Old 07-04-2013, 07:04 PM   #57
Visconti
Drives: 05 STi
Does anyone know if the ethanol content now displays in torque or is there a custom pid needed?
Sent from a hamburger
Custom PID
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
Yruyur (07-04-2013)
Old 07-04-2013, 07:33 PM   #58
Rich@ViscontiTuning
Drives: 2012 VW GLI
Happy Fourth of July to all of our awesome, freedom lovin’ American Customers!!
We wish everyone a happy & safe holiday weekend!
(Don’t worry though – we’ll still be around )
-Visconti Tuning
Rich@ViscontiTuning is offline   Reply With Quote
The Following User Says Thank You to Rich@ViscontiTuning For This Useful Post:
Yruyur (07-04-2013)
Old 07-04-2013, 07:45 PM   #59
Yruyur
Yruyur's Avatar
So lets say the ethanol sensor stops communicating with the ecu for one reason or another. Does the tune default to a certain map?
Old 07-04-2013, 08:01 PM   #60
Visconti
Drives: 05 STi
Boom
Old 07-04-2013, 08:10 PM   #61
Yruyur
Yruyur's Avatar
So use solder is what your saying.
Old 07-05-2013, 06:49 AM   #62
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Just curious - should I be looking for a hot 12v source or a switched 12v source for this? Thinking switched, but I wanted to be sure.
mikalem is offline   Reply With Quote
Old 07-05-2013, 09:15 AM   #63
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
That's a good question. I think we used hot but I'll have to wait for @cobrabyte or @Visconti to confirm.
post_break is offline   Reply With Quote
Old 07-05-2013, 10:06 AM   #64
Sensisnow
Drives: 05 TSX & 13 BRZ
I tapped into the radio, which is switched. If you tap into a hot 12v the display would be on even with the car off.
Sent from my Galaxy Nexus using Tapatalk 4 Beta
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1
Sensisnow is offline   Reply With Quote
The Following User Says Thank You to Sensisnow For This Useful Post:
Yruyur (07-05-2013)
Old 07-05-2013, 11:09 AM   #65
mikalem
mikalem's Avatar
After poking around some of the other DIYs I ended up using the 15amp fuse (left side closest to you) which seems to be switched as well. Sensor is up, just waiting on the ECU harness to finish out the wiring, then I sit and wait for a tune to head over to the local E85 pump
The Following User Says Thank You to mikalem For This Useful Post:
Sensisnow (07-05-2013)
Old 07-05-2013, 01:15 PM   #66
mikalem
mikalem's Avatar
Originally Posted by cobrabyte View Post
Looks good. The ECUtek parameter for logging is 'Custom Map F Result' (if I remember correctly).
Is this only true of the Flex Fuel tune? I have everything wired up and went to fire up the car with the 1.14 STG2 pumpgas and I'm throwing a CEL and Custom Map F Result is zeroed out completely, while the readout states E 11 (makes sense with the 93 around here having at least 10% ethanol in it). Wondering if I just need the new tune to verify wiring, or if something else is screwed up.
Old 07-05-2013, 01:20 PM   #67
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
I imagine you'll need the tune since @Visconti is repurposing another sensor's feed for ethanol content. The CEL is probably being kicked-off due to the ethanol content sensor sending data that's outside the range for whatever sensor was overridden.
cobrabyte is offline   Reply With Quote
The Following User Says Thank You to cobrabyte For This Useful Post:
mikalem (07-05-2013)
Old 07-05-2013, 01:58 PM   #68
Yruyur
Yruyur's Avatar
Anyone got a pic of the fuel tool. I have a feeling im missing that too.
Old 07-05-2013, 02:03 PM   #69
Sensisnow
If you look at at the photo in the first post, it's the small gray circular piece near the top middle of the picture.
2013 DGM BRZ
Yruyur (07-05-2013)
Old 07-05-2013, 02:07 PM   #70
Yruyur
Yruyur's Avatar
Aww sweet I do have it. Didnt think that was a tool.
campaign: ban jv, diy, e85, fuel leak, kit, laughing to the bank, oh lord jesus its a fire, visconti, viscontifried, viscontinued
Flex fuel testing Dynotronics1 Southwest 5 06-22-2013 03:27 PM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 11:04 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Cheap flex fuel? nix Engine, Exhaust, Transmission 1 05-11-2013 04:05 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
