Old 07-17-2013, 09:04 PM   #869
pgeist
pgeist's Avatar
Drives: 2013 Black BRZ Limited 6MT
If anyone has experience with the launch control/flatfoot add-on please PM me.. I seem to be having some issues.
Zeta Stage 2 Drop In + Red Silicone Tubing || Zeta SS Cat Back || DC Sports Cat-Delete Front Pipe || Torque Pro + MiniOBD Bluetooth || Fumoto F-108 Drain Valve || Konig Daylite Gold 17x7 +40 14.2lbs || Anarchy Motive Shift Knob
Future: Catted header, OEM Audio+
pgeist is offline   Reply With Quote
Old 07-17-2013, 10:11 PM   #870
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by ML View Post
No AFR is at 12.1 at WOT.
You know the factory sensor cannot read richer than 12.1 right? So your probably richer than that and the sensor is just flat lined. Or are you using a wideband sensor?
Either way it is advisable to reset the ecu when you change maps due to knock correction. It will clear learned corrections and fuel trims that my have stacked up with the previous maps.
The Following User Says Thank You to mad_sb For This Useful Post:
ML (07-18-2013)
Old 07-22-2013, 01:31 PM   #871
D.Scrye
D.Scrye's Avatar
Drives: Hot Lava FR-S
Originally Posted by pgeist View Post
I know when I tried a stock map on my car that has a drop in, cat back, and cat delete front pipe it ran like crap, but once I loaded in the right map with some Timing+ it's just amazing.
I threw a map with Timing+ on it at my car, and now it runs like a champ. Thank you for the advice.
Why not?
D.Scrye is offline   Reply With Quote
Old 07-23-2013, 06:19 AM   #872
Nickse30
Unnecessary Boost
Nickse30's Avatar
Drives: E30 M3, Evo 8mr, GT 86 Aero kit
So what is the difference between timing + and - & Fuel + and -? Whats the most aggressive map a Fuel+ & Timing+?
Im running a 92 Fuel+ and Time+ seems ok deff better than stock
can some one explain this +- thing with the fuel and timing
much appreciated
thanks
N
Nickse30 is offline   Reply With Quote
Old 07-23-2013, 11:48 AM   #873
Mike86
Drives: Scion frs
much appreciated
thanks
N
+ and - is just more or less fuel or more or less timing most aggresive map would be fuel - and timing + play around with the settings to try and find tge map that works best for you!!
Mike
Mike86 is offline   Reply With Quote
Old 07-23-2013, 11:59 AM   #874
nakamur21
Drives: 2013 BRZ limited
Is it really necessary to reset the ECU when switching maps? I only ask because considering that this is a piggy-back device, does the ecu really need the same learning curve as with other mods? I really don't know for sure, so if anyone does I'd appreciate any insight.
nakamur21 is offline   Reply With Quote
Old 07-24-2013, 10:36 AM   #875
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
ECU reset
nakamur21... thanks for the post.
No, there's no requirement to reset the ECU when switching maps. We do all the necessary closed loop tuning so there's no reason/advantage to resetting the ECU.
Please let me know if I can answer any additional questions.
Cheers
Unichip Jack is offline   Reply With Quote
Old 07-24-2013, 01:21 PM   #876
ML
ML's Avatar
Drives: 13 White MT FR-S
Yesterday I randomly started getting a P0102 CEL code(MAF circuit low voltage), and I can feel the throttle jerk. Has anyone else gotten this before? I'm have been trying out the Perrin CAI map because I have a custom made CAI but its based off an Injen intake. I guess I should go back to the Injen maps? Weird that it JUST started yesterday and I have been running the current Perrin map for a few seeks.
Old 07-24-2013, 06:22 PM   #877
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Originally Posted by IceFyre13th View Post
Same question, when will the fa20club CAI maps be out.
BTW, this is the best product I have run that corrects the ECU programming.....I find it more flexible than other "tuners" I have used in the past like HyperChip or Edge products. The expandability is the best part, along with the fact that I can go from one car to the next and all I need to do is load maps (or head down to my local tuner and have a map made).
Complaints, one.......I hate having to agree not to stare at the Flux every time I start the car, why cant it just boot to the last screen it was set at?
Cheers
Any news on the fa20club CAI maps???
IceFyre13th is offline   Reply With Quote
Old 07-24-2013, 09:49 PM   #878
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
Is there anyone in the Northeast US doing Unichip tuning? I live in NH and would be willing to travel to NY, CT, MA or VT for a specialist that could build me a couple of custom maps.
Mark
mtimney is offline   Reply With Quote
Old 07-25-2013, 12:14 PM   #879
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Got a CEL after ~500miles with a Unichip. About to re flash the Unichip after work today and if that doesn't fix it I'll take it into an Autozone or something to get the OBD code. Makes me a little nervous... Hopefully it's just running a little lean or something.
EDIT: have codes, running rich and TDC -- P0172 P117B... Any advice from anyone here?
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 07-25-2013, 02:46 PM   #880
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Are you using a neutral map or have you messed with the timing/fuel at all?
husker741 is offline   Reply With Quote
Old 07-25-2013, 02:53 PM   #881
enwave
enwave's Avatar
Neutral 92 all drop-ins map. Only other "mod" (if you can even call it that) is a K&N drop-in.
Old 07-25-2013, 02:56 PM   #882
husker741
What fuel are you using?
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 03:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-03-2013 11:05 PM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 05:31 PM
