Old 07-16-2013, 12:10 PM   #113
qoncept
qoncept's Avatar
Originally Posted by Perihelion View Post
For some reason, my phone never asks for a passcode... this may be related to the constant disconnecting
The code is probably 1111 or 1234, and a lot of BT will automatically try those without prompting.
qoncept is offline   Reply With Quote
Old 07-16-2013, 12:25 PM   #114
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
I mean I changed the code on the Headunit from 0000 to xxxx, but regardless the HTC One never prompts for a code.
Perihelion is offline   Reply With Quote
Old 07-16-2013, 12:31 PM   #115
qoncept
qoncept's Avatar
Oh.. well, the code is just to pair. Once it's paired you can connect without the code.
Old 07-16-2013, 01:13 PM   #116
Perihelion
Perihelion's Avatar
But I'm never asked for the code to pair either. That's my point, this could be why I keep getting disconnected, or maybe not, idk
Old 07-16-2013, 02:13 PM   #117
Be-Are-Zee
My code was 0000
Be-Are-Zee is offline   Reply With Quote
Old 07-16-2013, 02:15 PM   #118
Be-Are-Zee
Do you have the Bluetooth list of devices up on your phone when the HU is trying to pair?
Some phones also have a discovery mode that needs to be turned on.
Old 07-22-2013, 03:41 PM   #119
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
My Hands Free Voice Command feature stopped working 4-5 days ago
Hoping there's an easy fix for this mentioned in the manual.
Old 08-01-2013, 06:25 PM   #120
kuhlka
Drives: 2013 BRZ Limited AT
Originally Posted by tomkozski View Post
Per the owner's manual for the nav system, real time traffic data is derived from the FM radio, using RDS. Owner's manual calls it the Traffic Message Channel (TMC). So even without a XM subscription, traffic should still continue to work.
When does it work? I never get traffic warnings in Greater Baltimore or Toledo and none whatsoever on the entire freeway/turnpike trip to and from those two cities. Due to this fact, I won't be subscribing to satellite radio + traffic. It's a waste of money.
kuhlka is offline   Reply With Quote
Old 08-01-2013, 06:38 PM   #121
qoncept
qoncept's Avatar
"RDS-TMC is a low-bandwidth system, with each RDS-TMC message comprising 37 data bits sent at most 1–3 times per second, using a basic data channel primarily designed for FM radio tuning and station name identification."
[ame="http://en.wikipedia.org/wiki/Traffic_message_channel"]Traffic message channel - Wikipedia, the free encyclopedia[/ame]
Old 08-02-2013, 01:04 PM   #122
kuhlka
That doesn't mean it works. Unless you're in LA where traffic is heavily monitored, I have yet to see mine work reliably on the east coast. Many times I'll get a traffic alert when there is no traffic. When there is a massive traffic jam, no alert... Considering I have all of the alerts enabled in settings, I think the traffic 'feature' is BS.
Oh, and the Route 200 toll road north of DC isn't even on the map. Makes me wonder if we're running 2010 maps because it's been there since at least 2011.
Old 08-02-2013, 07:58 PM   #123
qoncept
qoncept's Avatar
If you're getting traffic alerts I think that pretty much proves it "works." If you aren't getting good ones that's low quality data. Mine works about as well as you could expect in Iowa. That is to say it knows where most road construction is and that's about it.
How good are Subaru's gadgets - nav, bluetooth, satellite radio, etc. Turbowned BRZ First-Gen (2012+) — General Topics 53 10-01-2012 01:40 PM
Radio, Iphone?? Radio cuts out when surfing the web Fugazi Electronics | Audio | NAV | Infotainment 5 07-30-2012 12:24 PM
Aha Radio in the Subaru BRZ Chronogps BRZ First-Gen (2012+) — General Topics 3 02-21-2012 06:52 PM
Subaru BRZ and Toyota 86 appreciation video thread Nostalgia1987 AUSTRALIA 2 01-11-2012 06:25 PM
