Old 07-16-2013, 06:05 PM   #127
edj
edj's Avatar
Drives: 2022 Toyota GR86
Originally Posted by Kido1986 View Post
Im confused by the BRZ/STI to STU entry. Are they just pre-empting Subaru in an STI model launch?
this was a joke entry put in there by the STAC.
those SCCA types are a bunch of comedians.
it will (hopefully) be removed from the official minutes.
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
Old 07-16-2013, 06:37 PM   #128
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Ah, gotcha. Humor doesn't translate well in plain text formatting hahaha
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 07-16-2013, 08:58 PM   #129
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
I am glad to see it left in CS, it is a great fit for it.
DylanFRS is offline   Reply With Quote
Old 07-24-2013, 02:18 PM   #130
qoncept
qoncept's Avatar
Planning ahead for next year ... it looks like most of you are running 225s and a few 235s. Anyone with 245s or 255s on the 7" wheels?
qoncept is offline   Reply With Quote
Old 07-24-2013, 02:24 PM   #131
Kido1986
Dodging cones
Kido1986's Avatar
Bigger than a 225 on a 7" wheel (street tire only, this doesnt include RComps) isnt really the best move for most cars. Pinched tires will cause turn in to be much poorer than it should be.
Im buying tires now, stuck between 215 and 225 but since I run RS3s whicha re known to have softsidewalls, Im going with a 215 I believe. If I was buying Rivals or Z2s, Id go 225.
Old 07-24-2013, 02:48 PM   #132
mla163
Overthinking it
Drives: BRZ in CS
I just picked up 225 Rivals. 235s will fit. 245s are too much and will probably rub.
I asked in a few previous threads and none of the 215 guys were happy with them.
mla163 is offline   Reply With Quote
Old 07-24-2013, 03:20 PM   #133
Kido1986
Dodging cones
Kido1986's Avatar
On rivals, 225 is the better choice. I just like my RS3s still and they are too soft to go 225.
Btw 245s fit on +42 wheels, just ask all the CS guys.
Old 07-24-2013, 03:20 PM   #134
Wepeel
Drives: '13 BRZ Ltd
What do you guys think about the twins against the 370Z in C Street? It doesn't look like there's a lot of data in the 370Z in RTR trim.
Wepeel is offline   Reply With Quote
Old 07-24-2013, 03:26 PM   #135
Kido1986
Dodging cones
Kido1986's Avatar
The 370Z will be a tough car to run in RTR/C Street. It was competitive but didnt top the podium often on R Comps. With it being significantly heavier than NC Miata, RX8 and Twins, it will have more trouble than before now on street tires. On a really open track, it will shine but it won't transition near as well, swinging 3300-3400lbs around on street tires.
Old 07-24-2013, 03:42 PM   #136
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Someone from my local SCCA chapter is thinking of going down to 16's on their BRZ for CS next year. What do you guys think of going to 16's on these cars?
G_Ride is offline   Reply With Quote
Old 07-24-2013, 03:51 PM   #137
qoncept
qoncept's Avatar
The car isn't offered anywhere in North America with 16s so they can't, right?
Either way, I think the 16" tire selection would be pretty disappointing. I ran 16x8s on my WRX for a while and there was hardly anything to choose from.
Old 07-24-2013, 03:51 PM   #138
Wepeel
Drives: '13 BRZ Ltd
I thought they got rid of the +/-1" diameter allowance?
Old 07-24-2013, 04:27 PM   #139
Kido1986
Dodging cones
Kido1986's Avatar
16s don't provide a good tire height for manual cars. Total tire height is too short, as the car has problems with redlining 2nd gear already in many autocrosses
The proposed for +/- 1 is still there I believe. I read each FastTrack and I dont recall it being removed.
I wish I could find 18x7 +42-48 wheels that are light enough but they dont exist. I have an idea to really help this car but I dont have the money to have someone build me a custom set.
Old 07-24-2013, 04:43 PM   #140
G_Ride
G_Ride's Avatar
I guess I should say C Street for next year, as I believe the +/- 1" diameter change is still being allowed.
He was thinking of going 225/50/16, which I think is too much sidewall. I'm still unsure if going to 16's is the best choice either. His reasoning for 16's had to do with tread width. I think it was about a 225/50 tire being meant for a 7" wide wheel. With 17's, a 225/45/17 or 235/40/17 tire is meant for something wider than 7" (but still will fit) will be more pinched, and the actual width of the tire touching the ground will be less than the 225/50/16 tire. Like I said, I'm not sure going to 16's is the best choice, but I guess we'll find out.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
