Old 07-08-2013, 03:52 PM   #1
hyperpunx
loose rear-seat latches
Hello everyone.
I have taken in my frs several times for the repair of the noise coming from the rear. They determined that it was my rear seat latches coming a bit loose after driving. Their solution was have me slam my rear seats closed to fully engage the locks on either side. This solves the problem, but only temporarily. Once I go over bumps it has to be redone.
Anyone else have this issue?
Thoughts?
hyperpunx is offline   Reply With Quote
Old 07-08-2013, 04:04 PM   #2
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
I believe I have the same issue... I've got some felt pads that were purchased for the bottom of our furniture. I intend to stick some of those so to keep the seat latched tighter and see if that remedies this problem.
Subaru STI :
Old 07-08-2013, 05:54 PM   #3
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
I THINK I have this problem. I'm not sure whether or not it is the "rear deck popping" sound or the seat latches. I would definitely try wrapping the latches with a foam substance if it is making sounds though.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-08-2013, 06:20 PM   #4
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Mine makes the noise too when the body flexes. The noise goes away when I spray WD40, but it lasts only for a month. I tried white lithium grease also and that lasts only a month too. My next step is to put some padding there. I'm planning to try it this Wednesday.
Old 07-09-2013, 01:13 PM   #5
hyperpunx
Thanks for the replies everyone! please let me know if those fixes work for you!
Old 07-11-2013, 04:40 PM   #6
Sigh-on-Rice
Padding didn't work.
I wiped off the grease I applied before and put some blue painter's tape as padding.
It still made the noise.
When I fold the rear seat down, there is no noise.
I don't know what else to try.
Old 07-11-2013, 04:43 PM   #7
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
How about Sugru or Plastidip? The extra width on the connecting ring may be all thats needed to shut that noise up.
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 07-11-2013, 05:16 PM   #8
Sigh-on-Rice
I have a feeling that making the connecting ring thicker doesn't remove the noise. I put 3-4 layers of tape around them so that I had a hard time putting the rear seats locked. I'm thinking it needs to be able to slide instead, and that's why greasing works. Maybe I'll just keep greasing and it might stop making the noise someday.
Old 07-11-2013, 05:24 PM   #9
Norkoastal
Norkoastal's Avatar
Must be the locking mechanism being a little to loose to not rattle over bumps.. Ugh.. Always the stuff thats buried inside the seat or dash panel, lol.. Already dynamatted the deck and side pillar rattle prone areas..
CO>CA Cartel
Old 07-11-2013, 06:12 PM   #10
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
if your seat is coming undone it may not be fully locked. push the circular buttons at both sides down completely
supramkivtt2jz is offline   Reply With Quote
Old 07-13-2013, 03:02 AM   #11
l0aded
Addicted
l0aded's Avatar
Wow I completely forgot about these buttons. Thanks lol.
Old 07-13-2013, 11:02 AM   #12
FRiSson
Drives: FR-S MT
OP thanks for posting this. I fixed a pesky rattle just by re-closing the seat back.
FRiSson is offline   Reply With Quote
Old 07-15-2013, 12:15 PM   #13
hyperpunx
close but no cigar
This is the same story that Toyota techs told me. "oh you are just not closing it well enough to engage the lock fully" well I am, and I have to slam it to lock all the way. But even then, just a little driving over some slight gravel or bumps and the seat lock disengages slightly to make that rattle.
Old 07-22-2013, 12:36 PM   #14
hyperpunx
I went in the back seat and started pushing down on both side's buttons to lock, and i noticed that the passenger one seems "bouncy". In other words, when you push it down and tap the seat a few times, the button will pop back up and unlock itself; whereas the driver's side wont.
Anyone else have a similar experience
Reviews on the TRD Door Latches/Stabilizer RYU Cosmetic Modification (Interior/Exterior/Lighting) 84 04-08-2022 06:41 PM
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 07:59 AM
Rear Seat Deletes ??? KVDB31 Cosmetic Modification (Interior/Exterior/Lighting) 40 08-17-2013 10:16 AM
JDM Rear Seat Silencer ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 4 01-09-2013 01:51 PM
car seat in the rear seat? 4032pauln Scion FR-S / Toyota 86 GT86 General Forum 20 09-05-2012 09:34 PM
