Old 07-09-2013, 01:53 PM   #155
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by jamesm View Post
I was worried about that as well when I first got my turbo. I did some logged runs with the gas light on WOT and didn't notice any change if the afr or anything. Not to say its 100% ok, just that low fuel doesn't immediately cause any issues under WOT.
As long as you watch the logs but I would still be weary. Anything could happen and having fuel in the car is playing it safe. Safe is better than costing a motor IMO.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 07-09-2013, 01:57 PM   #156
xxscaxx
Drives: 2013 SWP BRZ
I think the concern is while in turns with low fuel, seeing as the "hump" design of our fuel tanks have caused fuel starvation issues.
I was just being an ass btw, I wasn't really calling out @sw20kosh lol
xxscaxx is offline   Reply With Quote
Old 07-09-2013, 02:01 PM   #157
jamesm
i usually keep it above 1/2 tank in any case, i was just sharing what i've found in the limited testing i've done to reassure myself that if i were to get low on gas and need to make it to a station it's not an immediate issue.
another thing, sort of related but off topic, that i've noticed is that if i run it down to the gas light then put a small amount in, say $5 worth, it doesn't register at all on the gauge. the other day i put $5 in twice from the low fuel light being on just to see if it'd register and it didn't until i added a further $10 worth, when it jumped up past half tank. maybe because of the hump?
Old 07-09-2013, 02:17 PM   #158
sw20kosh
Drives: 2013 Black FR-S
After doing those runs last night (0-100) and a few 0-60's I filled up my tank.
Only issue now is my Deatschwerks Fuel Pump has gotten loud. I wonder what that means? I hope it isn't on the edge of dying... It is brand new.
Old 07-09-2013, 02:21 PM   #159
evo4g63
evo4g63's Avatar
Hmmm? I am still skeptical about the fuel pump upgrades as of right now due to the issues of others failing. I would have left the stock pump in place for the time being until further testing and proven results have been done. Be careful buddy is all I am saying.
-2016 Subaru WRX
Old 07-09-2013, 03:25 PM   #160
Dezoris
Dezoris's Avatar
But the most important thing is.... Supercharger whine galore!!!!!!
That's an excellent video for comparison, it seems to be exactly where it should be. I was comparing it to the Vortech videos I have side by side and they seem very close. In person delivery is different obviously.
The Following User Says Thank You to Dezoris For This Useful Post:
ftc~brz (07-09-2013)
Old 07-09-2013, 03:46 PM   #161
canu_50
canu_50's Avatar
Drives: Scion fr-s
deatchwerks never been known to be a good company when it comes to fuelling solution...
I have always try to stand away from their injectors and fuel pump, which is why i will probably do my own fuel set up using aeromotive pump!
Can't wait to put my name on the list, i am waiting for my parts guy to give me the final pricing, and then i will be part of you guys !!!
canu_50 is offline   Reply With Quote
Old 07-09-2013, 03:47 PM   #162
sw20kosh
Cool!
I definitely think the 0-60 could be way better with a proper driver. I'll try launching at 3k rpms rather than 4k.
Old 07-09-2013, 04:01 PM   #163
Dezoris
Dezoris's Avatar
Cool!
I edited the side by side video...
From second gear through 3rd...
Vortech vs. Innovate...
What do you think was faster?
Old 07-09-2013, 04:14 PM   #164
Dezoris
Dezoris's Avatar
@sw20kosh do you mind if I use your video to do a side by side?
I am not going to skew it in favor of either going to start from 2nd gear and up to take the launch out of question:
I won't post it until you say its ok.
The Vortech was using a base map the 212HP setting.
They are almost identical except the Innovate pulls in the midrange ahead, and then the Vortech pulls back at the top. Its almost a wash.
Well except the Innovate sounds like you have a supercharger!
The Following 4 Users Say Thank You to Dezoris For This Useful Post:
s2d4 (07-09-2013), sw20kosh (07-09-2013), swift996 (07-09-2013), TemeCal (07-09-2013)
Old 07-09-2013, 04:20 PM   #165
s2d4
s2d4's Avatar
Not surprising at all, everything indicates that'll be the behavioural difference between the two. I'll pick the one with more torque over a wider rpm range for sure.
Old 07-09-2013, 04:25 PM   #166
TemeCal
Drives: 86
Not only that, but hearing all of the installation pains of the Vortech...and now the belt issues (idler pulley, intake tube rubbing, etc...), the Innovate kit is looking much more appealing.
TemeCal is offline   Reply With Quote
Old 07-09-2013, 04:26 PM   #167
Dezoris
Dezoris's Avatar
It is interesting because you see the video slowed down and at the lower speeds 50-65 the Innovate looks faster, then at the high rpm the innovate is running out of steam while the Vortech is pulling stronger. Then the shifts take place and that pattern happens all over again. Like you said makes sense right?
Old 07-09-2013, 04:35 PM   #168
Dezoris
Dezoris's Avatar
I want to clear something up about this issue.
The Vortech kit has about 20x the ownership base, more miles, more long term testing more transparency.
There are maybe 7-10 owners who have the Innovate installed and posting, probably half are vendors. Not once has anyone posted any logs or data aside from base dynos. Your largest tuners don't even have enough people with the kit yet to start tuning properly. (Soon)
It is also non-intercooled, and thats a big question mark, namely without testing or logs being supplied. Point is the grass is greener you won't know about the bugs of the Innovate kit for months.
akuhei (07-09-2013), brybot (02-26-2016), Darryljr11 (07-09-2013), ftc~brz (07-09-2013)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
