Old 07-23-2013, 06:08 PM   #1
Dezoris
Dezoris's Avatar
The Vortech Autox Review
Americanizing the FR-S Part 3: Autocross Review
Vortech Supercharged - Perrin Tuned
VIDEO INDEX:
0:00-0:00:25 Opening
0:00:30-2:25 Course Walkthrough
2:25-3:40 Owner Impressions of Vortech Kit
3:50-5:30 Full Autox Run
5:31-6:48 Time Sheet Review
6:52-9:30 Pros and Cons, Final Thoughts
FULL VIDEO:
[ame="http://www.youtube.com/watch?v=B6_B4Wuvh0o"]Supercharged Vortech Scion FR-S BRZ Autocross Review | Part 3 of 4 - YouTube[/ame]
MODIFICATIONS LIST:
Engine:
Vortech Supercharger Tuner Kit
ECUTek / Perrin Tuned Rev. 10
Radium Engineering Dual Catch Can
Koyo Radiator and Perrin Silicone Hose Assembly
Oil Cooler Mocal / Perrin
Perrin 2.5 Header Back, Catted and Resonated
Brakes:
Primary Vendor: Counter Space Garage
Project Mu 800HC (Street)
Rotors: OEM
Suspension:
Stranoparts ARB
Whiteline Front Camber Bolts
Whiteline Rear UCA Bushing Camber Kit
Alignment:
Front
-1.4 Camber
1/8th" Toe Out
REAR
-1.3 Camber
1/16th" Toe In
Tires:
225/40/17 RS3 Hankook
Impressions Pre-Supercharging:
For the full details of the car before supercharging review the final review here:
[ame="http://www.youtube.com/watch?v=rsWHuEUVK3k"]The Marginal Scion FR-S BRZ Final Review | Part 3 - YouTube[/ame]
Impressions Vortech Supercharged:
PROS
  • Acceleration is linear and non-disruptive to fine inputs.
  • Longer straights or sweepers highly benefit from added power.
  • Car no longer struggles pulling out of tight sectors in 2nd gear
  • No one who has driven the car or rode along stated the extra power was negative to drivability.
CONS
  • Added power does not equate to better times
  • Higher class makes car virtually uncompetitive
  • Makes setup more difficult with less people running higher HP.
  • Higher heat, requires more
    care in terms of cool down cycle hood venting and preventing heat soak in IAT and radiator.
The Following 3 Users Say Thank You to Dezoris For This Useful Post:
qoncept (07-23-2013), simpleisbest (07-24-2013), toro73 (07-29-2013)
Old 07-23-2013, 06:09 PM   #2
Dezoris
Dezoris's Avatar
Reserved
Old 07-23-2013, 06:15 PM   #3
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Yeaaaa your car is not STX legal at all.
edit: i see that you entered SM. gotcha. i was very confused why all your comparisons were against stx until i paid closer attention.
supramkivtt2jz is offline   Reply With Quote
Old 07-23-2013, 06:26 PM   #4
qoncept
qoncept's Avatar
I don't think many will be surprised to see supercharging doesn't make the car much (if at all) faster at an autox. Now you can just drive and not worry about the burden of being competitive.
qoncept is offline   Reply With Quote
Old 07-23-2013, 06:36 PM   #5
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Driver mods are always the biggest bang for the buck
mechaghost is offline   Reply With Quote
The Following User Says Thank You to mechaghost For This Useful Post:
whataboutbob (07-24-2013)
Old 07-23-2013, 06:37 PM   #6
Dezoris
Dezoris's Avatar
The most asked question was, "that thing must fly now."
It's completely interesting to see the car before and after.
Before I felt, the car almost stock in RTR/CS or STX was perfect.
But hated it on the track.
After, it's not good enough in autox anymore if you want to compete. Still fun obviously. Have to wait to see how the track experience goes.
Old 07-24-2013, 10:00 AM   #7
TimR
TimR's Avatar
Drives: Limited Lightning Red
Nice pic of my car in there - Thanks!
TimR is offline   Reply With Quote
Old 07-24-2013, 12:11 PM   #8
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
That was an interesting review. However, I'd like to see how a well prepped SM twin will do. It'll be costly, but it is the "Spend Money" class.
G_Ride is offline   Reply With Quote
The Following User Says Thank You to G_Ride For This Useful Post:
Old 07-24-2013, 12:20 PM   #9
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I think it can be good with the higher class. You are way underprepped for the class that the supercharger puts you in. Plus on street tires. The bumped class allows for a lot of weight reductions a lot more tire and rim width, bigger brakes ect. Until the car is prepped 100 percent to the rules its hard to say if it will be competitive or not.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
Old 07-24-2013, 01:13 PM   #10
G_Ride
G_Ride's Avatar
I agree. Hopefully, someone will try one day.
Old 07-24-2013, 01:45 PM   #11
Dezoris
Dezoris's Avatar
It was right when the rain started!
Old 07-24-2013, 01:47 PM   #12
Dezoris
Dezoris's Avatar
I don't think most people would find the value in turning this car into a stripped down SM car for autox until you can buy one for 10k.
Old 07-24-2013, 01:58 PM   #13
simpleisbest
Senior Citizen
Drives: Scion FR-S
Awesome review!
Toss some Hoosiers on it and try again.
Also, I think your review closes the door on the platform for SM class prior to fully exploring the key allowable "other than power" mods (Tires, Wheels, Gearing, Suspension, Aero, Diff).
simpleisbest is offline   Reply With Quote
Old 07-24-2013, 02:28 PM   #14
Dezoris
Dezoris's Avatar
Originally Posted by simpleisbest View Post
Awesome review!
By far the key limiting factor here is definitely grip. Some areas it's terminal understeer, some it's overseer.
@TimR
After getting settled with the car other than smoothing out a few areas I don't think there was a lot of time to be found.
Getting the car to trailbrake was also much more difficult than other cars I have driven.
Throwing power at it was not the answer by any stretch.
The Dramatic Supercharger Install and Final Review | Vortech, Perrin More Dezoris Forced Induction 93 09-09-2013 02:52 PM
Supercharged Vortech FRS/BRZ Install and Review - Videos!! davidchoi Scion FR-S / Toyota 86 GT86 General Forum 10 07-05-2013 03:27 PM
Supercharged Vortech FRS/BRZ Install and Review - Videos!! davidchoi Forced Induction 1 07-05-2013 10:58 AM
Vortech charged, Perrin tuned. Review and dyno. Wonderbar Forced Induction 21 06-04-2013 12:57 AM
autox or autox school? engee Tracking / Autocross / HPDE / Drifting 10 06-12-2012 07:31 PM
