Old 07-09-2013, 11:28 PM   #2605
Marrk
Drives: Honda Fit
^^In terms of idle and engine performance, is it truly fixed, or is it merely better than it was?
Marrk is offline   Reply With Quote
Old 07-10-2013, 12:33 AM   #2606
acro
Drives: GT-86
Problem fixed with the ecu flash no problems
acro is offline   Reply With Quote
Old 07-10-2013, 12:09 PM   #2607
ftc~brz
Done
Drives: WRB BRZ
I would say fixed for me. As traumatic as the whole experience was the only dips I get now are shutters from ac or a little idle bounce at a stop when it's doing its thing injector wise. I've since modded and tuned without a hiccup so far. I would be lying if I said I wasn't still afraid of all of it coming back. Once you've posted in this thread the thought is always there in the back corner of ones mind. But I have gone too far with changes to look back.
I found a great mechanic that is worth the drive and will no longer visit a dealer for anything. I had faith in them with my ecu issue but lost it with minor maintenance.
ftc~brz is offline   Reply With Quote
Old 07-10-2013, 03:15 PM   #2608
Marrk
Drives: Honda Fit
^^I haven't seen your posts in a while, so I may have missed something. Did the dealer resolve your ecu/idle issue, or did your mechanic come up with the remedy?
Thanks.
Old 07-10-2013, 03:38 PM   #2609
ftc~brz
Done
Drives: WRB BRZ
Thanks.
yes it has been a long time!!! 2 sets of codes, new cams and valves, more codes then ecu flash. After the flash all was well so the dealer resolved that and subaru was very understanding. I have since done some things and had a tune and still no issue. Hit 13k last night on my way home from work!
Old 07-11-2013, 12:59 AM   #2610
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by Turkish View Post
I took mine to the dealer two days ago for a rough idle with CEL/SL this last Monday. Turkish, BRZ, 5600 mi, in shop, 6070XX. The service rep at the dealer said they had narrowed it down to the cam shaft timing, but they weren't sure which one yet.
See if you can find out which ECU you have...the number ends in 10, 11, or 12 (being the newest)
Old 07-12-2013, 08:59 AM   #2611
m3gaTR0N
m3gaTR0N's Avatar
Drives: Toyota GT86
Hey guys, I don't really know if this is a problem, but a lot of users are complaining about rear axels which are braking after some period.
I am doing some slalom and sporty driving, so mine broke up at 6,500km.
m3gaTR0N is offline   Reply With Quote
Old 07-12-2013, 10:50 AM   #2612
Marrk
Drives: Honda Fit
Are you running a stock powertrain? Stock rear suspension? Stock rims, tires, spacers? Alignment?
Just tryng to get the complete picture.
Thanks.
Old 07-12-2013, 07:06 PM   #2613
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
Looks like I will have to put off my Innovate supercharger install. My CEL just came on with error codes of P0303 and P219A. I pulled them with the torque app on my phone so I am not sure how accurate they are. Will be going to the dealership tomorrow hopefully it wont take to long to fix. Engine also seems to be running really rough and making a lot of valve train chatter. Does not sound good..
MattF is offline   Reply With Quote
Old 07-15-2013, 12:22 PM   #2614
Mkok
I got the check engine light and traction control light at about 3000m. I took it to the dealer and they said it was because my gas cap was lose. I know that makes sense for the check engine light, but the traction light in combination???
Mkok is offline   Reply With Quote
Old 07-15-2013, 12:43 PM   #2615
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
I usually check the gas cap first thing when the CEL comes on and when I take in to the dealer to look at it I tell them that I checked it. Keep an eye on it, if it doesn't come back on you are lucky, but if it does take right back to the dealer.
Turkish is offline   Reply With Quote
Old 07-15-2013, 03:04 PM   #2616
Mkok
CEL
I got the check engine light and traction control light at about 3000m. I took it to the dealer and they said it was because my gas cap was loose. I know that makes sense for the check engine light, but the traction light in combination???
What I am curious about is would - COULD a loose gas cap make the traction light come on??? (in combination with the CEL)
Old 07-15-2013, 11:32 PM   #2617
WytKnight
Drives: 82 MkII Supra
Are these cars throttle by wire? If so TC could get disabled as a safety feature. In the ODB specifications if certain types of faults are detected the engine program switches to a limp in mode set of static parameters killing automatic controls like TC. Cars that are throttle by wire give TC the ability to close the throttle plate regardless of what the accel pedal is doing. closing the throttle plate to reduce engine power is preferred than to killing an injector or spark because it messes up your emissions.
A loose/missing gas cap usually triggers a EVAP Large leak code. This is considered a severe fault as you have a leak severe enough to possibly allow raw fuel out. Ford years ago added a second EVAP test valve to the gas filler that triggered a gas cap light on the dash.
When I was a mechanic I would get almost 1 case a month for engine code diag due to gas caps being left off or loose. It happens..
WytKnight is offline   Reply With Quote
Old 07-16-2013, 05:27 PM   #2618
grodenglaive
Drives: asphalt FR-S
had the re-flash done a week ago. So far-so good.
grodenglaive is offline   Reply With Quote
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
