| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Thumper
Drives: 2013 FRS
Wider tire on stock rim..pics
This isn't exciting or anything but...
I did not like the noise, ride, or narrow look of the stock tires so I did a little research and found what I wanted. Hankook Ventus v12 evo - numerically the same values as stock but the physical dimensions are much more appealing. Overall height appears to be identical to the stock tires but the contact patch/width is about 3/4" wider. The tire looks more square. I just installed them today so I don't have much road time but just the feel at cruising is much better. The pressure needs to stay between 35-38 psi cold, otherwise it gets too rubbery and unsettled. Forward grip has improved dramatically(harder to spin) but I have not been able to test much with lateral grip besides side-to-side motion on the road. Ignore the black shavings..had to peel the plasti dip off my rims since it was damaged during install...pita ![]()
Car is gone - parts for sale
| The Following User Says Thank You to 6speed_Sam For This Useful Post: | Clipdat (07-04-2013) |
#2 |
? re: comparion pix
Thanks for the post and pix. 2 questions... in the side-by-side pix, is the OEM tire on left mounted (on a wheel)? 2) I'm guessing the OEM tire shown doesn't have any weight on it (from car) - right?
2013 Asphalt / MT
Olympia, Washington |
#4 |
Drives: TRD Ultramarine '13
#5 |
Drives: 86 GTS
He mentions " numerically the same values as stock" so I'm guessing still 215
Depends on the make too, I've had 215/45 Michelins in the past and 215/45 Bridgestone RE002 on a 8" wheel and the Mich were stretched and the RE002 looked liked a track tire |
#6 |
Drives: Sterling BRZ Ltd
actual width varies brand to brand. Kind of annoying but often more sport orientated tires are pretty generous on there sizing numbers.
#7 |
Shorter of breath
Drives: a soft bargain
Use the Tire Rack's web site; they list tread widths for most tires.
215/45-17 seem to range from about 7.4-8.4 inches, although section width is the same for all (8.5 inches, IIRC). |
| The Following User Says Thank You to Admiral Ballsy For This Useful Post: | Juvenile (07-06-2013) |
#8 |
My 205/50/17 snows are physically wider than the stock 215/45/17's by a few mm, and my 225/45 Z2's are MUCH wider than stock, more like an inch.
#9 |
Drives: fr-s
This was taken from my old forum VipStyleCars.com credit goes to them
SMALL:
TRUE:
LARGE:
| The Following 4 Users Say Thank You to executivekoala For This Useful Post: |
#10 | |
Thumper
Drives: 2013 FRS
The oem tire on the left is not on a rim. But, I did have them sided by side in the shop(both mounted and not on the car) and it appeared to look the same as in this pic. The Hankook is definitely wider.
#11 |
Thumper
Drives: 2013 FRS
#12 | |
Thumper
Drives: 2013 FRS
From what I could tell the new tires are a tiny bit shorter in appearance. I used 2 different gps before and after install and now it seems I'm going a mph slower(at 65) than what the speedo says...which is fine.
| WTB: One stock tire in LA | hapa_kcm | Wheels and Tires | 0 | 05-17-2013 10:57 AM |
| More stock pics. My Raven FR-S with graffitti background. Sick Pics | Hardrock4445 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 11-11-2012 11:29 PM |
| Question for everyone who has gone 8.25" and wider | SkAsphalt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-05-2012 03:46 PM |
| Better to go wider or lighter? | BRAWL | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 08-02-2012 09:48 PM |
| Looks wider than it is | Sigh-on-Rice | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-11-2012 08:15 PM |
