Old 07-24-2013, 04:33 PM   #1
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Rev Works Southeast Install Specials!!
Its Time to give back to the community. We here at Rev Works have had a great amount of support from local car enthusiasts and members from these forums, and we would like to show our appreciation.
We have developed a few package deals that include an installed price. These prices are at a discounted rate from our normal pricing, so you will only find these deals on the forums!
SouthBend Clutch Kits - Starting at $850 Installed
The DXD Clutch Kit offers something for everyone with some power! These clutch kits utilize South Bend's high performance pressure plate. You can expect a moderate increase in pedal pressure but with dual spring hub, various friction surface options and this pressure plate, you have a clutch that will hold some serious power and last!
Coilover Installation Package - $1350 Installed and Aligned
Your choice of the following 3 coilovers:
BC Racing
  • Mono-tube shock design
  • 30 levels of damping force adjustment, adjust compression/rebound
  • Pillowball mounts and adjustable camber plates included (where applicable)
  • Adjustable rear camber plates available
  • Separate full length height adjustable
  • One year warranty
  • Rebuildable
Stance Super Sport's + $50
  • 15-Way Damping Adjustable
  • Adjustable Camber Uppermount
  • Pillowball Uppermount
  • Cold Wound Linear Spring
  • Inverted Monotube Shocks
  • Dustboot
  • Aluminum Collars & Upper Mounts
  • Height Adjustable Lower Bracket
ISC coilovers
  • 32 Step Damper Adjustable
  • Piston Rod Design
  • Sports Spring
  • Ride Height Adjustable
  • Aluminium Bracket
  • Single Cylinder Design
So what you get with this package is a full coilover setup, complete with installation, alignment and height adjustment. We start with disassembling each coilover and applying anti seize to them to give them long term adjust ability and prevent seizing. We will then install each coilover and set to the desired height and dampening. This means no matter if you plan on running on track with your new setup or just want to get rid of some of that 4x4 height the car comes with stock, we will be able to set you up exactly how you want. After we make all necessary adjustments, we will then align the car into spec also following the same rule as before, based off your driving habits.
A new promotion for the month of October. Any purchase and installation of BC Racing coilovers will get your car aligned for free!! That's a savings of $125 just for buying an already fantastic set of coilovers.
What you get:
  • BC Racing Coilovers (For any vehicle)
  • Installation
  • Ride Height Adjustment Set
  • Anti-seize applied on all coils
  • Alignment set to desired specifications
Rev Works is offline   Reply With Quote
The Following 8 Users Say Thank You to Rev Works For This Useful Post:
Dadhawk (11-06-2013), ecko04 (08-13-2013), Enraged21 (07-24-2013), Ryaquinn (08-06-2013), sirwiggles (04-07-2014), Solbadfrs (06-01-2014), Wo6M (07-24-2013), WolfpackS2k (07-24-2013)
Old 07-24-2013, 04:49 PM   #2
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Wow that seems like some awesome pricing!
The Following User Says Thank You to WolfpackS2k For This Useful Post:
Rev Works (07-24-2013)
Old 07-24-2013, 07:02 PM   #3
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
The Pricing you guys are presenting and second to none! Truly admiring and i wish the best to anyone working with you guys.
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
The Following User Says Thank You to Wo6M For This Useful Post:
Rev Works (07-25-2013)
Old 07-25-2013, 08:53 AM   #4
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Thanks guys! We just want to be able to help out the community by offering some great packages that wont break the bank
-Matt
The Following User Says Thank You to Rev Works For This Useful Post:
WolfpackS2k (07-29-2013)
Old 07-27-2013, 09:48 AM   #5
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Take advantage of our great deals and schedule your appointment today
Old 07-29-2013, 02:48 PM   #6
Frs32907
Drives: Asphalt grey, manual Fr-S
Do you guys offer any fiancing options for the supercharger? Also how much power does it give the fr-s
Frs32907 is offline   Reply With Quote
Old 07-30-2013, 06:57 PM   #7
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Hey buddy replied to your PM
-Matt
Old 07-31-2013, 02:43 PM   #8
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Guess what day it is!!
[ame="http://www.youtube.com/watch?v=kWBhP0EQ1lA"]GEICO Hump Day Camel Commercial - Happier than a Camel on Wednesday - YouTube[/ame]
The Following 3 Users Say Thank You to Rev Works For This Useful Post:
Dadhawk (11-06-2013), lbroskee (08-20-2013), WolfpackS2k (08-01-2013)
Old 08-06-2013, 01:40 PM   #9
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Tuesday Bump!
Member of FT86Club.com?? Use coupon code "FT86" during checkout when ordering from our website and you will receive an additional 5% off of your total order! Just one more way, Rev Works is here to help you!
WolfpackS2k (08-07-2013)
Old 08-07-2013, 11:47 AM   #10
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Looks like someone is taking advantage of our Supercharger Install deal! Stay tuned for some pics from the install in just a short while!!
Old 08-11-2013, 12:31 PM   #11
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Weekend bump!
Old 08-11-2013, 12:44 PM   #12
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Mr Zgrinch is watching this eagerly.
Great price installed and tuned... ETA on completion and Dyno?
BRZGrincherhood
Zgrinch is offline   Reply With Quote
The Following User Says Thank You to Zgrinch For This Useful Post:
Rev Works (08-12-2013)
Old 08-11-2013, 04:18 PM   #13
mfbmike
Drives: 2013 FRS, 2008 R32
Holy cow. Looks like some trips up to Orlando may be in order.
mfbmike is offline   Reply With Quote
The Following 2 Users Say Thank You to mfbmike For This Useful Post:
Rev Works (08-12-2013), WolfpackS2k (08-14-2013)
Old 08-12-2013, 09:46 AM   #14
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Car just got dropped off at 9:45am Will post it up when its done later today
Car dyno'd at 163hp stock. Will have dyno numbers after the SC later this week
You let me know when you are ready and ill make some room in the shop for you buddy
Zgrinch (08-12-2013)
Recommended Shops (Southeast) Sportsguy83 Southeast 96 12-13-2022 02:34 PM
Official Southeast 86 Thread L3P47 Southeast 61 06-18-2014 03:20 PM
New moderators in the Southeast Region Sportsguy83 Southeast 8 11-08-2012 04:34 PM
Southeast Toyota Finance rushdown Southeast 0 08-22-2012 10:23 AM
Southeast sound OFF! OldSkoolToys Southeast 133 05-25-2012 12:31 AM
