Old 07-10-2013, 09:36 AM   #127
Visconti
Drives: 05 STi
New Flex Fuel Tune has arrived
v1.00b4 is the new cool
Visconti is offline   Reply With Quote
The Following 6 Users Say Thank You to Visconti For This Useful Post:
cobrabyte (07-10-2013), DriftEm (07-10-2013), JiB (07-10-2013), mikalem (07-10-2013), Sensisnow (07-10-2013), Yruyur (07-10-2013)
Old 07-10-2013, 07:07 PM   #128
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Got it loaded up, behaved fine on the way home in stop and go traffic, going to take it out for a logging spin here in a little while - will update the ticket with the data I pull.
mikalem is offline   Reply With Quote
Old 07-10-2013, 08:06 PM   #129
JiB
JiB's Avatar
Drives: GT86
feels pretty smooth sent some logs just then
JiB is offline   Reply With Quote
Old 07-10-2013, 08:32 PM   #130
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
EDIT AGAIN: All is fine with this update! For some reason, the ECU learning process took forever.
Whew, this update hurt. Def a step back for me but not sure if John tweaked my map like he has the last two updates. Car was falling on its face when pressing the gas pedal and I ran into some fueling issues near redline. Fuel pressure just dropped away. I did have a little less than half a tank but I just can't see that being an issue.
Btw, running john's 290LPH fuel pump. Maybe the tunnel pump isn't keeping up. Need to investigate Don@AP's fueling solution.
Edit: looks like less than half a tank may be the issue according to http://www.ft86club.com/forums/showthread.php?t=36231
cobrabyte is offline   Reply With Quote
Old 07-10-2013, 09:53 PM   #131
charged86
charged86's Avatar
that kit is only 1300$
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
Old 07-10-2013, 10:14 PM   #132
cobrabyte
cobrabyte's Avatar
"only"
Old 07-10-2013, 10:59 PM   #133
charged86
charged86's Avatar
"only"
it looks nice though I want it but don't really need until I go turbo.
Old 07-11-2013, 08:44 PM   #134
Yruyur
Yruyur's Avatar
Double check those fuel lines are all snugged up. Half a week running the kit was smelling just a little fuel. Two of the lines were hand loose. Thought I had them all but....
Sent from a Motorola DynaTAC 8000X
The Following 2 Users Say Thank You to Yruyur For This Useful Post:
cobrabyte (07-11-2013), iketiak (07-11-2013)
Old 07-11-2013, 10:14 PM   #135
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
I've quad checked the line and fitting, no visible leaks, yet there's still a strong fuel smell a week after the install. Could be the small spill I had when installing but the odour is stronger on the fuel line itself than the area where I had the spill.
Going to get in there and wash everything and hopefully it'll go away.
enouf is offline   Reply With Quote
The Following User Says Thank You to enouf For This Useful Post:
Yruyur (07-11-2013)
Old 07-12-2013, 12:24 AM   #136
Sensisnow
Drives: 05 TSX & 13 BRZ
Mine was running fine the night of the install then when I fired it up after being out of town for 5 days, I immediately smelled gasoline. I popped the hood and it was spraying fuel at the hose clamp connection. I think I pulled up too hard on the metal fuel line and threw things out of alignment a bit because it would work fine until I snapped the new line back into the plastic clips. Once I realized the issue, I just pushed down on the metal line which got everything back into alignment and I haven't had an issue since then. I still get a whiff of fuel every now and then though, which is probably just residual, but I've pulled over quite a few times to check the lines and haven't seen anything. I'm sure I'm just paranoid now, but I'd rather be safe than sorry.
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1
Sensisnow is offline   Reply With Quote
Old 07-12-2013, 10:05 AM   #137
Visconti
Drives: 05 STi
Yes, PLEASE make sure you guy have all the connections TIGHT
John
The Following User Says Thank You to Visconti For This Useful Post:
Sensisnow (07-12-2013)
Old 07-12-2013, 10:36 AM   #138
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
My gauge fell off too. Kinda pissed me off, I had to stick it to the steering wheel so now I can't even read it. I need to find some way of attaching it to the dash without it falling off.
post_break is offline   Reply With Quote
Old 07-12-2013, 10:37 AM   #139
Visconti
Drives: 05 STi
I have mine on a few local cars with no problems
Dam this pisses me off to!
Old 07-12-2013, 11:12 AM   #140
post_break
post_break's Avatar
Yeah it wasn't like it fell off once. It kept falling off over and over as I'm driving. Thanks Obama.
I've got some velcro I might try, or maybe even a magnet if it doesn't screw up the unit.
campaign: ban jv, diy, e85, fuel leak, kit, laughing to the bank, oh lord jesus its a fire, visconti, viscontifried, viscontinued
Flex fuel testing Dynotronics1 Southwest 5 06-22-2013 03:27 PM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 11:04 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Cheap flex fuel? nix Engine, Exhaust, Transmission 1 05-11-2013 04:05 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
