Old 07-12-2013, 07:14 PM   #141
Dezoris
Dezoris's Avatar
Originally Posted by sw20kosh View Post
Interested in seeing datalogged temps from my back2back dyno runs? IAT coolant and oil?
Yeah definitely, I will PM you. How has it been on the street when you hit high heat during the day to a cooler night?
Dezoris is offline
Old 07-12-2013, 07:21 PM   #142
sw20kosh
Drives: 2013 Black FR-S
So far my butt dyno sees no difference in 65 vs 100 deg weather. The data logs show no difference in timing either and there is no knock correction.
sw20kosh is offline
The Following User Says Thank You to sw20kosh For This Useful Post:
ftc~brz (07-16-2013)
Old 07-13-2013, 02:12 AM   #143
sw20kosh
@Dezoris
Ambient was around 96 F. One big fan blowing on the front of the car. @robispec total cooling solution. ~5 mins between each pull
Run 1 on the left, Run 6 on the right. Obviously there is not much airflow through the radiator so recovery of coolant temps after each run will be slower but as you can see coolant and oil temps dont creep up and up after 6 successive runs.
100 C = 212 F
96 C = 204 F
48 C = 118 F
sw20kosh is offline
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
Dezoris (07-13-2013), illmatic (07-16-2013), whataboutbob (07-13-2013)
Old 07-13-2013, 04:05 AM   #144
Dezoris
Dezoris's Avatar
@Dezoris
100 C = 212 F
96 C = 204 F
48 C = 118 F
All those runs with meth injection?
Basically all that data looks very good. Be curious to see the difference from other owners on stock cooling and no meth.
Again thanks a ton for posting this.
Dezoris is offline
Old 07-13-2013, 04:40 AM   #145
sw20kosh
yes except for the 5th run which had it disabled.
And yes to more temp logs from others. It is obvious to me that the robispec system is working great. Talked to him today and he told me in 116 deg ambient heat at a time attack track day his system was able to cope with flying colors. He was the fastest car there by the way... took first place by 10 secs! Congrats @robispec. Show those hondas who's boss!
sw20kosh is offline
Old 07-16-2013, 10:11 AM   #146
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Finally had a chance to do a little video work:
[ame]http://youtu.be/IxC2iNj1j9g[/ame]
Xero-Limit is offline
The Following 9 Users Say Thank You to Xero-Limit For This Useful Post:
cmss2000 (07-16-2013), Dezoris (07-16-2013), illmatic (07-16-2013), Kiske (07-29-2013), Lawnik (07-16-2013), Opposed (07-16-2013), vgi (07-17-2013), wrxgoose (07-16-2013), xxscaxx (07-16-2013)
Old 07-16-2013, 11:36 AM   #147
wrxgoose
WUB WUB
Drives: 2013 Firestorm
love how it sounds, just wish I could hear mine over my exhaust.
wrxgoose is offline
The Following User Says Thank You to wrxgoose For This Useful Post:
Old 07-16-2013, 04:26 PM   #148
Dezoris
Dezoris's Avatar
Mike you killing timing before 7k to prevent knock?
Dezoris is offline
Old 07-16-2013, 04:42 PM   #149
ftc~brz
Done
Drives: WRB BRZ
this
ftc~brz is offline
Old 07-16-2013, 05:58 PM   #150
Pete
Pete's Avatar
Drives: 22 BRZ
What a night and day difference in power delivery. I like it.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline
Old 07-16-2013, 07:48 PM   #151
Xero-Limit
Xero-Limit's Avatar
Injectors are on (DW700). Full power to redline now. No leanout, tip in knock reduced significantly as well.
Seeing about 6+ms port injection time to achieve .8 lambda with e85. That means we are well into the duty cycle on these on the stock pulley in nearly 100 deg weather. Was debating as to whether to start smaller, but I'd say the 700's are a good injector here.
Plan is to re-dyno once the header comes in.
Old 07-16-2013, 07:50 PM   #152
Xero-Limit
Xero-Limit's Avatar
Timing is taken out everywhere for pump gas. For E85 it is more selective. We pushed it on the dyno until the knock was blatantly evident (ever hear a 50 cal lol? hair away....) That point was well below stock maps on pump.
Old 07-16-2013, 08:58 PM   #153
jamesm
Intake temps were 116f with the meth running? That seems pretty high. How much does meth typically drop the temperature? What are people seeing without it? I'm usually around 105 or so, within 5-10 deg of ambient (with a fmic though).
jamesm is offline
Old 07-16-2013, 09:22 PM   #154
sw20kosh
It was a hot day on a dyno. Temps will be high at the airbox where the sensor is. This motor does not have a sensor in the intake mani so we cannot tell how much the meth is cooling. If you look closely you will see IAT drop to 42C when the actual run is started and there is more air flowing through the box.
I assume your maf/IAT sensor is post intercooler on your kit?
sw20kosh is offline
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
Innovate questions Fast_Freddy Forced Induction 12 07-02-2013 02:27 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
innovate SC for sale kioton32 Forced Induction 4 04-08-2013 11:42 AM
