Old 07-21-2013, 03:39 PM   #5811
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Norcalmav23 View Post
Just tried out the new tune! Every tune only gets better. Quick question, how do we switch the racerom "maps". I dug around a little bit but couldn't find a video or how to etc. Thanks!
Pull back on cruise control lever (towards you) and hold it there for a couple seconds until you see the tach point to 1. Then use the cruise control lever to cycle through maps (tap up to go to map 2, up again to map 3, down for map 2 again, etc.)
xjohnx is offline
Old 07-21-2013, 04:31 PM   #5812
Norcalmav23
Drives: SWP Limited manual BRZ
Soooo easy thanks! So map 3 will have the launch control, flat foot shifting, and auto blip right? Now time to put this to use! Thanks again for your help, super easy to cycle between 1, 2, and 3.
Norcalmav23 is offline
Old 07-21-2013, 05:02 PM   #5813
Yruyur
Yruyur's Avatar
Review the release notes on viscontis support page. It should show everything your looking for.
Sent from a Motorola DynaTAC 8000X
Yruyur is offline
Old 07-21-2013, 05:56 PM   #5814
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Got my B4 Stage 2. Thanks John. Feels a little different than my B2 tune. Can't quite place it. Feels good though, even in 90+ heat. I'll run the tune in a little then data log when it's cooler out. Gotta get my logger working though. I'll do a 3rd gear 2000rpm to redline pull on the Interstate. Traction off and map 4. Thanks again!
JimmyMac is offline
Old 07-21-2013, 08:40 PM   #5815
Nardi330
Nardi330's Avatar
Drives: 86
got my latest tune too. thanks heaps John.
Nardi330 is offline
Old 07-21-2013, 08:49 PM   #5816
Norcalmav23
hmmm I cant get my flash to switch to the 4k map. It cycles through the 1k, 2k, and 3k maps really well but it wont go up to the 4k. Am I missing something obvious? I hooked everything up again and ran a query and it confirmed that the new flash was in place.
Old 07-21-2013, 09:07 PM   #5817
Yruyur
Yruyur's Avatar
So when everyone goes to the zendesk portal do you see the section for our cars with videos, tutorials and change logs?
I have been to the site a few times and our section will be missing. I see it now but going back and forth with someone else on the forum that does not see a section for our cars.
http://viscontiflash.zendesk.com/forums
Yruyur is offline
Old 07-22-2013, 11:58 AM   #5818
mobybrz
Drives: White 2013 BRZ
I got my .14b4 tune Sunday (Thanks @Visconti the tune is great BTW ) and noticed the same thing. I sent @Rich@ViscontiTuning a PM asking about that. I figured it was just me. I checked map 3 and it definitely does not seem to have LC on it but besides that I didn't test to hard.
mobybrz is offline
Old 07-22-2013, 12:37 PM   #5819
Rich@ViscontiTuning
Drives: 2012 VW GLI
I'll have John check into this for your guys regarding map 4
Rich@ViscontiTuning is offline
Old 07-22-2013, 12:50 PM   #5820
Norcalmav23
sweet, thanks
Old 07-22-2013, 01:41 PM   #5821
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
@Rich@ViscontiTuning, I've been battling to get LC on both b3 and b4 maps, sent a ticket.
Ryan86 is offline
Old 07-22-2013, 02:15 PM   #5822
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Got my tune last night, installed it this morning. It feels great.
I too only have 3 maps to chose from.
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline
Old 07-22-2013, 02:24 PM   #5823
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
I'm assuming the automatic cars only have one map at this point, correct?
Nightbringer is offline
Old 07-22-2013, 02:34 PM   #5824
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Yes only 1 map for automatics
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
