Old 07-16-2013, 09:45 PM   #85
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Originally Posted by chuchutrain View Post
Thanks for this! I really want to get the enkei rpf1's in black and was looking for someones look to replicate on my Firestorm.
Sorry, I'm a newb with wheels. I'm not sure I want to lower my car (mostly because of in/declines of my daily drive and frequented neighborhoods). Would I be able to fit these tires with no issues (rub, etc) on stock springs?
I understand the terms like camber, etc. but I don't know when it applies. Is it only when getting really big wheels and lowering?
I have this set up on stock springs. The rpf1 17x9 +45 with 245/40/17 Bridgestone potenza re11s
Lee358 is offline   Reply With Quote
The Following User Says Thank You to Lee358 For This Useful Post:
chuchutrain (07-16-2013)
Old 07-16-2013, 09:50 PM   #86
chuchutrain
Drives: Firestorm
No rub, nothing? And pretty clean look? Better yet, can you post some pics?
Sent from my LG-E970 using Tapatalk 4 Beta
chuchutrain is offline   Reply With Quote
Old 07-16-2013, 09:52 PM   #87
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Without camber they will poke a little and you can't dial in any negative camber as the tyre is too close to the std strut. But they effectively just fit.
86•BRZ is offline   Reply With Quote
Old 07-16-2013, 09:57 PM   #88
chuchutrain
Drives: Firestorm
Camber is the wheel axis angle relative to the ground right? Would 17x8 or 17x8.5's with less than +45 offset be better?
Old 07-17-2013, 12:09 AM   #89
Lee358
Lee358's Avatar
Here are some pictures for you if you want anything more feel free to ask i love taking pictures of my car!
Name:  ImageUploadedByTapatalk 21374034031.136708.jpg
Size:  214.1 KBName:  ImageUploadedByTapatalk 21374034065.050557.jpg
Size:  247.1 KBName:  ImageUploadedByTapatalk 21374034081.734003.jpg
Size:  83.8 KBName:  ImageUploadedByTapatalk 21374034105.583746.jpg
Size:  92.1 KBName:  ImageUploadedByTapatalk 21374034149.050226.jpg
Size:  113.1 KBName:  ImageUploadedByTapatalk 21374034178.333570.jpg
The Following 2 Users Say Thank You to Lee358 For This Useful Post:
chuchutrain (07-17-2013), David L (11-12-2017)
Old 07-17-2013, 12:42 AM   #90
chuchutrain
Drives: Firestorm
Man. That looks great. And there's no rubbing, it just looks super close? Do you recommend a +38 if they make them?
Old 07-17-2013, 01:18 AM   #91
Squishy
Drives: 2013 WRB BRZ
The only +38 I ever saw in RPF1's were a limited run of 17x8.5's and they list them but have none on the market I know of except that limited run.
I have 17x9 +35 and it will rub up front unless you get some negative camber (I am running coilovers with camber plates so it fits just right). In rear the 17x9 +35 fit flush already on 245/40/17 all around.
Squishy is offline   Reply With Quote
Old 07-17-2013, 08:40 AM   #92
N_I_N
N_I_N's Avatar
Drives: FR-S [Hot Lava]
@chuchutrain
A 17x9 +45 won't rub except on a full lock as I mentioned above. A +35 would be like adding a 10mm spacer to a +45 which is what my car has on it in the photos on the earlier posts. +35's would be pushed out toward the fenders. The photos where the car is in the garage not in the driveway shows what I'm talking about. I have no idea about the 8 inch wide wheels...
N_I_N is offline   Reply With Quote
Old 07-18-2013, 03:37 AM   #93
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
yes, one way of putting it..
they only come in 17x8+45 not 8.5,
this would be the best size if you are not modifying suspension at all.
you could go 17x8 +35 if you want to add a little front camber, it will both be more functional and look like it fits better.
Old 07-23-2013, 05:07 PM   #94
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
Wheels
Are your hubs 5x100? or did you convert them?
Wilso is offline   Reply With Quote
Old 07-23-2013, 05:24 PM   #95
Lee358
Lee358's Avatar
I can only speak for myself but i am 5x100 im almost 100% sure tho everyone else in this thread is also 5x100
Old 07-23-2013, 05:29 PM   #96
Wilso
So I'm assuming your wheels were special ordered then? I can't find 18x9 or 17x9 for the RPF1s anywhere
Old 07-23-2013, 05:50 PM   #97
Lee358
Lee358's Avatar
17x9 +45 tirerack or any normal wheel store... +35 special order from a vendor on the forum.
Old 07-24-2013, 03:57 AM   #98
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
17x8 & 17x9 in both +35 and +45 are present in the Enkei catalogue
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei Kojin 17x9.0 +45 Clipdat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-02-2016 04:18 PM
