Old 07-17-2013, 11:38 AM   #15
thill
Originally Posted by f0rge View Post
There's no way Mazda can afford to build this car, they're barely hanging on these days after the split from Ford. They need another larger company (Fiat?) to share the chassis with and I'm not sure anyone else is looking to break into this market.
The only reason we're getting a new Miata is because of Alfa.
Might also be a tough sell put up against the new mustangs and camaros which will have significantly more power.
Well you make a good point. Mazda is doing better (actually profitable):
http://www.autonews.com/apps/pbcs.dl...EM01/130409934
But, a lot can happen. Mazda will need the 6 and 3 to be a hit like the CX-5 was. If the 3 is a big hit (and all indications are that it is at the top of it's segment) we could see another RX. But like I said, Mazda would be wise to follow what Tada did with the FT86 and make is a more affordable sportscar.
Old 07-17-2013, 12:40 PM   #16
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Originally Posted by LSxJunkie View Post
You think by then they'll figure out how to make a rotary that doesn't spit out apex seals?
Or burn unnecessary amounts of oil, especially with emissions regulations they really need to develop the engine.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
wparsons (01-12-2014)
Old 07-17-2013, 01:23 PM   #17
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Considering the 1.3L RX-8 only got 16/22mpg with 250hp, i'm doubting the 1.6L with 300hp will get much closer to the 30mpg mark. Rotaries have always been too thirsty for my particular tastes, maybe i'm just a cheap skate
Trashed675 is offline   Reply With Quote
Old 07-17-2013, 01:57 PM   #18
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
How do you guarantee your sports car will be a sales failure?
Answer: put a rotary in it!
PRO86 | WTCC | STL
The Following 6 Users Say Thank You to rice_classic For This Useful Post:
Dimman (07-22-2013), dsmx17 (07-18-2013), FnFast (07-22-2013), FRSBRZGT86FAN (01-16-2014), NWFRS (01-12-2014), WingsofWar (07-22-2013)
Old 07-22-2013, 01:13 PM   #19
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
If it comes in 2017 then my guess is $45K and no turbo.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
The Following User Says Thank You to Rampage For This Useful Post:
FnFast (07-22-2013)
Old 07-22-2013, 01:29 PM   #20
serialk11r
Drives: '06 AM V8V Coupe
If it passes emissions on 2017 that means it can't burn oil...they'll need to sort out some ceramic seal magic to make that happen.
Old 07-22-2013, 02:22 PM   #21
n2oinferno
Praise Helix!
n2oinferno's Avatar
They ought to just make a deal with GM and source out a bunch of LS engines. More power and better fuel economy. Best modification you can make to a rotary car!
The Following 2 Users Say Thank You to n2oinferno For This Useful Post:
Dimman (07-22-2013), OnkelC (08-25-2013)
Old 07-22-2013, 03:43 PM   #22
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
a rotary that meets todays global emissions is magic on its own. but i have faith in Mazda that their team found good solutions to horrible fuel and oil consumption that plagued the previous rotaries.
WingsofWar is offline   Reply With Quote
Old 07-22-2013, 11:32 PM   #23
Dimman
Kuruma Otaku
Dimman's Avatar
The issue with the oil consumption isn't that it's a problem, but that it is a 'solution' to the design limitations of the rotary.
The other problem is that they are inherently compression limited, and have poor combustion chamber shape. So the poor fuel efficiency is also a 'solution'. Running pig rich to get even fuel
dispersion.
However...
If they take a radical new approach to fight the natural weaknesses, who knows? But when you start hearing about experiments with laser ignition, well it's either outside-the-box thinking or crazy desperation with no regards to reliability (still...).
Mazda, just make a coupe that is as sexy and light as an FD and put a normal engine in it.
Because titanium.
Old 07-22-2013, 11:44 PM   #24
reni
Nobody beats the B[I|R]Z
reni's Avatar
Drives: shopping cart i stole from walmart
How do you guarantee you'll look like an ignorant retard on a car forum?
Answer: post something stupid about rotaries
The sales of the 1st gen RX-7 were nearly half a million
https://en.wikipedia.org/wiki/Mazda_RX-7
"The [Subaru BRZ] feels as trim, nimble, and athletic as the great sports coupes of the pre-bloat era."
-- Car and Driver, June 2012
"And I thought to myself, I'm not going to die, because this is annoying"
-- Niki Lauda
reni is offline   Reply With Quote
Old 07-23-2013, 12:04 AM   #25
Dimman
Kuruma Otaku
Dimman's Avatar
And they sold most of them before people knew better. Notice the last two generations combined sold less than the first. Word got out.
Because titanium.
Old 07-23-2013, 12:33 AM   #26
reni
reni's Avatar
Rotaries had been on sale for nearly a decade when the RX-7 came out, and over 15 years in other countries. So if it was a matter of "getting the word out" the SA/FB RX-7 wouldn't have had such a successful run for so log, so that argument doesn't hold water.
The 1st gens and non-turbo 2nd gens have proven to be pretty solid for reliability.
The 2nd gen onwards became significantly more expensive than than the original during a time when sports car sales were declining in general (by the mid/late 90s, the miata was about the only Japanese sports car still for sale in the US)
Facts good, ignorance bad...
-- Niki Lauda
Old 07-23-2013, 05:50 AM   #27
serialk11r
dispersion.
However...
Laser ignition is pretty smart, I actually want to see it succeed. Spark plugs obviously have more problems in a rotary where they are in a recessed chamber, but laser plugs could help oversquare engines by allowing multiple ignition points without the bulk of multiple plugs. Igniting the mix early to get complete burn is horrible for efficiency; you probably lose more power to that (slow combustion) at high rpm than hypothetically recovering all blowdown losses.
For a rotary, being able to remove the spark plug recesses ups your compression ratio while decreasing surface area for heat rejection, it makes a ton of sense.
I don't think the fuel consumption isn't really because it runs rich, but in a way your statement is right. Because the engine runs like shit at low rpm, they have to try to run it at higher rpms to get it running smoothly, and you get worse fuel consumption as a result. The RX-8 is geared shorter than the S2000 when considering "displacement".
I don't get why they can't make a crazy V6 when they make something as crazy as a rotary though. Their K engines were super tiny, and in theory they could've revved the shit out of them no problem.
Old 07-23-2013, 11:56 PM   #28
rice_classic
PRO86 | WTCC | STL
Official: Nissan Concept 2020 Vision Gran Turismo revealed, hints future R36 GT-R vh_supra26 Other Vehicles & General Automotive Discussions 42 01-17-2016 02:28 AM
Fs: Brand New BRZ OLM Vision LED Fog Lights ucsmfu Canada Classifieds 12 03-12-2015 05:22 PM
I have tunnel vision: 2004+ BMW 330ci ZHP D4ng3r Other Vehicles & General Automotive Discussions 3 08-24-2012 08:54 PM
Mazda MX-5 Yusho concept introduced at AMI Leipzig quik1987 Other Vehicles & General Automotive Discussions 6 06-27-2012 04:36 PM
2010 Mazda Shinari Concept WingsofWar Other Vehicles & General Automotive Discussions 18 09-07-2010 06:42 PM
