Old 07-09-2013, 12:57 PM   #1
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
RCE tarmac 0s.. how do you dial in front camber?
Hey guys,
My plan is to run the RCE tarmac 0's with some 18 x 9.5 +40 TE37SLs with 245/35/18 tires.
Since the tarmac 0's do not come with camber plates, how do you adjust the front camber? Been doing research and from what I see, people need about -2.0 degrees of camber up front to make the 245/35/18 fit without rubbing.
Myles responded, saying that the slotted struts would allow me to dial in front camber without plates, but I am not sure how that works.. does anybody have a pic to illustrate this?
Thanks in advance!
Brian
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
Old 07-09-2013, 01:43 PM   #2
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
I am guessing the front camber bolts is what he is referring to.
UnOvertime is offline   Reply With Quote
The Following User Says Thank You to UnOvertime For This Useful Post:
brianlo622 (07-09-2013)
Old 07-09-2013, 02:01 PM   #3
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Stole this from a different forum, but here is an example of a slotted strut. You can easily see it comparing the upper and lower holes.
The slotted design will allow you to run an eccentric camber bolt to adjust the camber
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
The Following User Says Thank You to RallySport Direct For This Useful Post:
Old 07-09-2013, 02:09 PM   #4
brianlo622
brianlo622's Avatar
Thanks Rick that was a clear illustration indeed
So I have to purchase some aftermarket front camber bolts, like the ones from whiteline?
Brian
悪魔のハチロク
Old 07-09-2013, 02:31 PM   #5
cnk
Drives: '13 DGM BRZ Limited
You don't have to get camber bolts since the top holes are slotted. You can keep the stock bolt and the slots will allow some adjustment. That's how my KW V3's were adjusted on the front.
The Following 2 Users Say Thank You to cnk For This Useful Post:
brianlo622 (07-09-2013), Sportsguy83 (07-09-2013)
Old 07-09-2013, 02:34 PM   #6
ayau
Drives: Some rust bucket
Brian
I don't think camber bolts will do anything if the slots are really wide. You're better off getting the OEM crash bolts. They're thinner than the OEM bolt and it will allow even more camber.
The Following User Says Thank You to ayau For This Useful Post:
Old 07-09-2013, 02:51 PM   #7
OrbitalEllipses
Drives: Attitude
What @ayau said. Myles recommends the OEM bolts.
Old 07-09-2013, 03:06 PM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I wonder if they're available with RCE's pimpin' camber plates.
Old 07-09-2013, 03:54 PM   #9
UnOvertime
UnOvertime's Avatar
I just took mine for an alignment with no camber correction front or rear, but I am running stock wheels still. I need to decide if I am going to stick with 17's or move to 18's soon. Guess that will depend on whether I decide to go turbo or not...
Old 07-09-2013, 03:59 PM   #10
brianlo622
brianlo622's Avatar
Thanks guys.
So this is the ride height I am trying to achieve (This is speed element's FRS, on the same spec wheels and tires, but running some form of prototype coilovers)
How low do the RCE tarmac 0's go? Is this height achievable with the tarmac 0s? By all means, I want to go with RCE/KW over stance or BC if possible.
Thanks in advance.
Brian
悪魔のハチロク
Old 07-09-2013, 04:17 PM   #11
UnOvertime
UnOvertime's Avatar
I am at 1.25" all around and there is some room left, but not a lot. I think the 0's can probably hit 1.5" I can take a picture of mine if you would like and show you what the 1.25 looks like on stock wheels.
Old 07-09-2013, 04:19 PM   #12
brianlo622
brianlo622's Avatar
Could you please? that will be great. thanks buddy!
悪魔のハチロク
Old 07-09-2013, 04:21 PM   #13
cnk
This is with a 1" drop all around:
The Following User Says Thank You to cnk For This Useful Post:
Old 07-09-2013, 04:45 PM   #14
UnOvertime
UnOvertime's Avatar
1.25" all the way around.
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 589 11-21-2021 04:13 PM
***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** FT-86 SpeedFactory Brakes, Suspension, Chassis 208 09-30-2016 03:43 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 05:31 PM
SPC/Whiteline front camber bolts in GTA? f0rge CANADA 2 03-20-2013 10:56 PM
