Old 01-08-2012, 05:02 AM   #15
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
either way... another way to look at it...
how many brands improve the average fleet mpgs with a new sports car... especially since toyota is already known for having one of the best
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 01-08-2012, 05:43 AM   #16
serialk11r
Drives: '06 AM V8V Coupe
FA20 appears to have cam phasing, no variable lift of any sort, as the head does not appear to have the space to accommodate the extra rocker/rollers/followers/whatever which all variable lift systems have. Sadly since boxer engines are so wide, I'm guessing variable lift won't make it for space reasons, unless they're willing to really change some stuff around. Valvematic doesn't provide a performance benefit in itself, but the better part load efficiency could give some emissions/efficiency headroom for larger cams for max power.
D4-S acts independently (as does any fuel injection) although timing is optimized according to the other parameters, if that's what you mean. I suppose D4-S + Valvematic (which needs to go with variable cam phasing to advance the cam when duration is shorter) makes tuning a bit difficult since lift dictates duration dictates load, and you would need to figure out direct injector timing not only at different speed but at different load as well.
Anyways, there's no reason a sports car should necessarily get worse mpg, just that up till recently engines have not been advanced enough to preserve fuel economy while offering high performance. D4-S seems pretty remarkable in that it can significantly improve combustion at low rpm even with a fixed profile cam that makes max torque at 6600 :O (besides the fuel economy/emissions benefits)
And I apologize that fuel economy appears in like 90% of my posts, I just like analyzing the thermodynamics a lot :P
Old 01-08-2012, 06:40 AM   #17
Stigmaru
Stigmaru's Avatar
Drives: 2022 Halo White GR86
In layman's terms: Not many $25K sports cars have direct fuel injection
Stigmaru is offline   Reply With Quote
Old 01-08-2012, 06:52 AM   #18
Navi
Drives: Peugeot RCZ EP7 4E-FTE Ford ST150
Send a message via MSN to Navi
Another review that says it will be released in June.... (8/6?)
1987 Corolla AE82 4AGTE - Sold
1988 Starlet EP71 4EFTE - Current
2008 Ford Fiesta ST150 - Current
2010 Peugeot RCZ - Current
Visit: http://www.4agte.nl
Navi is offline   Reply With Quote
Old 01-08-2012, 11:19 AM   #19
miata
Drives: 2006 Miata 5 spd
June and spring. Officially June 21st is the beginning of summer so it will be sometime before then.
miata is offline   Reply With Quote
Old 01-08-2012, 11:42 AM   #20
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
For some reason, 8/6 (June 8th 2012) sounds like the day...
I want it earlier, but that date is pretty darn cool!
- The Ancient BRZ Sacrament
by Zaku
Old 01-08-2012, 12:20 PM   #21
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
I wouldn't mind 8/6 either even if it was August 6th.
That would be so awesome
Snoopyalien24 is offline   Reply With Quote
Old 01-08-2012, 01:08 PM   #22
Levi
Drives: Toyota
I think I won't have any problem with consuption. My Alfa is new and I pay I need 10 liters to drive 100 km. I am sure the BRZ will be better and yet more powerful.
Levi is offline   Reply With Quote
Old 01-08-2012, 06:05 PM   #23
carbonBLUE
Reverse Burnouts
well if they drop it on june 20th (my b-day) ill be a happy mother fucker, i plan on buynig the car in cash then driving to vegas for the break in then blow some more money cause i can...
(wont forget you)
2011 Infiniti G37x
Old 01-08-2012, 11:41 PM   #24
DRACHENV6
Drives: tata nano
wow... 35mpg?! If true, this car would be good enough to be a daily driver for many folks. It would compare nicely with the corolla, and give other car manufacturers a reason to panic.
comparison:
2011 corolla 5spd - 2734 lbs 28/35mpg
2012 scion frs 6spd - 2700(?) lbs ??/35mpg
Those are crazy numbers. If everything they say is true, than toyota was justified in adding D4-S tech and subaru benefited as much as toyota, if not more from the collaboration.
DRACHENV6 is offline   Reply With Quote
Old 01-09-2012, 02:49 AM   #25
carbonBLUE
Reverse Burnouts
comparison:
i hope its 35 average between city and highway itll make the corolla look like a gas guzzler lol
(wont forget you)
2011 Infiniti G37x
Old 01-09-2012, 06:51 AM   #26
Infernal
NO FI?! (╯°□°)╯︵ ┻━┻
Infernal's Avatar
Drives: BMW e92 330D
that would be perfect - my insurance si due for renewal then :P
pulling my hair out waitinng to drive this thing
Infernal is offline   Reply With Quote
Old 01-09-2012, 01:43 PM   #27
carbonBLUE
Reverse Burnouts
Looks like DAVCS will be behind the valvetrain timing
(wont forget you)
2011 Infiniti G37x
Old 01-09-2012, 02:09 PM   #28
WhiteGDB
WhiteGDB's Avatar
Drives: Civic Si sedan
Except there are a lot of sporty cars with direct injection in the $25k range. Just off the top of my head:
VW GTI/GLI
V6 Camaro
Colbalt SS
Mazdaspeed 3
New Genesis Coupe?
WhiteGDB is offline   Reply With Quote
Top Gear Magazine Review of Subaru BRZ and Toyota GT86 davey90 BRZ First-Gen (2012+) — General Topics 122 01-09-2012 12:15 PM
Evo Review: BRZ + GT86 Boxer-4 BRZ First-Gen (2012+) — General Topics 51 01-08-2012 08:10 PM
EVO magazine review of GT86/BRZ review out TheRoadWarrior Scion FR-S / Toyota 86 GT86 General Forum 6 01-05-2012 09:26 PM
AutoExpress BRZ Review - Follow up to the GT86 Review Zgrinch BRZ First-Gen (2012+) — General Topics 3 12-13-2011 09:03 AM
UK WhatCar? GT86 Review Nerfie Scion FR-S / Toyota 86 GT86 General Forum 10 12-02-2011 02:15 AM
