Old 07-10-2013, 07:40 AM   #85
charged86
charged86's Avatar
Originally Posted by Dezoris View Post
Don't want to over complicate the issue just yet. Gonna replace suspect pulleys, replace tubes re-align and keep and eye on it for now.
My guess is there will some updates to the intake tube and documentation following all of our recent posts etc.
I searched gates web site could not find a double sided belt in our length.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-10-2013, 01:05 PM   #86
Dezoris
Dezoris's Avatar
Did you look at the green belts with kevlar? Thats what I wanted but does not look like they exist.
Old 07-10-2013, 05:21 PM   #87
charged86
charged86's Avatar
http://www.gates.com/oreilly/PDFs/SizeListings.pdf
I found green stripped v-belts but no 6 rib green
Old 07-10-2013, 05:45 PM   #88
Dezoris
Dezoris's Avatar
Too bad, it would take a nuclear blast to destroy those green belts. They are used on garbage trucks, 18 wheelers that have more torque than 20 FRS.
Old 07-10-2013, 05:48 PM   #89
charged86
charged86's Avatar
hahaha we have a gates 2 inch wide cog belt operation our wire forming machine at work. super hard plastic. cant wait to see your blue rb belt I have one on my 1.8t
Old 07-10-2013, 06:02 PM   #90
MATTrocity
Winter Is Coming
Drives: 2013 Scion FR-S Ultramarine
does anybody know what could be the issue if my belt is just getting tore up? when I looked inside a lot of the belt shreds were caught up in the back centerish of my compressor. it's only getting tore up on one side of the belt, towards the rear of the car and my friend suggested it could just be the compressor sitting not close enough?
Obviously I need to change the belt so I might as well change the pulley too. does anybody have alternatives? I'm open for smaller pulleys too.
MATTrocity is offline   Reply With Quote
Old 07-10-2013, 06:25 PM   #91
Dezoris
Dezoris's Avatar
I will post it up after I get it in with the pulley and intake pipe.
Turbowski and I will be dying in the heat doing a belt swap video.
The Following User Says Thank You to Dezoris For This Useful Post:
charged86 (07-10-2013)
Old 07-10-2013, 06:27 PM   #92
charged86
charged86's Avatar
Can you provide pictures
The Following User Says Thank You to charged86 For This Useful Post:
Dezoris (07-10-2013)
Old 07-10-2013, 06:27 PM   #93
Dezoris
Dezoris's Avatar
Take a good hard look at the pulleys for any wear, namely the one in question here. If you can post up some pictures it will help greatly to see anything obvious. How many miles do you have on your kit, did you do the install yourself?
Old 07-10-2013, 07:15 PM   #94
DJCarbine
Thupercharged
DJCarbine's Avatar
Sounds like a belt alignment issue....
Verify that the pulley below the discharge pipe that goes directly into the throttle body is good, and from there I would doublecheck the supercharger/bracket assembly mounting to make sure it is mounted properly
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-10-2013, 11:21 PM   #95
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
We should meet up and compare our kits. I would like to see if we installed every the same way, might be able to figure out what's wrong.
Deepseadiver is offline   Reply With Quote
Old 07-10-2013, 11:45 PM   #96
Mersd
Drives: Scion FS-R
Replaced my belt this week. No apparent cause.
Mersd is offline   Reply With Quote
Old 07-11-2013, 12:17 AM   #97
MATTrocity
Winter Is Coming
this is what I pulled out, and the damage of the belt. I didn't get a picture of where it was collecting, I'll try to get that later.
Old 07-11-2013, 12:18 AM   #98
MATTrocity
Winter Is Coming
yeah we definitely should. I definitely rushed mine and that was a huge mistake.
Kartboy Crank Pulleys 95.00 tom@kartboy Engine, Exhaust, Bolt-Ons 16 06-11-2013 01:06 PM
Crank,Alternator,Waterpump Pulleys etc..? fareastbrz Engine, Exhaust, Transmission 6 05-28-2013 08:46 PM
Titan Performance second batch of pulleys Amalgamo User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-30-2012 09:57 PM
