Old 07-08-2013, 01:13 AM   #1
joelg
Drives: Scion FR-S Whiteout
Hot Key After Driving
Has anyone noticed that their key is super hot when the pull it out of the ignition after driving? A couple times now I have just about burned my fingers on my key putting it in my pocket.
Has anyone else had this issue?
joelg is offline   Reply With Quote
Old 07-08-2013, 05:33 AM   #2
fistpoint
Drives: Supercharged Golf Cart
Have your dealer change the keyfob oil, it happens from time to time.
fistpoint is offline   Reply With Quote
Old 07-08-2013, 06:00 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Key fob oil is lifetime fill...
Old 07-08-2013, 07:23 AM   #4
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
No, I have not had anything close to that being a problem.
whaap is offline   Reply With Quote
Old 07-08-2013, 07:48 AM   #5
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Pull your codes. You probably have P8024 (fob coolant reservoir low). The reservoir is in the second trunk, adjacent to the serving trays and canoe.
Old 07-08-2013, 12:34 PM   #6
grodenglaive
Drives: asphalt FR-S
grodenglaive is offline   Reply With Quote
The Following 2 Users Say Thank You to grodenglaive For This Useful Post:
JDM FRS (07-09-2013), joelg (07-10-2013)
Old 07-08-2013, 12:52 PM   #7
topazsparrow
Drives: slow
Sounds like someone may have hot-wired your car at one point and left the wires exposed near the ignition lock.
You might need to run some coolant in there to cool down those hot wires.
topazsparrow is offline   Reply With Quote
Old 07-08-2013, 05:38 PM   #8
FRiSson
Drives: FR-S MT
Check for a short... and check your shorts for keyholes.
FRiSson is offline   Reply With Quote
Old 07-09-2013, 05:14 AM   #9
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
Yes, what has the weather been like in southern NM? I can only imagine it's been warm. It gets pretty hot here in southern AL. The dealership found nothing wrong and said it was probably just the heat. I had no issues in the cooler months.
Sent from SAMSUNG GALAXY NOTE. KEEP CALM AND CHIVE ON.
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Old 07-09-2013, 07:38 AM   #10
PMPB
Drives: BRZ Sport-tech
Is it AT? If yes, it's because the key connect the paddle shifters to the electronics. Completely normal.
If it's MT, the key can get got from slipping the clutch. The heat travels up the clutch master cylinder. This intense burning heat then warms up steering column and subsequently your keys. After too much clutch wear the key will stop working. It's a feature, to both burn your fingers, to let you know you're doing it wrong. And once the key stops working, the dealer can easily source the problem to your crappy shifting technique and void your warranty after you tow your car for service.
PMPB is offline   Reply With Quote
The Following User Says Thank You to PMPB For This Useful Post:
Simpleviet (07-09-2013)
Old 07-09-2013, 11:35 AM   #11
frslee
Just drive it
Drives: 13' FR-S
x2 on filling up key fob coolant.
frslee is offline   Reply With Quote
Old 07-10-2013, 08:42 AM   #12
joelg
Im having a hard time separating the trolls from the helpful advice. Going to ask the dealer next time I bring it in I guess. Pretty sure Gaffigan's advice was the best I got.
The Following User Says Thank You to joelg For This Useful Post:
yuicebox (07-10-2013)
Old 07-10-2013, 12:21 PM   #13
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
It's fine. Every car I've driven for extended amounts of time does it, Honda, Acura, Nissan, Toyota, Chevy, Ford etc. etc.
ineedyourdiddly
Driving section - actually driving the things somewhere bcj Site Announcements / Questions / Issues 6 04-08-2013 11:28 AM
Driving in the wet Turdinator AUSTRALIA 47 11-28-2012 03:23 AM
winter driving paraguin BRZ First-Gen (2012+) — General Topics 25 08-03-2012 05:26 PM
Why you are always driving uphill FRiSson Scion FR-S / Toyota 86 GT86 General Forum 9 07-25-2012 07:37 AM
Driving too much! F3dzo Scion FR-S / Toyota 86 GT86 General Forum 15 07-15-2012 01:14 AM
