Old 07-01-2013, 10:58 PM   #1
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
BRZ Headlight Swap
I know this has been discussed many upon many times. Yet I just want to know one answer before I buy BRZ headlights.
Does anyone know if the FRS has a plug for the headlight leveling switch behind the dash? I know there is a taped plug behind the dash. I believe it may be for the USDM fog lights that were just released.
Someone on this forum already installed the BRZ headlights yet has not posted his DIY yet. I know there are many individuals that have done this swap.
Thanks in advanced.
AVodka14 is offline   Reply With Quote
Old 07-02-2013, 02:55 AM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
no
Old 07-05-2013, 11:20 PM   #3
r4m3n
r4m3n's Avatar
Drives: Ultramarine FR-S
Found this on gt86 dot com dot au
http://*************/forum/f22/brz-h...progress-2132/
6.4.12 | Ultramarine | SoCal
r4m3n is offline   Reply With Quote
Old 07-06-2013, 02:55 AM   #4
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Originally Posted by r4m3n View Post
Link doesn't work.
FRSfan111 is offline   Reply With Quote
Old 07-06-2013, 06:13 AM   #5
r4m3n
r4m3n's Avatar
Originally Posted by FRSfan111 View Post
Link doesn't work.
the forum doesn't allow me to add the full url link so that's why u need to enter:
"gt86 dot com dot au" before the rest of the above link :P
Old 07-06-2013, 03:05 PM   #6
AVodka14
AVodka14's Avatar
Great! Thanks for the link! In the process of reading. I have pretty much got this swap figured out. I will post up a completion of the swap when finished. I called fastWRX.com today and they confirmed the plug behind the dish for the headlight leveling switch.
Old 07-06-2013, 03:26 PM   #7
AVodka14
AVodka14's Avatar
Just need confirmation of plug behind dash for level switch. Got verbal confirmation by fastWRX yet I want to see a pic. Thanks guys!
Old 07-13-2013, 07:04 AM   #8
AVodka14
AVodka14's Avatar
Bump. Can anyone confirm leveling switch behind dash for FRS?
Old 07-13-2013, 10:58 AM   #9
AVodka14
AVodka14's Avatar
Let me clarify my statement above to anyone that has done this swap. Is there is a plug for the leveling switch behind the driver's side dash?
Old 07-13-2013, 03:54 PM   #10
AVodka14
AVodka14's Avatar
You can see the fog light connector pulled away from where it was taped. Looks like there is no connector for the manual leveling switch for the BRZ headlamp. Even though there is anecdotal evidence stating otherwise.
Old 09-22-2013, 10:56 AM   #11
AVodka14
AVodka14's Avatar
Bump. Anyone have any information on the swap (i.e. DIY, feedback, etc.)? I will be performing this soon and will make a DIY otherwise.
Old 09-22-2013, 07:44 PM   #12
Cridland
Cridland's Avatar
Drives: 2013 Whiteout FRS
please make a DIY!
Cridland is offline   Reply With Quote
Old 09-23-2013, 12:17 AM   #13
AVodka14
AVodka14's Avatar
I will. Thinking about doing this before it gets too cold.
The Following User Says Thank You to AVodka14 For This Useful Post:
Cridland (10-08-2013)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 04:32 PM
Headlight Swap - FR-S -> BRZ Acree Southwest 2 12-21-2012 09:44 AM
BRZ Headlight Swap? ThePoet Cosmetic Modification (Interior/Exterior/Lighting) 2 11-19-2012 02:46 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 03:45 AM
