Old 12-28-2011, 09:22 PM   #127
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Max Schnell View Post
This is why I mentioned ECU tuning for DI and revs in the same paragraph. There are any number of reasons that may have the power drop off after 7k. If the car can be tuned to continue to make power then raising the rpms makes sense.
Cams. It will need bigger ones. And likely valvetrain at least.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-28-2011, 09:40 PM   #128
Mitch
form follows function
Drives: RIP '13 BRZ
Originally Posted by tranzformer View Post
Power drops off after 7000rpm. Why would you want to increase redline unless you had other supporting mods to make it worthwhile?
Just because power ceases to increase (or even decreases dramatically) at higher rpms does not mean there isn't a mechanical advantage to staying in gear versus moving on to the next gear. I make these graphs when I get a new car. I'll make one for the BRZ when it comes out and we get some baseline dyno numbers. This is one I made when I got my Civic Si: Basically, if you have the baseline dyno, the tire profile/size info, the transmission gear ratios, and the final drive ratio, you can make a graph like that to determine what gear / road speed combination gives you the most force. If you know the coefficient of drag, you can take a pretty good stab at the drag-limited top speed.
Mitch is offline   Reply With Quote
Old 12-28-2011, 10:21 PM   #129
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
You can put a filter assembly right over the ITBs. That's what I've used in the past. Carbon housing are just fancy, I'd rather either run just the filter with ducting going to it or just weld up an aluminum duct/box for them..
Or you can go RTR-X style
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 12-29-2011, 03:17 AM   #130
Sully
Drives: In the market for something fun
Wow that's sexy.
I wonder what the comparison numbers are for the filters inside the velocity stacks, mounted just outside and a traditional plenum over the ITBs.
Sully is offline   Reply With Quote
Old 12-29-2011, 05:17 AM   #131
fatoni
Originally Posted by Sully View Post
Wow that's sexy.
i dont know if it changes numbers. i would assume it just move them around
Old 12-29-2011, 08:44 AM   #132
old greg
Rocket Surgeon
Drives: PSM GGA OMG
The numbers aren't likely to be good. Those tiny filters have very little surface area (read: restrictive), and them being down inside the velocity stacks interferes with the functionality of the stacks.
old greg is offline   Reply With Quote
Old 12-29-2011, 09:45 AM   #133
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Unless there's another stack underneath. I agree on the surface area.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-29-2011, 01:32 PM   #134
arghx7
Drives: car
ITB's aren't going to happen until someone sources a complete electronic throttle solution for them.
It's likely that the intake ports will be restrictive above 6500-7000rpm.
Old 12-29-2011, 09:18 PM   #135
airboy808
Drives: toyota 5-lug long travel prerunner
Ram air like the s2k aftermarket air boxes. That is going to be the ticket plus look trick.
airboy808 is offline   Reply With Quote
Old 12-29-2011, 10:30 PM   #136
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
I won't agree with this just yet because of emissions. The faster the engine is turning, usually the more you're emitting out of the engine
That's pretty much how it already seems to be laid out, however I imagine is has left some room for improvement.
Homemade WRX is offline   Reply With Quote
Old 12-30-2011, 05:22 PM   #137
catharsis
Drives: honda civic si 08
If it's anything like a k20 at most with bolt on's and a tune I expect 20 more HP to the wheels. This thing is probably pretty refined from the factory, so there won't be much more power to squeeze out of it with bolt ons.
catharsis is offline   Reply With Quote
Old 01-03-2012, 03:46 PM   #138
NA_T
NA_T's Avatar
Drives: E36
Replacing parts that are in there for emissions will be all that we can do.. should except some gains from that. Gaining 20HP out of that could be possible, but that will be about it..
NA_T is offline   Reply With Quote
Old 01-05-2012, 09:22 AM   #139
Levi
Drives: Toyota
Levi is offline   Reply With Quote
Old 01-05-2012, 09:46 PM   #140
Caliban
Terrorist of Chat Rooms
Drives: 05 E46M3, 06 CT9ARS, FR-S?
if turbo can't be fitted under factory bonnet..how did they put a turbocharged motor under the BRZ GT300? the bonnet of BRZ GT300 doesn't look much different than the production model.
Caliban is offline   Reply With Quote
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
Mods? Bruninho8 Scion FR-S / Toyota 86 GT86 General Forum 3 12-06-2011 06:11 PM
Estimated Price.. SLeRoux92 Scion FR-S / Toyota 86 GT86 General Forum 44 05-25-2011 11:58 AM
