Old 07-23-2013, 09:14 PM   #1
Threads
Drives: FRS
Greddy Turbo Questions
I ordered a Greddy turbo kit and oil cooler kit and I was wondering if anyone else in the ft86club community had any experience with this kit specifically.
- Any hiccups or anything unexpected?
- Any tips and tricks for this kit in particular?
Also, slightly unrelated...
Does anyone have any recommendations for tuners in the midwest (Kansas / Oklahoma area)?
Sorry if this has been answered elsewhere, I haven't found anything specific to my needs as of yet.
Thanks!
Threads is offline   Reply With Quote
Old 07-23-2013, 09:25 PM   #2
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
Are you planning on installing the kit yourself or letting a shop install it for you?
Cessblood is offline   Reply With Quote
Old 07-23-2013, 09:38 PM   #3
Threads
Drives: FRS
I'm going to take it to a shop for the install. Hopefully they don't mind me watching and learning while they work
Old 07-23-2013, 09:43 PM   #4
Harmsy
Drives: 2014 Ultramarine Fr-s
From the research I've done as i'm in the market for a kit myself, it's to early in the game to know of any 'hiccups' and even if the owners of the GReddy kit chime in I'd say its still to early for them to even say if the kit/setup they're running is reliable. I'd get the kit installed by a professional unless your certain you are capable and get a conservative tune and run low psi, I'd say around 5 and wait until people with the GReddy kits surface and see how they're holding up running higher boost etc.
Harmsy is offline   Reply With Quote
Old 07-23-2013, 10:07 PM   #5
Threads
Drives: FRS
Thanks I really appreciate the advice. I plan on having a professional install it. I also like your recommendation about running a conservative boost.
Old 07-24-2013, 02:20 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I think you are only the second member to say they are buying the GReddy kit. It would be great if you could post any information you can on the install and results from it.
Old 07-24-2013, 09:49 PM   #7
NOTORIOUS.BRZ
Drives: SUBARU BRZ ZN6 AU 2013
http://www.ft86club.com/forums/showthread.php?t=42028
My greddy turbo kit install
NOTORIOUS.BRZ is offline   Reply With Quote
Old 07-24-2013, 11:30 PM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by NOTORIOUS.BRZ View Post
Awesome username, well played.
Old 07-25-2013, 04:49 PM   #9
Threads
Drives: FRS
Good idea. I have a buddy who likes making videos who will ride with me to the shop. We'll have something put together once everything is completed.
Old 07-26-2013, 04:16 PM   #10
JM Auto Racing
JM Auto Racing's Avatar
Drives: 2010 Dodge Ram
Send a message via AIM to JM Auto Racing
Cessblood should have his installed soon :-)
Right?
JM Auto Racing is offline   Reply With Quote
The Following User Says Thank You to JM Auto Racing For This Useful Post:
Cessblood (07-26-2013)
Old 07-26-2013, 04:36 PM   #11
Cessblood
Right?
Thanks for the good deal on the kit and the oil cooler.
My Greddy kit is intalled already. I just have to upload the tune from FA20club. I should have my car running next week when I return home.
The Following User Says Thank You to Cessblood For This Useful Post:
JM Auto Racing (07-27-2013)
Old 07-26-2013, 06:50 PM   #12
Robojesus
I just completed the install of this turbo kit on my BRZ last week. I did it in my garage at home with a motor savvy buddy. There were only 2 real "hiccups" or unexpected steps that blindly went with this kit. Otherwise I'd say just about anyone could bolt this on at home, the kit is very solid and the pieces fit perfectly:
  1. You have to remove your oil pan, drill a hole in it, and solder an oil return line into it at the correct angle. Getting the pan off w/out damaging it is the only real challenge here, as Subaru decided they'd seal the hell out of the pan instead of use a gasket (understandable I guess).
  2. The intercooler and the crash bar aren't friends. You either have to cut your crash bar to the point of it not even being functional, or just leave it off. I went with the latter.
I guess a 3rd hiccup (for me being in SLC) comes from no one being able to immediately tune it. That should happen soon however, but going in to it I just didn't figure no one would be setup to do the tune right after I was done with the install. I almost ended up buying my own ECUTek cable. So have that piece planned early on.
Robojesus is offline   Reply With Quote
Old 07-30-2013, 01:24 AM   #13
Threads
Drives: FRS
I called the greddy dealer directly and those were the two things he mentioned as well (tapping the oil pan and cutting into the crash bar).
Do you see any potential issues with installing a koyorad radiator as well?
http://www.ft86club.com/forums/attac...7&d=1363640952
Thanks for the great response by the way!
Old 07-30-2013, 11:43 AM   #14
JM Auto Racing
Sent you a PM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 12:50 PM
Turbo Questions marine321 Forced Induction 7 06-03-2013 07:22 PM
Greddy EVO 3 + front and overpipe questions jonbonazza Engine, Exhaust, Transmission 5 06-02-2013 11:00 AM
Greddy turbo clayrush Forced Induction 12 12-18-2012 01:19 PM
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 09:13 PM
