Old 07-24-2013, 03:05 PM   #29
FR-S Matt
Originally Posted by Dynotronics1 View Post
that's not quite correct. The STOCK program is only scaled down to 12.17. A simple reset of the scalar will net you correct readings down to 10.5 with no loss of resolution.
OP, you might want to log injector PW on that to really see where you are. I would bet your pig rich based on a few other parameters I'm seeing on that log
Looking forward to you tuning my car locally. :happy0180:
Old 07-24-2013, 03:39 PM   #30
Dynotronics1
Originally Posted by ft_sjo View Post
That's amazing. You can increase the range, whilst not losing resolution. Please let us into your secret on how ADC's work like this.
I'm assuming that's your attempt to be a a wise ass? Look at the table, its plenty easy to understand
Dynotronics1 is offline   Reply With Quote
The Following User Says Thank You to Dynotronics1 For This Useful Post:
Sportsguy83 (07-24-2013)
Old 07-24-2013, 03:46 PM   #31
ft_sjo
Drives: GT86
Yes, it scales 0-5v over a set number of cells. Now who is trying to be the wise ass?
Old 07-24-2013, 05:31 PM   #32
Dynotronics1
no it does not read 0-5v. Again, look at the table, and you will understand
Old 07-24-2013, 05:38 PM   #33
ft_sjo
Drives: GT86
What do you think the raw adc value relates to?
The Following User Says Thank You to ft_sjo For This Useful Post:
mswhong (07-25-2013)
Old 07-24-2013, 05:50 PM   #34
Dynotronics1
LOL
Old 07-24-2013, 11:30 PM   #35
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Resolution a relative thing.....i'm not sure of the point at which making the range wider will affect the resolution but think of it this way.
a 30" TV will look the same with 720p as 1080p. only when you get over 50" can the majority of people tell the difference. So while you technically lose resolution it may not matter.
also unless the denso ecu has changed a lot your car starts at .5x and goes up to 1x after time under load without knock. If you never reach 1 then i'd say your tune is too agressive.
many things will alter stft like fuel changes temp and elevation. so if you were tuned with one fuel or > 20F temp swing then your trims will go nuts.
* My opinion w/ lots of reading and interactions with a local tuner.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 07-24-2013, 11:34 PM   #36
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yep, 100% of the time....
Old 07-24-2013, 11:54 PM   #37
Sportsguy83
Drives: Limited BRZ
Originally Posted by mad_sb View Post
Because your stacking up a long term positive fuel trim. More info here
Are you coming for Southeast 86 meet in Orlando? Thanks for bringing so much knowledge and being so transparent. I would like to personally thank you at the meet.
Old 07-25-2013, 12:05 AM   #38
s2d4
s2d4's Avatar
No it doesn't? Where did you get that info?
Old 07-25-2013, 02:28 AM   #39
ft_sjo
Drives: GT86
From the maf sensor linearization table in front of me....
Old 07-25-2013, 03:25 AM   #40
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
He's too busy trying to sound like an arrogant know it all to actually research something.
Toma is offline   Reply With Quote
Old 07-25-2013, 04:18 AM   #41
s2d4
s2d4's Avatar
Thought it was something along the lines of 0.6 up to 3.7 volts....
Old 07-25-2013, 04:45 AM   #42
coyote
coyote's Avatar
Drives: Slowly
The people having an argument here and talking about two completely different sensors and tables.
coyote is offline   Reply With Quote
The Following User Says Thank You to coyote For This Useful Post:
s2d4 (07-25-2013)
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 01:57 AM
Just want to make sure Moonbase Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-16-2013 05:02 PM
Need to make time this weekend.. Khánh Scion FR-S / Toyota 86 GT86 General Forum 0 02-06-2013 08:43 PM
Dynotronics and their E-Tune/ OTA tune. Ricepuddin User/Vendor/Sponsor Reviews, Feedback, Comments 5 12-24-2012 10:53 AM
Time to make some noise and some demands: VR + AP CF FR-S/BRZ aero trim poormans_LFA Cosmetic Modification (Interior/Exterior/Lighting) 14 09-05-2012 05:44 PM
