#29 | |
Drives: 2009 BMW 335i
![]() Knowing the standing relationship that GREDDY and Toyota have I am sure they opened the parts bin or gave inside info.
![]() AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma |
#30 |
Site Moderator
Drives: Stuff
Agreed. I'm not even sure they are slightly modified. There will be a.. hmm not sure what the correct word is, but a "shaft" to replace the end of the axle for the bearing/hub assemly to slide onto... that may be all that's bolted to the hub. It needs something in the middle so the bearing doesn't destroy itself.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#31 | |
Site Moderator
Drives: Stuff
a front knuckle with no axle through it... The WRX bearing is pressed into the knuckle and then the hub is pressed into the bearing. Standard stuff. The only modification I can see is bolting on an axle end or what not for the bearing/hub assembly to slide over. I would not be surprised if the hub/bearing assembly belongs to a Toyota FWD car (using the rear bearing/hub assembly) though, simply enough to use that on the front since the setup would then be the same (just a threaded shaft, slide the assemble over, put on a washer, and then tighten the axle nut.)
-Dave
#32 | |
Drives: 2010 Evo X MR-T
think about it. they have a golden opportunity to prototype a conversion kit before anybody else even has a chance to see the car, let alone touch it.
#33 | |
Site Moderator
Drives: Stuff
I'd love a real 5x114.3 conversion hub, or just the ability to press in STI bearings and hubs, but I haven't seen anybody post links to WRX guys doing that.. the WRX market is much bigger than the AS1 market so you'd think it would have been done there already if there was a good enough business case for it. I guess I just like to see evidence of things posted on here, and none of the pics/info provides any evidence that they made conversion hubs at all. I'd really love to see between those wheels and the rotors as that would answer the question.
-Dave
#34 |
Site Moderator
Drives: Stuff
Just went back around and checked some of the pics and videos. Based on the offsets and how flush those wheels are, and the spacing between the wheel and calipers, etc I'm pretty much convinced they are spacer adapters. I hope they aren't (but then I also hope it's not greddy specific parts) but without better evidence it just looks like spacers are used to me.
-Dave
#35 |
FT86Club.com O.G.
Drives: Gunmetal Gundam Wing Zero Custom
what's wrong w/ spacer adapters??
#36 | |
I not sure I follow you. Are you saying you just think it's an adapter? I know there are adapters to convert 5x100 to 5x114 in existence already. *edit, saw second post. Meh...nothing wrong with space adapters to me.. Doubt I would do anything but daily drive on them though. |
#37 |
I have friends that own STIs and other Subarus and they hate the spacer kits because of the construction and hitting the wheels when they are on (plus extra long bolts)
#38 |
FT86Club.com O.G.
that sounds pretty lame. sounds like a hub conversion kit would be a lot easier/better to live w/.
#39 |
I'm a Carcissist
Drives: JERRV , 11 STI, 07 FJ
#40 |
was real evident in the FT concepts headlamp design (then they softened the production ones up)
#41 |
Site Moderator
Drives: Stuff
Wrong? I guess nothing, but here's what I don't like about them personally:
1. I've had them come loose a bit before, so instead of just checking the wheel's lug torque you have to remove the wheel and check the spacer, then put the wheel back on and tighten/check them. 2. Depending on spacing, you may need a really high offset wheel to keep the wheel and tire inside the finder, or close to flush... I don't stretch tires so I want clearance for the tire. 3. They place additional load on the wheel bearings (which if the 5x100 Subaru bearings are really as bad as some say, you could experience accelerated bearing wear due to the spacers/spacer adapters).
-Dave
#42 |
(=^・ェ・^=)
Drives: 2013 FRS, '08 GSXR 600
All those juicy mods and they couldn't have changed that ugly antenna to a shark fin one lol
| New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 584 | 08-28-2023 08:53 PM |
| Official FT-86 Specs / Info Thread | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 203 | 09-09-2019 10:43 PM |
| Greddy Scion FR-S Coverage from FR-S reveal night | Harinjo | Scion FR-S / Toyota 86 GT86 General Forum | 90 | 01-14-2012 12:02 PM |
| Scion FR-S Reveal - Interview, GReddy & GT5 Data logger | NikostC | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 12-05-2011 11:34 PM |
| Greddy Set to Build Scion FR-S for Ken Gushi in 2012 | Kids Heart | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-29-2011 09:22 AM |
