Old 07-23-2013, 03:17 PM   #1
Howardwei
Heel-Toe on track
Hey Guys,
I was wondering if you come up to a corner that you could take with 30-35 mph but you were initially at say 7mph. Do you just brake until you hit the 30-35 mph and heel toe? I found that its quite hard to downshift into gear right after you blip the throttle. I always have to shift first then blip then clutch out.
Sorry if it's too vague, let me know and thanks!
Howardwei is offline   Reply With Quote
Old 07-23-2013, 03:24 PM   #2
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
The idea of heel-toe is two-fold: first, you allow the engine deceleration to act as additional braking force. Secondly, you complete the shift to a lower gear while braking so you don't spend time coasting after the brake zone getting into the right gear before you get back on the gas.
So, usually I'll start my braking to get the balance of the car right, and once the weight is transferred to the front of the car, I'll move my heel over and give a quick blip while moving the shifter to the lower gear, then let the clutch out. The key is to get as close as possible to a perfect rev match so you don't jerk the car by letting the clutch out. In an extreme instance, you'll lose the back end doing this and end up giving a hokey pokey clinic by turning yourself around.
Here's a video of me messing around in my Lemons car showing plenty of heel toe action:
[ame="https://www.youtube.com/watch?v=UJH3yU5TmUw"]Driving the Lemon at Putnam Park - YouTube[/ame]
Let me know if you need me to clarify anything.
trippinbillies40 is offline   Reply With Quote
Old 07-23-2013, 03:29 PM   #3
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
The more you slow down, the larger blip you need. How you come off the clutch is probably the most important part of the whole mess.
GTM_Challenge is offline   Reply With Quote
Old 07-23-2013, 05:20 PM   #4
Howardwei
Heel and toe
I guess I just don't really understand because I would see some ppl heel toe twice for a single corner. but base on what you did. even if you are in 5th gear you could slow down fast enough to go from 5th directly to 3rd? Is it more like predicting what speed range you are going to be in during the initial brake like you said as the weight of the car is transfer to the front then you heel toe according to the speed at that moment? and also I think what you did was you blip after you first shift to the lower gear correct?
Old 07-23-2013, 05:21 PM   #5
GTM_Challenge
Drives: On track
This is usually due to styles. Some people rev match through the gears (what I do personally), others would go 5th-3rd. It's all personal preference.
Old 07-23-2013, 05:27 PM   #6
Howardwei
wouldn't going through the gear waste more time and increase your chance to corner not as precise as you wanted it to be?
Old 07-23-2013, 05:30 PM   #7
GTM_Challenge
Drives: On track
If you're doing it while slowing down still, there is no lost opportunity that you could be accelerating instead. It truly is an art that takes years to get down just right.
The Following User Says Thank You to GTM_Challenge For This Useful Post:
Symmetrical (07-23-2013)
Old 07-23-2013, 05:50 PM   #8
Howardwei
You meant if I have to slow down anyway there is no loss of acceleration opportunity right?
Old 07-23-2013, 05:51 PM   #9
Howardwei
It's just that some corners don't require that big of a brake which render me in a weird feet position to heel toe.. Especially driving around town
Old 07-23-2013, 05:53 PM   #10
CSG Mike
CSG Mike's Avatar
Always go into the gate, even if you don't let the clutch out. This will reduce wear on your synchros, and extend transmission life.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
altezza280t (07-25-2013), GTM_Challenge (07-23-2013), oofie (07-23-2013), raul (08-16-2013), WillRacer1jz (07-24-2013)
Old 07-23-2013, 06:42 PM   #11
trippinbillies40
Drives: '22 WRB
In the Putnam video, I'm never in fifth. It's always 4 to 3 in T-1 and 3 to 2 in T-7. I will do multiple heel-toes in a corner if I'm going down two gears, ie. at Mid Ohio.
Old 07-23-2013, 08:51 PM   #12
wheelhaus
wheelhaus's Avatar
It takes a lot of practice. A lot. Everyone develops habits, especially while driving, and learning to heel-toe feels awkward at first because it just doesn't feel right. It's not something that just suddenly "clicks" and you're a pro. Practice...
If you're only slowing a small bit, you may not need to downshift at all. You can bleed off speed simply by turning into the corner, the tire's lateral friction will chew off a few mph. If this makes you fall out of the power curve to exit the turn, then you may have been in too high of a gear to begin with. A heel-toe downshift can be performed very quickly with enough practice.
Learn to pivot your foot around the brake pedal without changing how much pressure you're applying. Even if it's light pressure. The exact motion and placement you feel comfortable with can vary, but typically you use the inner ball of your foot to brake, and the side of your heel to blip/rev the throttle (as mentioned above). This constant pressure is easier to apply under hard braking, but takes more skill and sensitivity under light braking.
If you're braking you can downshift as many gears as necessary, as long as it doesn't prevent you from accelerating when you need to. I also prefer to downshift single gears one at a time as I'm slowing down.
The Following User Says Thank You to wheelhaus For This Useful Post:
GTB/ZR-1 (07-24-2013)
Old 07-23-2013, 09:53 PM   #13
Howardwei
Heel toe
I'm just a little confused now. It's been really good help from you guys. So say I'm at 50mph and I slow down for a corner and not knowing what's the proper speed. Wouldn't it always be good to shift to a lower gear? For ex. Like going through all the gear till like maybe 2nd gear since I take most street corners with 20 mph? Lower gears give you more torque right?
And do you shift into gear before you blip?
Old 07-23-2013, 10:37 PM   #14
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
My go-to video clip when anyone asks.
[ame="http://www.youtube.com/watch?v=VxGtx9xXhlM"]Heel and Toe Braking - Shifting Technique Tutorial: Hooked On Driving - YouTube[/ame]
KKaWing is offline   Reply With Quote
The Following 3 Users Say Thank You to KKaWing For This Useful Post:
altezza280t (07-25-2013), juliog (07-29-2013), MightyMeeple (08-01-2013)
DIY - Drivers Mat Heel pad for only $15 nzer DIY (Do-It-Yourself) Guides 40 09-25-2020 03:00 PM
Heel Toe Question trackmagic Scion FR-S / Toyota 86 GT86 General Forum 36 02-24-2014 12:29 PM
Heel Toe Around Town? strat61caster Scion FR-S / Toyota 86 GT86 General Forum 154 06-12-2013 05:30 PM
Heel toe #87 Other Vehicles & General Automotive Discussions 21 08-25-2012 05:39 AM
Heel and Toe ichitaka05 Other Vehicles & General Automotive Discussions 13 04-02-2010 02:28 AM
