Old 07-17-2013, 11:00 PM   #225
Dezoris
Dezoris's Avatar
Originally Posted by simpleisbest View Post
Found these online from Misumi (Japan's version of McMaster-Carr):
Part Number: SCSPJ20-8
https://docs.google.com/viewer?url=h...%2Fp1_0233.pdf
They're shaft collars are round and seem low profile. I might give them a try once I get the replacement bar from Sam.
Thanks I will try those instead. And for anyone who is using this bar just know if you use any type of aftermarket over pipe the collars won't work.
Sam needs to either integrate the collars into the bar design or at the very least offer lower profile removable collars. Because eventually someone else will complain. (free product improvement advice) The later option would cost next to nothing. Oh and include some instructions!!
Old 07-17-2013, 11:37 PM   #226
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Originally Posted by qoncept View Post
So... can we skip them? I'm fairly certain I can hear them occasionally and I'd rather just take them off than file them if they aren't necessary.
Probably as the Hotchkis bar doesn't use shaft collars http://www.ft86club.com/forums/showthread.php?t=39003
G_Ride is offline   Reply With Quote
Old 07-18-2013, 08:02 AM   #227
celica73
Originally Posted by Dezoris View Post
Sam, I know you work hard etc. But have to just point out the fact that the split collars you are using are grinding into the metal support frame as collar rotates as we discussed and they are much too large to fit any type aftermarket overripe setup.
Most people who have been asking me about the bar, I highly recommend it but am honest about the issues because you never responded.
Does your version of the bar allow the collars to fit on the OUTSIDE of the bushing?
Works great for me. I'm using some steel collars from Amazon (I got mine before the bar came with collars).
Old 07-18-2013, 11:08 AM   #228
G_Ride
G_Ride's Avatar
Which ones did you get from amazon?
Old 07-18-2013, 11:50 AM   #229
celica73
[ame="http://www.amazon.com/gp/product/B0063KYWJQ/ref=oh_details_o07_s01_i00?ie=UTF8&psc=1"]Ruland SP-14-F Two-Piece Clamping Shaft Collar, Black Oxide Steel, .875" Bore, 1 5/8" OD, 1/2" Width (Pack of 2): Amazon.com: Industrial & Scientific[/ame]
The Following User Says Thank You to celica73 For This Useful Post:
G_Ride (07-18-2013)
Old 07-18-2013, 12:18 PM   #230
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
My issue has been the long factory links are causing contact of the body @ full lock. Is anyone else having this issue? I can live with it--just not ideal...
Thx
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 07-18-2013, 12:29 PM   #231
Dezoris
Dezoris's Avatar
Thx
Mine also does this, contacts the control arms. Just grind down the bar.
Not ideal. I am at full lock <1% of the time but still should be corrected.
Old 07-18-2013, 12:32 PM   #232
Dezoris
Dezoris's Avatar
I will have to try that and let you know.
Old 07-18-2013, 12:57 PM   #233
apexaddict
Thx
I just swapped my top mounts yesterday, and I didn't see any contact between the endlink and the body. I know some people have reported this, so I checked it when the strut was out, and saw no scoring or scratching on the unibody from the link. I also turned the wheel from lock to lock when it was in the air - it's close but doesn't touch. I think this is going to vary a lot depending on the parts being used in the suspension and also what the alignment settings are - i.e. a lot of camber/caster at the top mount (thereby moving the whole strut in) would increase the risk of this.
Regarding the collars, I've put mine against the bushings on the outsides (the side facing the strut) and the bar hasn't walked, nor have the collars moved on the bar. It probably shouldn't matter what side they go on, but my original thought was to put them on the outside just so they were easily serviceable. I've driven the hell out of the car, too - I DD it and autocross it pretty heavily.
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
Old 07-18-2013, 01:31 PM   #234
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Thx
Same here. It's more noticeable on the stock wheels than the lower offset autocross set too. Only happens close to full lock so it's not too big of a deal.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 08-14-2013, 01:21 AM   #235
enigma
Drives: Asphalt 86
Ordered my bar about a week and a half ago. Looking forward to getting it on in time for the next local autocross event! Any ETA on when the next batch is going to be available?
enigma is offline   Reply With Quote
Old 08-14-2013, 12:44 PM   #236
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
Shipment is headed my way. Hope to see them late this, or early next week. So you should get it by the end of next week unless the tractor trailer crashes or something.
Sam Strano is offline   Reply With Quote
Old 08-19-2013, 03:27 AM   #237
enigma
Drives: Asphalt 86
Awesome! Looking forward to getting it on!
Old 08-28-2013, 05:18 PM   #238
A_CENT11
Drives: 2013 FRS
Nice! I ordered mustang parts for you a couple years ago, now that I see you have parts for the FRS I have to put a package together! Top notch!!
A_CENT11 is offline   Reply With Quote
Autocross video of Strano Performance Parts FR-S, first time out. Sam Strano Tracking / Autocross / HPDE / Drifting 18 10-02-2014 09:01 PM
Lutz Performance | Performance parts SALE Diego@lutzperformance Engine, Exhaust, Bolt-Ons 8 10-08-2012 10:09 AM
TRD/STI & Performance Parts newft86 Australia Classifieds 31 08-27-2012 07:17 AM
Strano Performance Parts making use of Suspension and Brakes Sam Strano Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-11-2012 07:52 PM
