Old 07-10-2013, 02:53 PM   #323
Diode Dynamics
Diode Dynamics's Avatar
Originally Posted by topazsparrow View Post
I wonder if the same thing could be done for the tail lights?
Tail lights are much more difficult to re-seal IMO
-Nick C.
John C.
Diode Dynamics
Old 07-12-2013, 04:34 PM   #324
PANDA86
Old School Status
Drives: .
Side Note:
This method below has helped in my past modification to my other vehicles.
After resetting the lens to the housing and allowing it to cool down for a minute, cover the lens with a towel and set it under the couch cushion and add weights as need to weigh down the cushion. This will help to press and reseal the lens to the housing to minimize/eliminate condensation.
BTW, make sure no one sits on them.
PANDA86 is offline   Reply With Quote
Old 07-12-2013, 04:53 PM   #325
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Originally Posted by Scalzo View Post
More or less
I only put it for about 6-8 min then just pry out like the head light . Then once done painting I put it back in the oven then put silicone around to seal it
Sent from my HTC One using Tapatalk 2
Did you also put silicone to seal the headlights after the putting it back into the oven? Very tempted to try this, but just afraid of headlight condensation occuring.
Old 07-12-2013, 05:13 PM   #326
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Yes, I have no condensation on all the head lights
Scalzo is offline   Reply With Quote
The Following User Says Thank You to Scalzo For This Useful Post:
Wes (07-12-2013)
Old 07-12-2013, 05:39 PM   #327
Diode Dynamics
If your worried about re-sealing, you should add some rubber butyl
John C.
Diode Dynamics
Old 07-12-2013, 05:55 PM   #328
Wes
Wes's Avatar
Thanks! that would be cleaner, but is it necessary? I mean it would be good security to use rubber butyl or silicone as added security, but are most people putting the headlights back on with the original glue without any issues?
Old 07-13-2013, 09:54 AM   #329
Diode Dynamics
I think Paul usually recommends adding some rubber butyl just for safe measure, for how rubber butyl is, you might as well add it IMO
-Nick C.
John C.
Diode Dynamics
Old 07-13-2013, 11:35 AM   #330
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I want to do this badly but am scared of ripping apart the lights. I would never want to lose the high beams. Just blacking out the projector area looks badass enough.
hmong337 is offline   Reply With Quote
Old 07-13-2013, 12:00 PM   #331
Wes
Wes's Avatar
-Nick C.
Okay cool thanks Nick! Yeah it would also just give me a peace of mind instead of being paranoid lol. Do you recommend any places to get some from?
Old 07-15-2013, 09:43 AM   #332
Diode Dynamics
I think O'reilly's probably carries it, but if you google "Automotive Butyl" you can read a little more to get piece of mind about it. It's one of those things where it seems really intimidating, but if you take your time and have patience it's actually pretty simple.
Of course if you ever have any issues or anything you can always shoot me a PM or contact us: contact@diodedynamics.com
Paul has the most experience with taking the lenses off and our team is exceptionally knowledgeable.
Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
Wes (07-15-2013)
Old 07-15-2013, 10:26 PM   #333
laley81
Scion FR-S
laley81's Avatar
Drives: Scion FR-S 2013
These look sick! Great job. Is it hard to do? I like the strip under the light.
laley81 is offline   Reply With Quote
Old 07-15-2013, 10:44 PM   #334
Yruyur
Yruyur's Avatar
The reteofit source sells the good stuff as well. I picked some up when I ordered my retrofit. Never ended up using it for the headlights though.
Sent from a Motorola DynaTAC 8000X
Old 07-16-2013, 10:08 PM   #335
Clalondeberg
Drives: 2013 frs
Shout out to darrin for the write up made life a lot easier. One thing I did notice in steps 3 and 4 when you remove the side marker if you stick an awl or some small pick tool you can pop the push pin out rather than removing the side marker, I think that why it may have broken
Clalondeberg is offline   Reply With Quote
Old 07-17-2013, 11:42 AM   #336
Wes
Wes's Avatar
I finally manned up and did this and I must say, I'm glad I did it, thanks to Darrin for this diy, I nearly wanted to give up when I was opening my headlights. Most nerve racking experience! Will have some pics soon.
If anyone is having a hard time with taking out the side markers heres a video I used and it was actually super easy to take off without breaking it.
[ame="http://www.youtube.com/watch?v=xP6tbrGyN1o"]2013 Scion FRS Subaru BRZ Horn Upgrade DIY - YouTube[/ame]
Picture time!!
Definitely glad that I did this
The Following User Says Thank You to Wes For This Useful Post:
Diode Dynamics (07-17-2013)
HID Headlight Upgrade KIT - 1st MOD completed SpecPer Exterior Parts - The Rest 76 08-03-2012 10:13 AM
Is Anyone Else Tired of SOA Information Blackout geb2391 BRZ First-Gen (2012+) — General Topics 23 04-21-2012 09:37 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 02:45 AM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
TRS headlight mod RRnold Other Vehicles & General Automotive Discussions 0 12-24-2011 04:20 PM
