Old 07-16-2013, 08:45 PM   #155
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
If you're getting whiffs of E85, it's most likely dripping out very slowly and drying up by the time you have the hood up. Before I sprung the manly leak, I kept getting whiffs of it and didn't see anything. It was only after a few 3rd gear & 0-100 pulls that the floodgates finally opened up. No squirting but steady dripping stream of E85. Good thing I had a bunch of microfibre towels in the glovebox after hearing about the initial leaks.
My top clamp seems to be holding (it's the stock T clamp, I've screwed it down till it can screw no more) but the bottom one I've added the stock T clamp under my busted worm drive clamp. No more E85 smell so far. I'll probably add another T clamp to the top just to make doubly sure.
As for the hose clamp vs hose itself, the hose definitely could be better. The stock hose was nice and thick with a smaller inner diameter. There was hardly any force exerted from the clamps - the hose itself stuck to the metal pipe like a limpet and I'm sure many of us had to cut it off.
enouf is offline   Reply With Quote
Old 07-16-2013, 09:08 PM   #156
Yruyur
Yruyur's Avatar
Guess you could draw on a paper towel with marker. Wrap a small piece of it around the joints. If the ink smears then its getting wet. Kinda like the cell phone water indicators.
Crossing my fingers things are still dry.
Still dont have the tune though.
Sent from a Motorola DynaTAC 8000X
Old 07-16-2013, 09:23 PM   #157
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Can you take pictures of your setup?
post_break is offline   Reply With Quote
Old 07-16-2013, 09:31 PM   #158
enouf
Mr. Grumpy
enouf's Avatar
I'll get some photos after work, especially of the busted worm drive clamp.
With the stock rubber hose, you can see when it bulges that the clamp is good and tight. With the fabric outer sheath, you don't really see much until you clamp the shyt out of it.
Also you US guys have that nifty metal fitting at the top so there shouldnt be any leaks there - we Aussies have to worry about both the top and bottom leaking
Old 07-16-2013, 10:33 PM   #159
post_break
post_break's Avatar
I'm going to need some clarification on that. Can you highlight which parts you're talking about using the photos I took?
Are you saying you have a clamp on the engine side as well as the fuel rail side?
Old 07-16-2013, 11:39 PM   #160
enouf
Mr. Grumpy
enouf's Avatar
Yep that's correct. Our stock hose is clamped on both ends. The plastic clip + metal hex fitting doesnt lock onto our metal tube end properly on the engine side.
Old 07-17-2013, 01:55 AM   #161
JiB
JiB's Avatar
Drives: GT86
yeah, our metal tube is half the length of your spec
JiB is offline   Reply With Quote
Old 07-17-2013, 09:02 AM   #162
enouf
Mr. Grumpy
enouf's Avatar
Here's some photo overload of my fuel lines - first 4 are of my initial setup and the overtightened screw clamp. Next 2 is the double clamped setup and last photo is the other high pressure line with stock hose and clamp.
Still don't like the screw clamps though, they don't clamp evenly around the hose. The stock clamps are pretty darn good so I'll be ordering these:
http://www.ebay.com.au/itm/2x-Mini-F...16f7b4f&_uhb=1
Old 07-17-2013, 12:24 PM   #163
Rich@ViscontiTuning
Drives: 2012 VW GLI
Did you guys get a chance to see our test rig that has the Vortech kit and FlexFuel installed? 290+whp/200+wtq ... on pumpgas! The gauge was reading like e10! It's like these kits were a match made in heaven
[ame]http://youtu.be/8irVuFpvZ4w[/ame]
Rich@ViscontiTuning is offline   Reply With Quote
Old 07-18-2013, 11:56 AM   #164
Visconti
Drives: 05 STi
I haven't had any complaints but if there's a better clamp ill use it.
No matter what clamp you use make sure the line is on good.
John
Visconti is offline   Reply With Quote
Old 07-24-2013, 07:47 AM   #165
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Mine is leaking as of this morning, came outside to a slightly soaked hose. Trying to adjust and fix.
Sent from my SGH-M919 using Tapatalk 4 Beta
mikalem is offline   Reply With Quote
Old 07-24-2013, 07:48 AM   #166
Visconti
Drives: 05 STi
Make sure the line is done a good amount and tighten that clamp.
You don't want to drive around with a leak.
I'm going to have update ready to ship out to everyone in a few days
Old 07-24-2013, 07:50 AM   #167
Visconti
Drives: 05 STi
Here it is.. No more clamp
Old 07-24-2013, 08:16 AM   #168
mikalem
mikalem's Avatar
Attachment 45494
Sweet, the sooner the better
campaign: ban jv, diy, e85, fuel leak, kit, laughing to the bank, oh lord jesus its a fire, visconti, viscontifried, viscontinued
Flex fuel testing Dynotronics1 Southwest 5 06-22-2013 03:27 PM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 11:04 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Cheap flex fuel? nix Engine, Exhaust, Transmission 1 05-11-2013 04:05 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
