less about maximum performance and more about real-world enjoyment of minimalist sports car ideals.
In terms of going fast and making numbers for people to gawk over, yes. But what's missing is the feeling of being in a small fun car.
For every 200k rotary, there are thousands of 500+k piston engines.
If you can't treat it with utter neglect and still get 150k+, it's not going to fly in the market, even if the fuel efficiency issue is "fixed" (not likely).
Old 07-26-2013, 03:56 PM   #40
YukiHachiRoku
Lex Luger
YukiHachiRoku's Avatar
Drives: 2004 GS430
In 2017 all cars will have magnetic levitation. The internal combustion engine is dead!
YukiHachiRoku is offline   Reply With Quote
Old 07-26-2013, 04:26 PM   #41
speedy07
Drives: 2015 Subaru Brz Limited
You know this is in the Other Vehicles & General Automotive Discussions right?
speedy07 is offline   Reply With Quote
Old 08-05-2013, 12:02 PM   #42
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
good to hear that RX7 is coming back!
I would just wait and see what they can do about making RX7.
Official: Nissan Concept 2020 Vision Gran Turismo revealed, hints future R36 GT-R vh_supra26 Other Vehicles & General Automotive Discussions 42 01-17-2016 03:28 AM
Fs: Brand New BRZ OLM Vision LED Fog Lights ucsmfu Canada Classifieds 12 03-12-2015 06:22 PM
I have tunnel vision: 2004+ BMW 330ci ZHP D4ng3r Other Vehicles & General Automotive Discussions 3 08-24-2012 09:54 PM
Mazda MX-5 Yusho concept introduced at AMI Leipzig quik1987 Other Vehicles & General Automotive Discussions 6 06-27-2012 05:36 PM
2010 Mazda Shinari Concept WingsofWar Other Vehicles & General Automotive Discussions 18 09-07-2010 07:42 PM
