Old 01-05-2012, 10:21 PM   #141
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Originally Posted by Caliban View Post
if turbo can't be fitted under factory bonnet..how did they put a turbocharged motor under the BRZ GT300? the bonnet of BRZ GT300 doesn't look much different than the production model.
The bonnet may be about the same, but nothing else is. JGTC cars are so far from production models that it's not even funny. They have almost nothing in common, or less. My guess is that both the engine and the driver are several inches further back than they would be in a production BRZ, and that's where the extra room is coming from.
Originally Posted by Masuda-san
We can fit tougher valve springs, and that would allow the BRZ to rev much higher, maybe to 9000 rpm.
I like the sound of that. He seems to be saying that the only thing keeping the revs down is valve float (ie. the stock bottom end is already good enough). So I/H/E + cams, valve springs and a reflash could potentially be good for 250+ hp.
old greg is offline   Reply With Quote
Old 01-06-2012, 02:59 AM   #142
balance
Drives: 86 & Picanto
I am also down for 20~30% increase in power only if it is safe from the reliablity standpoint and the cost of the necessary modifications is reasonable.
How much do you think 'I/H/E + Cams + Valve Springs + Ecu reflash' would cost?
I'm thinking 'easy $3K' when going with quality parts....
NA power upgrades are costly....
balance is offline   Reply With Quote
Old 01-06-2012, 09:41 AM   #143
Levi
Drives: Toyota
Sorry, but 3K is worthy. When you make turbo upgrades you also have to upgrade oil-cooler, intercooler and other parts also.
Levi is offline   Reply With Quote
Old 01-06-2012, 01:22 PM   #144
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Depends on how you define "quality"
But yeah $3k ought to cover it. And honestly that's an absolute bargain for 50 hp out of an N/A 2L. You'd spend $4-5K minimum on a turbo kit not counting installation and tuning which might only be good for ~300 hp or so on stock internals (total guess). So price to performance wise it would actually be a very good value at that power level.
Old 01-07-2012, 04:28 PM   #145
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
yeah, easy $3k.
You roughly figure that for quality parts:
intake = $250 for a basic one or upwards of $700 like some of the nice S2k ones.
exhaust = $1000
exhaust manifold/header = $700
cams (subaru) = $800-1000....BC's for like $550
some decent ovate beehive springs = $400
then get a tune...$x
so without a tune firgured in, you're roughly $2900 (low end) up to about $3800 (high end). Then factor in that in order to do valve springs, the head will probably have to come off too. Not sure if we'll be able to pressurize the camber and pull springs on this head. So then factor in some head gaskets and more time.
May as well do valves, a nice valve job and some port work while you're in there
...yes I know the cat is on the exhaust manifold on the FA20.
Homemade WRX is offline   Reply With Quote
Old 01-07-2012, 05:44 PM   #146
catharsis
Drives: honda civic si 08
Originally Posted by Homemade WRX View Post
yeah, easy $3k.
exhaust = $1000
If you're spending 1k on an exhaust but only 700 on a header, you're doing it wrong.
catharsis is offline   Reply With Quote
Old 01-07-2012, 07:04 PM   #147
Homemade WRX
Oh, I just grabbed a few random prices with a quick search.
I do agree that an exhaust manifold is way more crucial than exhaust.
oh and that manifold was some mass produced piece.
Old 01-07-2012, 08:52 PM   #148
catharsis
Ah ok gotcha :happy0180:.
Old 01-08-2012, 05:43 PM   #149
NA_T
NA_T's Avatar
Drives: E36
If only tougher valves springs would do the trick to make the engine rev to 9.000rpm, I dont understand why Toyota/Subaru wouldn't have done it themselves in the first place? This sounds too good to be true, but if it is.. awesome.
NA_T is offline   Reply With Quote
Old 01-08-2012, 06:01 PM   #150
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Im sure both companies' engineers and project planners have thought of plenty power adders or parts that could further increase the cars performance. But were omitted from the final plans to keep costs down.
WingsofWar is offline   Reply With Quote
Old 01-08-2012, 06:24 PM   #151
Homemade WRX
I'd say emissions. The larger the rev range, the harder the FTP cycle (RMC's for that matter too) and the larger your NTE window. To make the 9k worthwhile, you have to make trade offs down low.
Old 01-08-2012, 07:02 PM   #152
serialk11r
Drives: '06 AM V8V Coupe
I think this engine would have one of the longest strokes and THE poorest rod:stroke ratio of any engine that revs past 8k if they did that, which makes me skeptical (even if they could get emissions to be acceptable at >8000 rpm).
Old 01-08-2012, 11:07 PM   #153
Homemade WRX
you do know that the K20 is an 86mm stroke and 86mm bore as well, right?
I have a few things up my sleeve for the FA engine based off of what I already know for the FB25 and handed down from extensive EJ building and K-series work.
put simply, I'm not scared
Old 01-08-2012, 11:10 PM   #154
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
What are you currently thinking?
tranzformer is offline   Reply With Quote
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
Mods? Bruninho8 Scion FR-S / Toyota 86 GT86 General Forum 3 12-06-2011 06:11 PM
Estimated Price.. SLeRoux92 Scion FR-S / Toyota 86 GT86 General Forum 44 05-25-2011 11:58 AM
