Old 07-05-2013, 02:01 PM   #127
Ben_G
Drives: Blue BRZ
Originally Posted by sw20kosh View Post
3.) Snow Performance supercharger bypass valve boost solenoid (to open the bypass when there is faulty flow)
4.) Eaton bypass actuator with two vacuum ports (you need this to make the snow performance boost solenoid work)
When failsafe is triggered the bypass valve opens and only allows supercharger to make a max of 2 psi untill you shut off the engine and restart.
Noob question, I'm assuming that the bypass valve is to prevent overboost....but what conditions would cause that to happen? Or is my original assumption wrong?
Ben_G is offline   Reply With Quote
Old 07-05-2013, 02:14 PM   #128
sw20kosh
Drives: 2013 Black FR-S
The superchargers boost is limited by the pulley not the bypass. The bypass is used for idle and light throttle cruising. Puts less drag on the motor since the supercharger is not being asked to compress air underneath it. It equalizes the pressure pre and post sc.
Old 07-05-2013, 02:27 PM   #129
Ben_G
Drives: Blue BRZ
ok....that makes sense.... but then in what circumstances would you need a failsafe? The OP says it's to protect against faulty flow, but I don't understand how that could happen? Sorry, hope that's not too basic.....
EDIT - HA! didn't realize you ARE the OP! =)
Old 07-05-2013, 03:01 PM   #130
Ben_G
Drives: Blue BRZ
I just reread your original post...and clicked the links
Failsafe monitors the water injector flow.... if water injection stop, the bypass is activated so that lack of water injection doesn't create a condition where you're boosting higher than you can without water, right?
Old 07-05-2013, 09:08 PM   #131
sw20kosh
Your on the right track! The supercharger system is set to whatever psi the pulley allows. In this case 7. With water meth injecting you can advance the ignition timing a bit to gain more power. This advance would cause knock during no meth spray.
If the meth were to not flow properly, the failsafe protects your engine from knock. It limits boost to 2 psi. Even with ignition advanced (for the meth spray)... 2 psi will not blow your engine. My ecu map is also set to not advance timing untill at least 4.5 psi is seen and a certain amount of load is present. These conditions were selected because these are also conditions when the water meth is injecting.
Old 07-05-2013, 09:36 PM   #132
sw20kosh
At the dyno. 3 other 86's here!
I really like this white BRZ!
The Following 4 Users Say Thank You to sw20kosh For This Useful Post:
DriftZen (07-06-2013), mines13 (07-06-2013), Opposed (07-05-2013), Sportsguy83 (07-05-2013)
Old 07-05-2013, 10:05 PM   #133
Ben_G
Drives: Blue BRZ
Ahhhh! Got it! thanks for the patience explaining it all....
Old 07-06-2013, 01:14 AM   #134
sw20kosh
The new meth tune delivered 40 more horses. Yum. Im officially a meth addict lol
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
Pete (07-07-2013), swift996 (07-06-2013)
Old 07-06-2013, 01:37 AM   #135
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Nice wheels, sw20kosh.
mines13 is offline   Reply With Quote
The Following User Says Thank You to mines13 For This Useful Post:
sw20kosh (07-06-2013)
Old 07-06-2013, 07:26 AM   #136
mad_sb
Drives: 2013 Asphalt FR-S
same pulley or with the smaller (higher psi) pulley?
Old 07-06-2013, 10:13 AM   #137
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I'm curious about daily-driving logistics with a kit like this. I had a 6psi boost-activated setup for the I/C sprayer in my STI and I would go through a tank of water rather quickly if I left it on all the time.
With a W/M system, do you have two tunes; one with, one without? If you're not switching, how do you conserve your meth? Just stay off the loud pedal?
Old 07-06-2013, 12:33 PM   #138
sw20kosh
Same pulley.
Old 07-06-2013, 12:36 PM   #139
swift996
swift996's Avatar
Same pulley.
Dyno!
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-06-2013, 12:37 PM   #140
sw20kosh
I do have two tunes. Been running on the meth tune mostly so I can stress/longevity/reliability test it. I've gone through maybe 3 gal in a month but keep in mind I've been playing around with boost.
It obviously lasts a long time when you are just commuting etc.
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 12:49 AM
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! Visconti Forced Induction 67 04-03-2013 03:56 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
