Old 07-23-2013, 11:25 PM   #5839
Carwhisperer
Drives: A lot of supercars.
Originally Posted by ft86me View Post
You might wanna open a ticket for that like ASAP
No, I'm going to fix it myself with a local tuner.
Carwhisperer is offline
The Following User Says Thank You to Carwhisperer For This Useful Post:
ft86me (07-23-2013)
Old 07-23-2013, 11:28 PM   #5840
ft86me
ft86me's Avatar
Drives: 2013 FRS
those of you that WENT 12psi pulley did you need a new belt?
ft86me is offline
Old 07-24-2013, 12:10 AM   #5841
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Originally Posted by atledreier View Post
Had my stg1 pumpgas done yesterday, along with a catback. Apart from sound it doesn't really feel any different.... A little more after the torquedip perhaps, but not much. The features are cool though.
Are there any way to adjust the autoblip? It seems to blip way too little for any kind of revmatching...
Probably need a modified tune - put in a request. From what I have read they can adjust the amount of throttle autoblip, but you can't.
Sport-Tech is offline
Old 07-24-2013, 07:26 AM   #5842
Visconti
Drives: 05 STi
Originally Posted by Carwhisperer View Post
Got CEL P0011 and P0351. The Cams on my car are fucked on v1.14. Going back to stock it runs perfect. Idk whats going on anymore with my car.
Not even going to try and go back and run data logs, not safe at all.
It's not the tune
The cam mapping that's in this tune has been setup like this since day 1... 10 months now. I've made several slight tweaks over the months... Nothing that's drastically different from stock
Visconti is offline
Old 07-24-2013, 07:34 AM   #5843
JiB
JiB's Avatar
Drives: GT86
I finally found out what all the danger talk was about with auto blip this morning hahah. for some reason the car started on map 4, or i forgot i put it on. either way. came into a tight corner in 3rd, was going to downshift but decided against it just as i touched the clutch while braking, so i just tapped the clutch. then the car jumps into the corner pulling for half a sec, heart rate skyrocketed
JiB is offline
Old 07-24-2013, 07:51 AM   #5844
Visconti
Drives: 05 STi
I wasn't kidding !
Visconti is offline
Old 07-24-2013, 07:56 AM   #5845
JiB
JiB's Avatar
Drives: GT86
I wasn't kidding !
lol nope... tomorrow im going to try and re create it in a safer environment.
from what i can tell, for it to work you have to be over 3k rpm and faster than 60km/h.
Is that right?
JiB is offline
Old 07-24-2013, 07:57 AM   #5846
Visconti
Drives: 05 STi
Is that right?
And faster than. 40mph
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
JiB (07-24-2013)
Old 07-24-2013, 08:03 AM   #5847
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Any updates on new customers tunes? When u gonna send em out?
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline
Old 07-24-2013, 08:11 AM   #5848
Visconti
Drives: 05 STi
Didn't think there were any new tune requests , I'll have to double check, but plan on getting everything out shortly
Visconti is offline
Old 07-24-2013, 08:19 AM   #5849
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Thanks....
Btw.. Request number #2531 and I'm looking forward for my first tune
Old 07-24-2013, 08:51 AM   #5850
Foobar
SLO NO MO
Foobar's Avatar
I gues I'm pretty behind?
v1.01b3
Just one release behind. That was the same version I was on until this past weekend when it jumped to 1.06
Foobar is offline
The Following User Says Thank You to Foobar For This Useful Post:
ft86me (07-25-2013)
Old 07-24-2013, 09:26 AM   #5851
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Hi John,
Im going in for service with Toyota on Friday and they going to connect up to verify the SW A001 upgrade. I loaded my stock A001 ROM file and ran for a day, the CEL came on due to the header O2 sensor. Load the tune back and the CEL was cleared.
I was under the impression this would not happen while on the stock ROM with Ecutek?.
I have purchased a spacer and will install to prevent CEL with or without tune.
Then Ive tried V1.13 and v1.14 and both tunes in map 2 to 4, launch control is not working, sent a ticket.
the autoblip is frikkin awesome BTW.
Ryan86 is offline
Old 07-24-2013, 10:01 AM   #5852
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Yeah, I finally figured out how auto-blip works. You can get all the way down into 2nd gear. I used to hate it because it seemed inconsistent, but now that I knew exactly how its working, it seems more fun to play with. I haven't tried launch control with this version. I'll have to see if it works. I'm always on map 4. Maybe I need to try the other maps.
JimmyMac is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
