Old 07-18-2013, 12:50 AM   #1
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
Reporting problems with the car safercar.gov
With all of the "problems" that people have encounter with this vehicle, I thought there would be a ton of reports on safercar.gov.
Unfortunately, either the problems are overblown or under reported, the manufacturer will never push out TSB or fixes if the problems are not reported.
I did a quick search and only 5 reports for SCION FRS and two of them were related to DI
3 Subaru BRZ reports and only one DI problem.
At this rate... we will never get a TSB
I know there is a lot of concern about the DI injectors failing. For all of those that actually had failures, please report it to safercar.gov so the government will force Toyota and Subaru to push out a TSB.
safercar.gov
Please help out the community and report this so a TSB can be put out asap
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 07-18-2013, 12:24 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Unless the DI injectors failing results in the car suddenly going off the road or igniting on fire, then it really isn't a safety issue.
Old 07-18-2013, 12:29 PM   #3
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
@SkullWorks says he did not identify any serious wear on the pump piston shaft and feels that it should not wear out any time soon
supramkivtt2jz is offline   Reply With Quote
Old 07-18-2013, 12:56 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
safercar.gov
You can only report problems to the NHTSA and that website that could cause potential danger and/or destruction of the vehicle. The DI issue isn't hugely widespread and I wouldn't doubt CSGmike already reported his car to that and other people as well.
Reporting Spam ichitaka05 Site Announcements / Questions / Issues 50 04-18-2023 08:13 AM
A few problems...but how bad are they? deedz Issues | Warranty | Recalls / TSB 20 07-21-2013 03:27 AM
Gas Problems Kelbyat07 Issues | Warranty | Recalls / TSB 3 04-20-2013 10:21 PM
No CEL problems here BRZranger Issues | Warranty | Recalls / TSB 41 12-08-2012 02:36 PM
Fresh GBS Mafia Recruit reporting for duty! Shinji2787 BRZ First-Gen (2012+) — General Topics 10 10-23-2012 05:29 PM
