Old 07-10-2013, 07:30 AM   #85
WRXGuy1
WRXGuy1's Avatar
Drives: 2013 WRB BRZ Premium 6MT
Originally Posted by PMPB View Post
But how about when it's dark HOURS before sunset because of a big storm, should it still be in 'day' mode?
Or when driving through long dark tunnels.
2013 BRZ Premium WRB MT - Picked up 5/31/12
WRXGuy1 is offline   Reply With Quote
Old 07-10-2013, 06:07 PM   #86
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
LCI models did come with upgraded LED Angel Eyes, M3's never had LED's
but it's easy to replace the bulb with an LED upgrade
http://www.bimmian.com/WeissLicht-LE...om-bimmian.com
That's the one I was thinking of. I installed CCFL halos on my E46, which ran great in the summer and took up to 45 minutes to warm up turn on in the winter. They were a real pain in the ass.
I just want to know if there's some way to retrofit the boomerang to burn brighter (especially without baking it). CCFL might actually work well in that application since it's better insulated, from my experience it's the inverters that crap out first, though.
DoomsdayJesus is offline   Reply With Quote
Old 07-13-2013, 06:34 AM   #87
tranat
tranat's Avatar
Drives: Subaru BRZ SWP Limited
Just change your nav screen setting to the time of the day. Its one of the options. The other option is when your headlights turn on the screen dims.
Does anyone know how to make the led bar (near the fogs) turn on at night while the headlights are on? This would really complete the look of the brz.
tranat is offline   Reply With Quote
The Following User Says Thank You to tranat For This Useful Post:
mwjcyber (12-08-2013)
Old 07-13-2013, 08:35 AM   #88
infinite012
Drives: 13 DGM BRZ Ltd
CCFL is an old technology that was never really supposed to be used in cars and was replaced by LEDs in the aftermarket due to constant failures/fires. Ever wonder what was used to light up the old E39/E60 5 series halos? Incandescent bulbs.
Want to know what's used in the BRZ's "boomerang?" LEDs.
Until someone figures out a way to replace the PCB/ribbon that holds the LEDs inside the headlight housing, we will not have an easily replaceable/upgradeable boomerang.
infinite012 is offline   Reply With Quote
Old 07-14-2013, 12:33 AM   #89
Brzetto
Drives: 4 wheels
Originally Posted by OakmanSmalls View Post
I want both on (boomerang and drl) but no tails or side markers. I essentially just want to run the boomerangs as the drl w the led bar.
The "boomerang" hawkeyes are not as bright as the DRL's, thus the reason why they are not used as DRL's.
Brzetto is offline   Reply With Quote
Old 07-15-2013, 02:08 PM   #90
DoomsdayJesus
I'm just waiting for the first person to bake apart their headlights and dissect it.
Old 07-15-2013, 02:15 PM   #91
infinite012
@Jive Turkey has already separated his BRZ headlights to paint them black.
http://www.ft86club.com/forums/showthread.php?t=19954
Old 07-15-2013, 02:51 PM   #92
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
What a waste of the boomerangs to not have them on with DRLs.
SMH Subaru
sprintertrueno86 is offline   Reply With Quote
Old 07-15-2013, 11:48 PM   #93
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
I wonder if there's a way to increase the voltage or something like that to the DRLs to make them shine brighter... or do LEDs not work that way? Not a electrical engineer unfortunately
It'd be interesting to see if we can increase the intensity of the light output..
KelvinBRZ is offline   Reply With Quote
Old 07-15-2013, 11:55 PM   #94
37
degrees
37's Avatar
Drives: 6MT BRZ
Excessive voltage to a diode causes catastrophic failure. Hit your local Rat Shack, purchase a 5V LED, and connect it to a 9V battery. You'll be an electrical engineer in no time. Just wear safety glasses in case it explodes.
37 is offline   Reply With Quote
The Following User Says Thank You to 37 For This Useful Post:
krayzie (05-05-2015)
Old 07-16-2013, 04:09 AM   #95
ASdispatch
Drives: GBM Subaru BRZ
I would also like to have my boomerang and led drls on all the time with back, side and headlights automatically come on when dark.
ASdispatch is offline   Reply With Quote
Old 07-16-2013, 08:09 AM   #96
infinite012
LEDs are regulated by both voltage and current. What you don't want to do is increase voltage blindly. LEDs can be operated somewhat out of spec, but the right way to increase/decrease brightness is (someone can correct me if I'm wrong, since I'm just a regular ol' mechanical engineer that dabbles in electrical stuff on the side) with a PWM (pulse width modulator), which would control the duration that current goes to the LED(s) and pulses the current rapidly.
Old 07-16-2013, 09:37 AM   #97
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
^ So the LEDs use some sort of PW modulation when running? That would certainly explain why on videos you can see them blinking rapidly on occasion.
The use of PWMs is a digital way of achieving an analog effect, at least on computer fans - it can be used to reduce the RPM of a fan to any level. It has the net effect of a variable voltage reduction resistor, turning the fan motor on/off rapidly to maintain a set speed.
Sport-Tech is offline   Reply With Quote
Old 08-07-2013, 04:23 PM   #98
Kwisak
Kwisak's Avatar
Drives: 2013 BRZ GBS
I was messing around with my head unit and found that if you go to info, settings, then scroll down to auto dimming and place it on manual or on the clock time. The gps doesn't go to night mode and the head unit as well as all the other interior lights do not dim.
Kwisak is offline   Reply With Quote
The Following User Says Thank You to Kwisak For This Useful Post:
buddy32 (08-07-2013)
no front LED strip? Lydin Scion FR-S / Toyota 86 GT86 General Forum 3 06-03-2012 02:05 AM
FR-S SNS 200 mystery NAV/XM/Receiver FR-S-Ohio Electronics | Audio | NAV | Infotainment 2 05-31-2012 06:58 AM
About the LED strip on the GT86 Sasquachulator Scion FR-S / Toyota 86 GT86 General Forum 14 05-15-2012 12:14 AM
Mystery Clay Model From Toyota Video Dark Other Vehicles & General Automotive Discussions 16 02-18-2011 04:21 PM
