Old 05-23-2013, 02:31 AM   #309
636
636's Avatar
Drives: '23 CWP BRZ
Originally Posted by thejevans View Post
Just make sure you took out the plastic pop-pin thing behind it. Then they should just pull straight out.
That's the thing I'm having trouble with. Popping that tab, lol
636 is offline   Reply With Quote
Old 05-23-2013, 08:52 AM   #310
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
Well, they do suck. It's one of the screw out ones, correct? I had to break some of those and get more of the good ones.
1994 Plymouth Acclaim - Engine died and went to cash for clunkers
2001 Dodge Neon R/T- Hydro-locked engine and parted out
2003 Nissan Sentra SE-R Spec-V - Traded for next car
2013 Scion FR-S - Got taken out by a distracted driver while I was sleeping. Total loss.
1997 Mazda Miata - Current
thejevans is offline   Reply With Quote
Old 05-23-2013, 12:50 PM   #311
636
636's Avatar
Drives: '23 CWP BRZ
No, no. The wheel well tabs are easy, it's the pop tab inside the side marker I'm having trouble with.
Old 06-10-2013, 04:01 PM   #312
FRS_Sovereign
Manual Noob
Drives: 2013 Scion FR-S MT Asphalt
Originally Posted by DarrenDriven View Post
OK, so I got some sleep last night and woke up refreshed to install the lamps into the car.
[/B]
What kind of paint do you recommend? Does it have to be for higher temps? Also what do you think will be the best way to get a color match to asphalt. BTW I think your car looks fantastic.
FRS_Sovereign is offline   Reply With Quote
Old 06-28-2013, 06:35 PM   #313
White-Out
White-Out's Avatar
Drives: '13 White-out FR-S 6MT
I've failed to remove the side marker too..
Isn't the side marker must come out before that pop? It's the fifth one.
'00 Toyota Solara V6 SLE
'13 Scion FR-S 6MT
White-Out is offline   Reply With Quote
The Following User Says Thank You to White-Out For This Useful Post:
636 (06-30-2013)
Old 07-01-2013, 11:26 AM   #314
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
I'm so nervous about doing this. I wish a vendor would do it for me lol
Ammonia is offline   Reply With Quote
Old 07-09-2013, 05:14 PM   #315
JETRED
JETRED's Avatar
Drives: Unicorn
Thanks @DarrenDriven for an awesome write up! Here is a preview of mine...
JETRED is offline   Reply With Quote
The Following User Says Thank You to JETRED For This Useful Post:
DarrenDriven (07-10-2013)
Old 07-09-2013, 05:33 PM   #316
Rickp2
Japsquad member
Rickp2's Avatar
Drives: Toyota GT86 - Daihatsu Charade GTti
Nice ones, keep going
Rickp2 is offline   Reply With Quote
Old 07-09-2013, 11:31 PM   #317
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
I'm a guru at these headlights, I even started doing the blinkers, I've done about 5-6 sets including my own car. I charge about 150$
Turbod frs is mine in the 3rd pic
Sent from my HTC One using Tapatalk 2
Scalzo is offline   Reply With Quote
Old 07-10-2013, 09:23 AM   #318
Ammonia
Ammonia's Avatar
Old 07-10-2013, 11:26 AM   #319
ML
ML's Avatar
Drives: 13 White MT FR-S
Same process for the blinkers?
Old 07-10-2013, 11:32 AM   #320
Scalzo
Scalzo's Avatar
More or less
I only put it for about 6-8 min then just pry out like the head light . Then once done painting I put it back in the oven then put silicone around to seal it
The Following User Says Thank You to Scalzo For This Useful Post:
ML (07-10-2013)
Old 07-10-2013, 02:39 PM   #321
ML
ML's Avatar
anyone used this paint?
http://shop.advanceautoparts.com/web...k+chrome+paint
I heard you could use it for the high beams and retain effectiveness. Might looks good for the whole headlight too?
Old 07-10-2013, 02:48 PM   #322
topazsparrow
Drives: slow
I wonder if the same thing could be done for the tail lights?
topazsparrow is offline   Reply With Quote
HID Headlight Upgrade KIT - 1st MOD completed SpecPer Exterior Parts - The Rest 76 08-03-2012 10:13 AM
Is Anyone Else Tired of SOA Information Blackout geb2391 BRZ First-Gen (2012+) — General Topics 23 04-21-2012 09:37 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 02:45 AM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
TRS headlight mod RRnold Other Vehicles & General Automotive Discussions 0 12-24-2011 04:20 PM
