Old 01-04-2012, 01:32 AM   #295
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
Originally Posted by AeroWRX View Post
This car will be dominating when corning. But you will kick urself when U get dusted by a 350z in a straight line.
Lol that statement right there is one of the reasons I was considering getting a used 350z. But by the time I am able to get one I may as well just pick up the 86 since the one I am currently eying definitely will sell soon.
00NissanNinja is offline   Reply With Quote
Old 01-04-2012, 12:01 PM   #296
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by Homemade WRX View Post
...then what am I missing? Enlighten me
I don't think you're missing anything, just maybe that you are dead-set on a turbo so arguments are falling on deaf ears.
To each their own.
Because titanium.
Old 01-04-2012, 12:29 PM   #297
DMDZK
DMDZK's Avatar
Drives: 2007 Cayman
I am torn between both sides honestly...
I'm completely content with 200hp NA. I think it will be a blast to drive much like the s2000 and Miata are known to be. Look how infrequently you see turbo'd s2000's, seems like most owners are more than happy with NA.
I agree that 200hp is comparatively low, at least when weighed against other offerings. In a perfect world I would love something a bit closer to the s2000. 225 - 250hp would be amazing. Sadly I doubt we'll see anything near that even with a few thousand in bolt on mods.
Is forced induction the answer? maybe for some, I will live happily with 200hp and whatever I can squeeze out with I/H/E + tune. As much as a sub 6 or even near 5 sec 0 - 60 sounds great, It won't will benefit me enough to justify the expense.
With a factory turbo/supercharger I would expect this car's MSRP to jump 2 - 4k which would hurt my chance's with it since I want a well equipped model and over 30k is too much for me to justify on a car with my income level.
DMDZK is offline   Reply With Quote
Old 01-04-2012, 12:30 PM   #298
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
Actually, I DON'T want to turbo this car....for once.
I just find so many naive comments about turbocharging on this forum that it's almost disturbing, hence I was/have been playing the devil's advocate. I really wonder if any of the people complaining about them have actually driven a well set up turbo car. I'm going to assume not.
I am actually planning to do NA development on this engine upfront as I really do suspect the factories will release FI models, making early FI work seem almost trivial.
To each their own.
Homemade WRX is offline   Reply With Quote
Old 01-04-2012, 12:37 PM   #299
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
A supercharged TRD FR-S
240-250 hp
190-195 tq
2,775 lbs
$27,000(if base is $22,500) add $3,000 for the TRD lip kit.
Wouldn't need brake upgrades since the brakes is straight from a WRX. This car would be EPIC!!!!
SUB-FT86 is offline   Reply With Quote
Old 01-04-2012, 02:13 PM   #300
Dimman
Kuruma Otaku
Dimman's Avatar
Fair enough.
My turbo experience comes from A70 Supras. The most responsive being a 1JZGTE powered twin turbo JDM car with opened up intake and exhaust, as well as parasitic (power-steering) and inertial (clutch, driveshaft) reductions. It is basically a short-stroke 2JZGTE (for those that don't know) and the factory twins are each about the size of a small hamster with ceramic wheels. It was responsive as hell, but there was still a split second of lag.
Because titanium.
Old 01-04-2012, 03:19 PM   #301
Levi
Drives: Toyota
Yes 200 PS is little, so I'll be getting 250 PS with NA mods, surely an engine kit. But kick-ass turbo would also be nice, only there are other cars for this, and the "first" car is going to be it. I don't see the AS1 being the only car in ones garage, that is why it is important for it to be affordable.
Levi is offline   Reply With Quote
Old 01-04-2012, 09:40 PM   #302
fatoni
Fair enough.
i dont think youre talking about turbo lag
Old 01-04-2012, 09:46 PM   #303
Dimman
Kuruma Otaku
Dimman's Avatar
Depends on the definition of 'lag'. The delay between pressing the throttle and getting the power you want/expect. It's from needing the exhaust gas to spool the turbos to their rpm, then for the compressor to pressurize the intake side.
So even at mid-high rpm, there is still a delay between going full throttle and getting full boost.
This is something that a lot of people who just say "But the BMW 335 makes full boost at just over idle!" don't seem to fully understand.
Because titanium.
Old 01-05-2012, 12:34 AM   #304
Homemade WRX
yes, it's called transient response (often mistakenly called 'lag') and it does decrease with engine RPM...as well as other changes that can be made. You get the same effect when you put larger cams on an NA engine or a large plenum intake manifold (for power).
Response isn't shown on a typical dynograph but 'lag' is.
You may also want to check out some newer turbo tech. Both turbine and compressor 'response' technology have made large gains since Toyota use to poke around with turbos. Nothing you can do about gas pressurizing, as it will always be there, but reductions in weight and geometry gains make for spool up at lower exhaust pressure = faster spool up on the compressor = shorter transient response. The better geometry also means that they flow more for the same given transient response or vice versa.
Old 01-05-2012, 12:02 PM   #305
Dimman
Kuruma Otaku
Dimman's Avatar
For the time, those two tiny ceramic turbos were probably the best responding factory turbo system out there. I would have loved to be able to put some same-sized, better flowing, more efficient, variable geometry, titanium-alumide turbines on it.
Le sigh...
Because titanium.
Old 01-05-2012, 12:25 PM   #306
miata
Drives: 2006 Miata 5 spd
I like naturally aspirated engines because turbo will die when the car is out of warranty. All snails die. I would have been happier with a 1.8L. 200hp engine.
miata is offline   Reply With Quote
Old 01-05-2012, 02:40 PM   #307
duffman13
Auto-Xer
Drives: 2004 Acura RSX Type-S
Scooby says they could see it revving to 9k with proper valve springs.
If that's the case, gimme some cams and valvesprings and I'll take it that way. I'm driving a VTEC motor now, I don't touch anything below 5k when I'm driving hard anyway.
duffman13 is offline   Reply With Quote
Old 01-05-2012, 04:02 PM   #308
arghx7
Drives: car
I would be surprised if the intake ports would flow above the stock red line. If you port it out there is a potential for driveability issues due to a lack of charge motion and combustion instability. It's hard to say for sure though, so somebody will have to get in there and try.
Happy Thanksgiving!!! S2KtoFT86 Scion FR-S / Toyota 86 GT86 General Forum 11 11-27-2010 07:01 AM
Happy Holidays, all White Comet Off-Topic Lounge [WARNING: NO POLITICS] 4 02-12-2010 08:45 AM
