Old 07-03-2013, 09:13 AM   #43
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Originally Posted by Shaun. View Post
What would a reasonable amount be to pay someone to install it the kit? Seems a little daunting to me...
A shop's going to probably charge you an hourly rate and, conservatively, they're going to estimate 5 to 6 hours to complete the job.
You may look for regional members on the forums that may be willing to help you with the install. You're no where near us or I'd say drive it on over and we'll get it done. I'm sure you'll find more members that are willing to do the same.
cobrabyte is offline   Reply With Quote
Old 07-03-2013, 01:18 PM   #44
Sensisnow
Drives: 05 TSX & 13 BRZ
Where are you located?
Sent from my Galaxy Nexus using Tapatalk 4 Beta
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1
Sensisnow is offline   Reply With Quote
Old 07-03-2013, 09:23 PM   #45
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
Did anyone else get a CEL after unplugging the ECU cable harness?
Need some clarification on the ECU harness, the plug to the lowest facing me does not fit the socket so I moved the cable to the 3rd last slot.
iketiak is offline   Reply With Quote
Old 07-03-2013, 09:26 PM   #46
Visconti
Drives: 05 STi
3rd slot, only fits in one
Visconti is offline   Reply With Quote
Old 07-03-2013, 10:47 PM   #47
JiB
JiB's Avatar
Drives: GT86
Has anyone installed yet without the harness?
JiB is offline   Reply With Quote
Old 07-03-2013, 11:22 PM   #48
Shaun.
Drives: '13 Silver BRZ Limited MT
Thanks, I may do that
San Diego. May be a while before I purchase the kit, though.
Shaun. is offline   Reply With Quote
Old 07-04-2013, 05:20 AM   #49
mkivsoopra
Did I install this correctly? It was surprisingly easy. I didn't remove any panels, glovebox, or disconnect any other plugs. Just stuck my head under there, undid the 3rd plug, connect green harness to ECU, then chassis harness to the green harness.
Also, what parameter do we look for in the logging screen to verify that it's getting the data?
Thanks,
Garland
mkivsoopra is offline   Reply With Quote
Old 07-04-2013, 05:24 AM   #50
Sensisnow
Thanks,
Garland
Yep, looks good to me!
2013 DGM BRZ
Old 07-04-2013, 05:39 AM   #51
mkivsoopra
BTW, great write up, @post_break!
Note to everyone: make sure all the fuel line AN fittings are tight, even the ones that appear to be pre-tightened from Visconti. One of mine was hand-tightened and leaked fuel
Old 07-04-2013, 06:38 AM   #52
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
Great write up & photos @post_break
I take it this DIY is the official install guide for the kit? If so, would be great if you can show us non-harnessed peeps where to tap for the 12V/ground and that white wire to the ECU.
enouf is offline   Reply With Quote
Old 07-04-2013, 08:06 AM   #53
cobrabyte
cobrabyte's Avatar
Thanks,
Garland
Looks good. The ECUtek parameter for logging is 'Custom Map F Result' (if I remember correctly).
Old 07-04-2013, 08:09 AM   #54
cobrabyte
cobrabyte's Avatar
We're going to be installing @post_break's kit this weekend (hopefully) and those two items are definitely on the agenda to cover. We began to lose light during my install and couldn't see striped wire colors all that well with the flashlight we were using. I had already tapped for a dashcam and winded up using the same 12v/ground connections.
I'll have to get with John @Visconti to see which wire is to be tapped on the ECU harness side for that white wire.
Old 07-04-2013, 02:56 PM   #55
mkivsoopra
You're right! I'm getting the data feed Thanks
Old 07-04-2013, 03:59 PM   #56
Yruyur
Yruyur's Avatar
Does anyone know if the ethanol content now displays in torque or is there a custom pid needed?
Sent from a hamburger
campaign: ban jv, diy, e85, fuel leak, kit, laughing to the bank, oh lord jesus its a fire, visconti, viscontifried, viscontinued
Flex fuel testing Dynotronics1 Southwest 5 06-22-2013 03:27 PM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 11:04 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Cheap flex fuel? nix Engine, Exhaust, Transmission 1 05-11-2013 04:05 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
