Drives: 2013 white brz
Another Coilover noise thread..
So i have fortune 500's. Never had a problem, until recently both sides started making noise. I checked the preload, tightened the collars, tightened the top hat bolts, tighted the top strut nut. All other bolts *sway bar/shock bolt ext are tight. I'm literally clueless as to what the noise could be. It will randomly make a clunking sound. It'll happen on bumps/flat roads/inclines ext. Its just totally random when it happens. And its just the rears. Fronts i've had no problems with it.
#2 |
Just a dude
Drives: Scion FR-S 2013
Stock top hats and have the washers from subaru installed?
#3 |
thats what im thinking of trying
#4 |
Drives: 2013 FRS 6MT Firestorm
I have this same problem as well on fortune 500s. Havent figured it out yet
#5 |
Its so frustrating. I've tried raising it up more, preloading alittle more, retightening all the collars/tightening all the bolts/ redoing the top hat nuts/ and the strut nut. Im clueless to what it could be.
#6 |
Usually I hear a clunk after hitting a bump and the rear comes back down. But today I heard it again when taking a sharp right turn semi-quickly. I'll check the stock rear sway as well at the same time.
#7 |
lmk if you figure anything out. Mines getting super annoying lol
#8 |
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
I've had the 500s for about 7 months now. I had some clunking... tightened the bolts and everything on them. still had it. Turned the damping up from full soft and haven't heard it since. I also autocross on them. Going over large bumps, they are noisy, but that's just metal on metal since they don't use the rubber top mounts.
Only issue I had was with the radial bearings drying out, but that was expedited due to DDing through the winter (salt). |
#9 |
I was planning on turning them a little stiffer from full soft anyways so hopefully that helps
#10 |
The fortune auto rep told me the rears have a rubber top mount? I'm going to dive back in into it today. And see what i can find out
#11 |
Drives: '13 BRZ | '04 E55
I had a loose strut nut that caused clunking over bumps with mine.
I also had coil bind at low speed turns. I sprayed some lube in the spherical bearings in the top hats of the front coilovers and it went away in a few days.
#12 |
sorry for the new question. But coil bind? i've heard it before, what exactly is that?
#13 | |
That resistance between the spring and what it rests on. Fortune Auto sells roller bearings to alleviate this issue as well for $50 I believe. They have a good explanation on their website. The roller bearings allow the top hat to move independently of the rest of the coilover when turning.
#14 |
well that'd explain that noise.. But the clunking and stuff im kind of baffled. Fortune wants me to send them in and be "looked at". But i hafta pay shipping and be without my car for god knows how long. And they may determine nothings wrong with them. And i'll hafta pay to have shipping back.
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| *--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 95 | 01-30-2013 07:48 PM |
| Kronos Coilover/Spring MEGA THREAD! Special Prices inside! | KronosPerformance | Brakes, Suspension, Chassis | 46 | 09-09-2012 08:22 PM |
