Old 07-16-2013, 08:56 PM   #1
kajun
Drives: Toyota 86 GTS
CEL came on, not sure if it's the same as the big thread
Yesterday I picked up an OBDII bluetooth connector that had been recommended by another 86 owner - I'd been curious about the connector and the data I could get out of it, so I plugged it in & connected to Torque. Played around with it, checked for error codes (none found), and then went out for a short drive to see how the data logging worked (it didn't work).
When I got back to my house, I noticed the CEL & slip lights were both on (!). Not sure what was happening, I turned off the car & pulled out the OBD transmitter.
This morning, I started the car again for my drive to work, and the CEL is still on. The SL is no longer on, and there's no rough idle, so it doesn't look like the issue people are having in the sticky, but given the timing I'm a little suspicious. The one thing I have noticed is that as the (automatic) transmission drops back into 1st around the 10 mph (15-17km/h) mark, there's a little "stutter" from the transmission. No problems when shifting up, or in any of the other gears, just when slowing to 1st I can feel the gear change.
I'll plug the connector in tonight and see what error code is being reported, but just thought I'd float this while I'm at work to see if anyone has experienced something similar.
Any advice from those around here? I haven't accidentally triggered an error code while using the OBD connector, have I?
kajun is offline   Reply With Quote
Old 07-17-2013, 01:03 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You could pull the terminals off the battery to "reset" the car if the code isn't something alarming, if there's really an issue it should show up again shortly.
ineedyourdiddly
kajun (07-17-2013)
Old 07-17-2013, 11:44 PM   #3
kajun
Tried plugging in the OBD connector last night after seeing the code again - couldn't connect for some reason; turned on the ignition, and the light went away. I'll chalk it up as a mystery.
Old 07-17-2013, 11:53 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Maybe its the issue other members have been having? Most of the connectors have horrible connections due to them needing to be re pinned?
Old 07-18-2013, 12:04 AM   #5
SkullWorks
Drives: SSM LT MT BRZ
Huh?
Haven't heard of such an issue, is the supposed problem with a certain brands obd2 connector or are you saying some cars are wired incorrectly?
I have been playing with a Tactrix openport 2.0 cable and various software bits mostly logging CAN data. I have on 2 occasions upset the car where it reported it "lost connection to dash module" never had any issues with the cluster though...cleared it and it would never be an issue again...unless i tried accesing the ecu with outdated SSM2 protocol
Old 07-18-2013, 12:18 AM   #6
FRSBRZGT86FAN
Smile
Originally Posted by SkullWorks View Post
Huh?
Well, multiple people complained of the OBDII connector on the cars were wired incorrectly, causing them to lose or get a bad signal when connecting to the car with an OBDII tool or connector. Like on the user Dezoris's car he had a similiar issue:http://www.ft86club.com/forums/showt...ight=connector
Old 07-21-2013, 11:37 PM   #7
kajun
Hmm, hadn't seen that thread/issue before. I'll try out the connector on another car and see if it's the connector or the car that's at issue.
D-4S Thread WingsofWar Engine, Exhaust, Transmission 85 03-31-2020 05:25 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 01:24 PM
AZ bs thread sfwg Southwest 185 09-11-2012 04:11 AM
The "if you wanna kiss the backside of white musicians make a thread about it" Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 8 12-19-2011 08:59 PM
