#29 |
Drives: Viper, Mustang, FD RX7, FFR GTM
Did the factory have the same goal in mind as people that want to boost a internally stock 12.5:1 na engine and double it's output on pump gas?
#30 |
Switch the factory cooling fans from cycling at 212F to 200F or hardwire a switch and call it a day. That or buy a $300-400 radiator, problem solved.
#31 |
#32 |
Have you ever said why you need it that low? What is your real application?
#33 |
#34 | |
I wont argue with you except to say, regardless of what you think is better for this engine the ECU still controls power delivery. And it is finicky about coolant temps that are too high and too low. So if you believe lower is better, below 175 the ECU will trim power. Since there isnt a lower temp tstat, flipping coolant fans to always on will drop your temps by 10 degrees, and more in clean air. Which would put you at about 180 to 185F NA. Larger radiator in clean air will put you at 180 most of the time with fans. So there is more than one way to handle it.
#35 |
Drives: Passat
This one is a little pricey but it should do the job for those who know WTF they are doing.
http://www.ebay.com/itm/SARD-SUBARU-...item4ac0fdc131 |
#36 |
Drives: Rocket Bunny'd GT86
I think what the OP has meant is that here in Dubai it gets super friggin hot and we're worried about higher engine temperatures in the afternoon would reduce engine horsepower since the air intake would be much hotter than usual (yes I've seen differences between summer and winter pulls). There is a difference that you'd notice but has nothing to do with lowering the coolant's temperature, on the contrary I think the engines would perform much better on the temperature it was designed to run fully efficient at. I think what we should be looking for is somewhat a colder air intake design to help get more colder air into the intake (like snorkels on 4 wheel drive cars).
#37 | |
That's a ridiculous price for a Tstat |
#38 | |
Drives: 2013 Asphalt FR-S
Your probably better off to get a tune that will turn the fans on at a lower temp :happy0180:
~Namaste~ |
#39 | |
When you sit at idle (not moving) the intake air temp climbs quickly due to convection from the condenser and radiator and the location of the snorkel inlet. But, once you start moving temps quickly drop to a few degrees above ambient. at 120*f ambient, the ecu will pull roughly 2 degrees ignition timing. At 160 it will pull 6 degrees. sitting at a stop light in 120 ambient temps the intake temp will probably climb to 160 so it will feel slugish when you leave from a stop. Nothing you do with the thermostat will change the intake air temps. Turning the fans on sooner might help though. I'll have to do some logging and see what happens to iat (at a stop) when the fans kick on.
~Namaste~ |
#40 | |
Thanks! |
#41 | |
#42 | |
Do you guys have E85? I think those that want to run cooler thermostat can do so with some benefit, assuming all of the coolant temp related tables in the rom are adjusted so the new lower temp becomes the "normal" temp. My original point was that just dropping in a cooler t-stat without adjusting the rom is not going to do much other than cause a wider range of operating temps.
~Namaste~ |
