Old 06-28-2013, 09:18 AM   #323
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by trueno86power View Post
Crap. I'm in the boat too. Wednesday on the track session I've got the P0351. No particular sound on start up or anything. Cleared it. Yesteday on my way to home I've floor it 3 to 4 WOT. Got it again...
Mods: Perrin EcuTek Flash - aFe Intake - Nameless Fontpipe/Axle back.
I hope the seals are ok
Trust me seals are not good and also check spark plugs as well
The Following User Says Thank You to whitefrs For This Useful Post:
Carwhisperer (06-29-2013)
Old 06-28-2013, 09:20 AM   #324
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Given the responses to this thread, hope isn't much of a plan. I would inspect the seals and replace the coil pack.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 06-29-2013, 11:09 AM   #325
regal
Drives: Scion FR-S/Toyota Yaris
Going on 7500 miles next month and due for state inspection. Do the dealers have the ECU update now or is it being held up by the EPA? Will just have the local mech do the inspection and diy the oil change if the dealers aren't flashing updates yet.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 06-29-2013, 03:16 PM   #326
Carwhisperer
Drives: A lot of supercars.
Originally Posted by reeves View Post
I just read through all 14 pages... good luck to all of you who've had this problem. But If you haven't had any symptons/issues of misfiring at this point (I'm up to 23K miles), you've got nothing to worry about right? I got an updated rom file from my tuner that's suppose to help prevent this issue, but how much help is it really at this point?
uh no, I was at 21k miles when it started with me. happened to 2 different injectors within a month of each other.
Carwhisperer is offline   Reply With Quote
Old 06-29-2013, 03:18 PM   #327
Carwhisperer
same code I got 2 days before I started getting the popping. Your 1st cylinder isn't getting enough fuel. Take it in SOON.
Old 07-01-2013, 12:25 PM   #328
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
P0351 came back yesterday with a noticable POP sound. Car stored in the garage and I'll bring it to the dealer soon... I'll update the process.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 07-02-2013, 04:46 PM   #329
415FRS
Drives: Red SCion FRS
So my car is supercharged and I am at around 11k miles. I started to hear those pop sound around 1 weeks ago. Where can I take to replace the seal since I no longer under warranty? And how much am i looking to pay? Thanks
Sent from my HTC One using Tapatalk 2
415FRS is offline   Reply With Quote
Old 07-02-2013, 05:15 PM   #330
Lonewolf
Lonewolf's Avatar
Drives: Moped
Did you install the s/c yourself or did a shop do it?
Works (or the place you got your s/c installed) should be able to do it if they order the seal replacement tool kit...
The Following User Says Thank You to Lonewolf For This Useful Post:
415FRS (07-02-2013)
Old 07-02-2013, 06:31 PM   #331
Calum
That Guy
Drives: 2013 asphalt FRS MT
I haven't been following this thread so sorry if this has been gone over. Has anyone had a seal go after the new ecu programming?
Old 07-02-2013, 07:07 PM   #332
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
No clue, but Im still getting a P0351 on track after flashing a new tune with the new tables.
GTM_Challenge is offline   Reply With Quote
The Following User Says Thank You to GTM_Challenge For This Useful Post:
Calum (07-02-2013)
Old 07-02-2013, 07:17 PM   #333
xjohnx
Grip>Slip
xjohnx's Avatar
but you were getting that before, right?
Old 07-02-2013, 07:25 PM   #334
GTM_Challenge
Drives: On track
Yes.
Old 07-02-2013, 08:11 PM   #335
Carwhisperer
Yes.
You ever Gotten P0456 ( very small emission leak ) and no it doesn't seem to be my cap. I've only gotten the P0351 once right before I started having the injector popping begin.
Old 07-02-2013, 08:24 PM   #336
415FRS
I had a friend helped me out with the installation of the Supercharger. I will contact WORKS soon to see if they have the tool to replace the seal. Thanks.
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 04:26 PM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 12:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 03:25 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
