#15 | |
http://www.autonews.com/apps/pbcs.dl...EM01/130409934 But, a lot can happen. Mazda will need the 6 and 3 to be a hit like the CX-5 was. If the 3 is a big hit (and all indications are that it is at the top of it's segment) we could see another RX. But like I said, Mazda would be wise to follow what Tada did with the FT86 and make is a more affordable sportscar. |
#16 |
Or burn unnecessary amounts of oil, especially with emissions regulations they really need to develop the engine.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | wparsons (01-12-2014) |
#17 |
Drives: 2013 Ultramarine FRS
Considering the 1.3L RX-8 only got 16/22mpg with 250hp, i'm doubting the 1.6L with 300hp will get much closer to the 30mpg mark. Rotaries have always been too thirsty for my particular tastes, maybe i'm just a cheap skate
#18 |
Drives: Nevermorange FRS
How do you guarantee your sports car will be a sales failure?
Answer: put a rotary in it!
PRO86 | WTCC | STL
| The Following 6 Users Say Thank You to rice_classic For This Useful Post: | Dimman (07-22-2013), dsmx17 (07-18-2013), FnFast (07-22-2013), FRSBRZGT86FAN (01-16-2014), NWFRS (01-12-2014), WingsofWar (07-22-2013) |
#19 |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
If it comes in 2017 then my guess is $45K and no turbo.
So many modders have more cents than sense!
| The Following User Says Thank You to Rampage For This Useful Post: | FnFast (07-22-2013) |
#20 |
Drives: '06 AM V8V Coupe
If it passes emissions on 2017 that means it can't burn oil...they'll need to sort out some ceramic seal magic to make that happen.
#21 |
Praise Helix!
They ought to just make a deal with GM and source out a bunch of LS engines. More power and better fuel economy. Best modification you can make to a rotary car!
#22 |
MODERATOR-SAMA
Drives: Swagtron Scooter
a rotary that meets todays global emissions is magic on its own. but i have faith in Mazda that their team found good solutions to horrible fuel and oil consumption that plagued the previous rotaries.
#23 | |
Kuruma Otaku
The other problem is that they are inherently compression limited, and have poor combustion chamber shape. So the poor fuel efficiency is also a 'solution'. Running pig rich to get even fuel dispersion. However... If they take a radical new approach to fight the natural weaknesses, who knows? But when you start hearing about experiments with laser ignition, well it's either outside-the-box thinking or crazy desperation with no regards to reliability (still...). Mazda, just make a coupe that is as sexy and light as an FD and put a normal engine in it.
Because titanium. |
#24 | |
Nobody beats the B[I|R]Z
Drives: shopping cart i stole from walmart
Answer: post something stupid about rotaries The sales of the 1st gen RX-7 were nearly half a million https://en.wikipedia.org/wiki/Mazda_RX-7
"The [Subaru BRZ] feels as trim, nimble, and athletic as the great sports coupes of the pre-bloat era."
-- Car and Driver, June 2012 "And I thought to myself, I'm not going to die, because this is annoying" -- Niki Lauda |
#25 | |
Kuruma Otaku
Because titanium. |
#26 |
Rotaries had been on sale for nearly a decade when the RX-7 came out, and over 15 years in other countries. So if it was a matter of "getting the word out" the SA/FB RX-7 wouldn't have had such a successful run for so log, so that argument doesn't hold water.
The 1st gens and non-turbo 2nd gens have proven to be pretty solid for reliability. The 2nd gen onwards became significantly more expensive than than the original during a time when sports car sales were declining in general (by the mid/late 90s, the miata was about the only Japanese sports car still for sale in the US) Facts good, ignorance bad...
#27 | |
For a rotary, being able to remove the spark plug recesses ups your compression ratio while decreasing surface area for heat rejection, it makes a ton of sense. I don't think the fuel consumption isn't really because it runs rich, but in a way your statement is right. Because the engine runs like shit at low rpm, they have to try to run it at higher rpms to get it running smoothly, and you get worse fuel consumption as a result. The RX-8 is geared shorter than the S2000 when considering "displacement". I don't get why they can't make a crazy V6 when they make something as crazy as a rotary though. Their K engines were super tiny, and in theory they could've revved the shit out of them no problem. |
#28 | |
PRO86 | WTCC | STL
| Official: Nissan Concept 2020 Vision Gran Turismo revealed, hints future R36 GT-R | vh_supra26 | Other Vehicles & General Automotive Discussions | 42 | 01-17-2016 02:28 AM |
| Fs: Brand New BRZ OLM Vision LED Fog Lights | ucsmfu | Canada Classifieds | 12 | 03-12-2015 05:22 PM |
| I have tunnel vision: 2004+ BMW 330ci ZHP | D4ng3r | Other Vehicles & General Automotive Discussions | 3 | 08-24-2012 08:54 PM |
| Mazda MX-5 Yusho concept introduced at AMI Leipzig | quik1987 | Other Vehicles & General Automotive Discussions | 6 | 06-27-2012 04:36 PM |
| 2010 Mazda Shinari Concept | WingsofWar | Other Vehicles & General Automotive Discussions | 18 | 09-07-2010 06:42 PM |
