#225 | |
Drives: 13 Asphalt FRS AT
Sent from my Nexus 7 using Tapatalk 2
#226 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Turns out the RallyX car unexpectedly needs a full brake job... so it will be a bit longer for the BRZ to go under the knife.
Oh well. Guess that means I can wait longer for the Nameless header...
#227 |
Drives: 2013 White Out FR-S
#228 | |
WUB WUB
Drives: 2013 Firestorm
definitely will. going to try and send one tomorrow. Need to go on the site to remind myself how to log, then i'll send it. edit: perhaps i'll go make one now. the roads are empty.
#229 |
use the guide i sent you to setup the logs how i want them done.
#230 |
WUB WUB
I couldn't find the guide, so I tried using tips from ecutek.com to make good logs. We'll see if they work for you. (hope they do!)
#231 |
Got my SC coming next week, bought it from FT-86 SpeedFactory, it's already shipped and be here Wednesday
(thanks SpeedFactory)I will be doing Flex Fuel setup, so it might be couple of weeks before it's all installed and figured out.
| The Following User Says Thank You to DriftEm For This Useful Post: | whataboutbob (07-14-2013) |
#232 |
WUB WUB
when you work on the car, either take breaks, or have some awesome pain meds ready. back is sore as shit now. too long bent over the engine. lol
#233 | |
Thupercharged
I've driven cars up on ramps just to not bend over so much working in the engine bay
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#234 |
WUB WUB
damn. i'm 6', I can't imagine how bad it'd be for you. we did this at my apartment complex, and I don't have ramps that we could have used. wouldn't have worked anyways, since john is about 5'8. he wouldn't have been able to reach. lol
#235 |
I've only ran one data log (might get another this evening). I noticed my peak boost was at 5.3psi. Is that all the stock MAP sensor can read?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#236 |
Old...
Drives: Subaru
I feel ya! The engine is below your knees when the car is on the ground.
#237 |
Drives: 2013 SWP BRZ
The best advice I can give is take your time. Give yourself adequate time to install it so you aren't rushing for a "deadline" to finish. Thats usually when crap goes wrong because you are trying to finish up and miss something in the directions or something along that lines.
I took off work friday to install it. I got the supercharger thursday night, and installed my fuel pump and 95% of the supercharger from 7 oclock to about 1:45 that night haha. That was with me just taking my time, not worrying if i finished up or not, reading the directions a bunch of times, etc. The fuel pump took me longer than the sc install because I took a break and also wanted to make sure I did it correct the first time around. I also had to pull it back out because I forgot to put the stupid rubber piece on the bottom of the pump lol. I took a LOT of pics for that fuel pump install, I will be doing a proper write-up on it because the DIY on this site leaves a lot to be desired. |
| The Following User Says Thank You to xxscaxx For This Useful Post: | No Limit Motorsport (07-15-2013) |
#238 | |
I Love custom Turbo kits
Drives: Limited BRZ
Thanks!!
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
