#127 | |
Drives: 04 S2000
#128 | |
Site Moderator
Drives: Stuff
I'm moving to a FT86 variant to get that same blast on the track/autox and HOPEFULLY that Miata kind of fun on the street. If this car ends up reminding me exactly of the S2K I can't imagine I'd buy it.. I'd rather just pick up a S2K CR if I wanted that same experience again.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#129 |
Drives: 2013 BRZ ordered!
I sold my S2K a year ago after 6 years of ownership because I required a back seat.
Sorely miss it and hope the FR-S I have on order can fill that void! I don't think it will be better, but I do think it will replicate that driving experience. |
#130 |
Handling junkie
We believe the car as the *potential* to be faster than a s2k. It's all going to depend on the front suspension not failing us.
There's are some real strengths and weaknesses to the car. Pros: - Engine should be easily tuned to 250hp with bolt-ons (TBD). I'm thinking intake, exhaust, test pipe, and tune. - Car is LIGHT. Losing 100 lbs from stock is a matter of running a quarter take of gas, taking out spare tire + tools. Losing another 100 lbs is a battery, exhaust, and rear seat removal, all of which is easily reversible. - Coupe chassis; possibly stiffer, and no roll bar needed immediately. - Car is aerodynamically superior. S2k has front downforce, but massive rear lift. This car has lower Cd and possibly smaller frontal area. As long as there's no significant lift, it's already at a significant aero advantage. 250hp/2500 lbs is quite potent versus a s2k with 250hp/2700lbs. Cons. - Front struts. Takes rim/tire space. - 5x100 wheels. Limits rim choice. - Unproven engine and platform. - Extremely limited aftermarket support for a while. |
#131 | ||
Handling junkie
Just a lot of bolt-ons that are very well sorted out and balanced.
Up to him if he wants to post any more... From a previous post he made: ![]() Quote:
The s2k in stock form is 50/50, or 49/51, but every one modified for the track is heavier in the front. Porsche/Lotus are all rear biased, and you don't see their handling compromised much ![]() Quote:
#132 | |
#133 |
Drives: Honda Fit
@Mike: 2500 lbs. would be nice.
#134 | |
Handling junkie
I have a hardtop on my s2k, and I can tell you, it helps, but not much. Think K20 (performance variants). Also 86x86, but 11:1 comp as opposed to 12:1. Redline is 8200, give or take, depending on the variant. With bolt-ons and a tune, they're hitting 260+. Given that TRD is going to offer a supercharger, I have no doubt that this engine can gain some power with just bolt-ons as well. It really comes down to how the car will turn. Not many cars rotate like a s2k. |
#135 |
Drives: '06 AM V8V Coupe
Camry has good aerodynamics actually, 0.27 drag coefficient, flat underbelly with "diffuser" (at least some newer models). The S2k has a pretty horrible bottom as well as top, the FRS is looking much better already for sure. Hardtop cars tend to do better since the rear window doesn't slope down so steep, I think...
#136 |
Glorious BRZ Master Race
Drives: Subaru Libird
For all the frs/brz vs threads I would say go compare the 86 to the car in question in GT5. I honestly think it can be used as a virtual benchmark closest to the real thing til the real cars become physically available.
#137 | |
Drives: 2022 Halo White GR86
Sure the S2000's CD is horrible compared to the FT86's 0.27. But it also has 40 HP more under the hood despite being 100 lbs heavier. In automobiles and especially sports cars, aerodynamics are pretty much non existent. 3 out of 4 of the top 4 lowest drag coefficient cars created were 1933-1996. Aerodynamics is an after thought in car design because artist/designers' concepts are more important. Most automobile form factors nowadays range from 0.29-0.35 with the trucks and SUVs obviously hitting higher. One can tell from the standard deviation of the CD pool in cars, that there isn't much engineering done in aerodynamics. Something has gotta be wrong if the top rally cars and sports cars has equal or worse drag than a 1990 Volvo 940 After keeping up with Toyota's FT86 5 year development I can say that 0.27 is a very respectable CD. A 0.03 CD difference might not be a lot number-wise, but car aerodynamics is like grading on a curve and the FT86 is in the top 8% of the class. They purposely designed it into the car to an extent unlike most cookie cutter builds these days. Cars like the Lexus LFA, NSX, 350z, 370z are average C students. Although a Toyota Prius has a CD of 0.25
#138 | |
Handling junkie
The official Cd of the s2k isn't published, but the math works out to be about 0.38-0.39 with the top up Cd matters. Non-existant aerodynamics? Have you seen the latest round of exotics? There's an insane amount of simulation that goes into these things. Top rally and race cars have horrible Cd and frontal area because they're made for extreme downforce, not to cut through the air with as little resistance as possible. |
#139 |
Drives: Some rust bucket
i've always wanted a CR in GPW. :o
are you trading the CR for the FRS/BRZ, or adding another car to the stable? |
#140 |
Handling junkie
| Thinking of Buying either MR-2 Spyder or an AP1 S2000 | FT///R86 | Other Vehicles & General Automotive Discussions | 33 | 12-29-2011 12:53 AM |
| S2000 or MX-5 | balance | Other Vehicles & General Automotive Discussions | 10 | 11-01-2011 02:01 AM |
| S2000 from hell | CyberFormula | Other Vehicles & General Automotive Discussions | 13 | 07-09-2010 09:05 PM |
| The Real S2000 Successor | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 10 | 02-12-2010 01:21 AM |
| Honda S2000 Mugen Hard Top Headliner | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 3 | 01-15-2010 01:43 PM |
