#57 |
Drives: BRZ Limited, Satin Pearl White, MT
ASL
Who on here knows anything about the ASL and SVC settings?
#58 |
Drives: WR Blue BRZ, 240Z
SVC is a way to balance the various inputs. The mid setting works well for my iPhone. You shouldn't need to stray much from the mid setting. Too high of a setting can cause over modulation and too low of a setting can be too weak to derive meaningful volume.
ASL is really a user preference; some like it some don't. I find it useful and keep it in the high setting.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#59 | |
Are you saying that the settings should be adjusted separately for each mode, AM, FM, SAT, CD? |
#60 |
You can not adjust the AM & FM SVC (I'm not sure about the CD because I've never put a CD in my HU). The SAT & BT have individual setting.
#61 | |
What is BT anyway? |
#62 |
Drives: car
If you want smoother audio sound when you turn the radio up 100%, do the following steps:
1: Go to SVC settings (source volume control) and change it to -10dB to -15dB 2: Turn down the volume on your input device (i.e. bluetooth phone) This eliminates speaker box door rattle and gives a nice crisp sound and perfect bass levels. Your music already has the levels compressed and mixed, why screw with EQ settings and mess up the sound that a dedicated professional had already pre mixed? @ScottKR why do you amp up your levels to +20dB? I notice significant distortion with the bass and trebles overshooting if I have my source volume too high. |
#63 |
BT bluetooth. Duh. :-)
I hardly play music from my phone at all. I'm usually listening to FM and SAT(XM) or even a CD. What should be the settings for ASL/SVC for FM and SAT? |
#64 |
Drives: car
Turn down the dB's on Sat to -20dB IMO, the satellite radio seems to have a much higher input than my BT connected phone and therefore is usually too loud even at less than 30% volume, so cutting the source volume really helps mellow it out.
#65 | |
>> I'm getting more and more confused now on how the unit is supposed to work. |
#66 | |
This unit made by Fujitsu Ten is NOT user friendly at all IMHO. I've seen other units in other type cars that were much more user friendly, had large icons, the sound leveling worked great without all this screwing around. |
#67 |
Drives: car
@ScottKR oh snap, you might be right. SVC must stand for speed volume control, not source volume control! Ha so no wonder I always end up turning my phone's volume up when I'm reaching the highway. So perhaps disregard what I've said previously, I feel like I got my head stuck up my ass.
Either way, the head unit has too much gain on input sources like BT or Aux, and I suggest cutting volume on the device (BT phone or music player) by 50% to get usable performance without distorting volume. |
#68 |
Won't be using the AUX, don't have an iPod to plug into it.
The music I have on my phone I also have on a CD which I have slid into the player. My main issue is the ASL and SVC and how they work in conjunction with AM, FM, SAT. CD. I called Subaru corporate in Cherry Hill, NJ and they weren't much help. All they quoted was info from the manual which I could do myself and the manual isn't much help either. I emailed Fujitsu Ten the maker of the unit and they just referred me back to Subaru or my local dealer. |
#69 |
Drives: '13 BRZ
now if only some1 would show us a good custom setup for the Canadian version of the headunit haha...
#70 |
Drives: '13 CBS BRZ
Used the OP's EQ settings and fader set to R3. A huge improvement. Thank you!
| Motiv Concepts Test Pipe - 2013 Scion FR-S / Subaru BRZ | Enjuku Racing | Engine, Exhaust, Bolt-Ons | 11 | 08-22-2012 08:32 PM |
| 2013 Subaru BRZ Limited Long-Term Test - InsideLine | brianc | BRZ First-Gen (2012+) — General Topics | 0 | 08-01-2012 07:18 AM |
| 2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast | Zgrinch | Scion FR-S / Toyota 86 GT86 General Forum | 124 | 02-21-2012 02:43 AM |
| Road & Track Test Drive Review of 2013 Subaru BRZ | Hachiroku | BRZ First-Gen (2012+) — General Topics | 39 | 12-05-2011 09:45 AM |
