Old 07-24-2013, 12:47 AM   #15
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
^Hey, you're Canadian - you should be fluently bilingual, n'est-ce pas?
Sport-Tech is offline   Reply With Quote
The Following User Says Thank You to Sport-Tech For This Useful Post:
canu_50 (07-25-2013)
Old 07-24-2013, 12:49 AM   #16
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
Originally Posted by number1Tango View Post
from what ive heard not just form this vehicle but other as well, even when you reflash your ecu and get more power, over a given period of time it will start reverting back to how it used to be with the factory AFR. I could be wrong, its just what ive heard.
This theory is very interesting...
But I hope you are wrong because that mean all Ecutek folks are wasting their monney.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 07-24-2013, 12:51 AM   #17
NoFear99
NoFear99's Avatar
Je me débrouille . I try to speak with mon tête !
Old 07-24-2013, 12:56 AM   #18
NoFear99
NoFear99's Avatar
Originally Posted by FA20Club.com View Post
why dont you send me the log since you just installed the over pipe and i was expecting your log anyway
You want me to send you the log I did today where I'm fully rich or you want me to send you a log after a fresh reflash with a better normal afr reading ?
Which one is more valuable for you to know if you have some corrections to do or not ?
Old 07-24-2013, 01:26 AM   #19
Fast_Freddy
Drives: Passat
That only applies to closed loop AFR changes made with a piggyback. The ECU can and will override any attempts to change the CL AFR from the 14.7:1 target value. Open loop AFR can be modified but is also subject to some ECU changes due to closed loop fuel trim changes. That's why it's so important to zero out your fuel trims before you start tuning.
Originally Posted by NoFear99 View Post
This thread you are refering me seem very interesting but too complicated for me especially when English is not your language.
May be somebody could explain here what this thread is all about in a simple short summary...
I'll try to simplify this as much as I can but I'm not sure if it will help.
The ECU sees how much air is entering the engine via the MAF sensor and looks at a preset table to determine how much fuel to add in order to achieve the target AFR. The ECU then reads the O2 sensor to see if the AFR is correct. When the O2 sensor AFR is too lean, the ECU applies a positive short term fuel trim (STFT) to richen the mixture to reach the target value. If, for instance, the ECU always has to add 10% extra fuel at a given set of conditions, it will set a long term fuel trim (LTFT) of +10% which essentially adds 10% to the lookup table value.
Now your tune may start out with a LTFT of 0 and that equates to 13:1 AFR but after some learning time the ECU sets a LTFT of +10%, it will add 10% more fuel making your new AFR ~12:1.
I hope this helps. It's the best I could do in a short time.
Fast_Freddy is offline   Reply With Quote
The Following User Says Thank You to Fast_Freddy For This Useful Post:
NoFear99 (07-24-2013)
Old 07-24-2013, 01:34 AM   #20
NoFear99
NoFear99's Avatar
Thanks a lot for this nice summary. It help a lot to understand how an ecu may act.
Old 07-24-2013, 01:42 AM   #21
FAER
Drives: Silver BRZ
So basically we have to re flash every few weeks or so many miles to maintain our tunes?!?
FAER is offline   Reply With Quote
Old 07-24-2013, 01:49 AM   #22
NoFear99
NoFear99's Avatar
For those of you who dont know it, 12.17 is the lowest AFR ( Richer ) reading ecutek may read.
So if you are seeing 12.17 everywhere, that means your car can be anywhere below that point.
Old 07-24-2013, 02:01 AM   #23
Fast_Freddy
Drives: Passat
You're very welcome. BTW, I'm pretty sure that FA20Club.com wants the ECU adjusted "rich" data logs. They tune, the ECU adjusts, they re-tune and so on for a few times until harmony is achieved.
No, see above. You just have to send data logs back to your tuner after flashing the initial tune and allowing the ECU time to adjust to it so he can fine-tune for the changes the ECU has made. It should never be an endless cycle.
Old 07-24-2013, 01:50 PM   #24
wparsons
wparsons's Avatar
Just a clarification... EcuTek can read much lower, the limitation is the stock O2 sensor range. If you run an aftermarket wideband ecutek can read as low as the sensor can.
flickr
Old 07-24-2013, 01:57 PM   #25
ft_sjo
Drives: GT86
Just for clarification on your clarification; the stock sensor can read outside that range too, they just calibrated it down to 12.17. Chances are the margin of error between different sensors was too much below this point, or it just didn't matter and they wanted resolution over range.
Old 07-24-2013, 02:41 PM   #26
Dynotronics1
that's not quite correct. The STOCK program is only scaled down to 12.17. A simple reset of the scalar will net you correct readings down to 10.5 with no loss of resolution.
OP, you might want to log injector PW on that to really see where you are. I would bet your pig rich based on a few other parameters I'm seeing on that log
Dynotronics1 is offline   Reply With Quote
Old 07-24-2013, 02:56 PM   #27
ft_sjo
Drives: GT86
That's amazing. You can increase the range, whilst not losing resolution. Please let us into your secret on how ADC's work like this.
Old 07-24-2013, 02:58 PM   #28
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I know on my FA20Club FI tune, the AFR is scaled down to 11.02 I believe, but there is no reason to lose the resolution on an NA tune.
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 01:57 AM
Just want to make sure Moonbase Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-16-2013 05:02 PM
Need to make time this weekend.. Khánh Scion FR-S / Toyota 86 GT86 General Forum 0 02-06-2013 08:43 PM
Dynotronics and their E-Tune/ OTA tune. Ricepuddin User/Vendor/Sponsor Reviews, Feedback, Comments 5 12-24-2012 10:53 AM
Time to make some noise and some demands: VR + AP CF FR-S/BRZ aero trim poormans_LFA Cosmetic Modification (Interior/Exterior/Lighting) 14 09-05-2012 05:44 PM
