Old 07-02-2013, 08:06 PM   #15
Chauntalei
Drives: Non-BRZ
Originally Posted by aranami View Post
They're the round ones... so they are fog, and they aren't supposed to be running when I have them set to off?
Correct, the round ones in the corner of the fenders, down at the very bottom are the fogs. The stalk setting should look like this, if they are switched off (apologies for low lighting, pic taken in a parking garage at work):
Chauntalei is offline   Reply With Quote
Old 07-02-2013, 08:30 PM   #16
aranami
Yup, that's how my stalk settings look. They only come on when I'm moving. I took it by the dealership and they claim it's functioning as intended. They told me they aren't actually fog lights, they're dtrl's like others have pointed out to me. I can never tell how much truth I'm hearing at the dealership, though.
aranami is offline   Reply With Quote
Old 07-02-2013, 08:33 PM   #17
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Send a picture so we can end the confusion. I'm guessing they are the DRLs
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 07-02-2013, 08:44 PM   #18
Chauntalei
Drives: Non-BRZ
If it's the vertical bar of LED's, right above the round light, those are the DRL's.
The bar along the top are the DRL's, the round light is the fog light
The TOP bar should come on when you are moving, that's correct. The BOTTOM light should not, and if it is, and the stalk is turned off, something is busted.
Old 07-02-2013, 11:45 PM   #19
infinite012
Drives: 13 DGM BRZ Ltd
Horizontal, not vertical.
But anyways, I still can't really see why this is a thread.
infinite012 is offline   Reply With Quote
Old 07-03-2013, 12:03 AM   #20
dsgerbc
Drives: BRZ(sold), STI
Wow, 90% of the tread posters assume that OP is a stupid hobo. Must be annoying.
Driving around day or night, with my lights set to off or auto, my fog lights are shining bright.
DRLs go off at night, people.
Sounds like a genuine problem. I think your Fog light relay is stuck in ON position. There's no easy way to access it, so take it to the dealer.
The Following User Says Thank You to dsgerbc For This Useful Post:
WolfpackS2k (07-25-2013)
Old 07-03-2013, 10:06 AM   #21
aranami
Well, as much as I'd like to say they were wrong to assume I'm a stupid hobo, they're not. It's the horizontal bar, I just couldn't tell correctly when seeing it through the reflections of other folks cars. You're right though, generally people should not treat others like they're idiots -- I just happen to be a genuine idiot.
Still, my DLRs are staying on at night so I'm going to take that in to get it looked at.
Thanks for the assistance, folks!
Old 07-03-2013, 10:11 AM   #22
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Not if the headlights are off.
Admiral Ballsy is offline   Reply With Quote
Old 07-03-2013, 01:11 PM   #23
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
The DRL stay on if your parking lights are on but not your headlights. (I believe.). I'm not actually sure now at night... I've read you can't have your headlights, fog lights, and DRL on at the same time. You can run your parking lights ("halo's") and DRL at the same time.
ashtray is offline   Reply With Quote
Old 07-03-2013, 01:25 PM   #24
Admiral Ballsy
Shorter of breath
You never even looked at the lights?
Old 07-03-2013, 02:43 PM   #25
White64Goat
Old 07-04-2013, 12:47 AM   #26
aranami
Nope, the one time I tried, I put it in neutral, pulled the e brake, stepped out and nothing was on.
Old 07-04-2013, 12:49 AM   #27
Zgrinch
Zgrinch's Avatar
DRLs turn off when the parking brake is applied.
BRZGrincherhood
Old 07-04-2013, 06:18 PM   #28
aranami
Learning something new every day!
**PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) PhastekSport Exterior Parts - Lighting 18 07-09-2014 08:42 PM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 09:38 PM
Fog Lights encity5 Cosmetic Modification (Interior/Exterior/Lighting) 22 06-18-2012 10:00 PM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 08:29 PM
