Old 06-29-2013, 04:31 PM   #113
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by robispec View Post
Yes no problems
what clutch you using?
I will probably go with the Exedy stage 1 clutch kit.
xxscaxx is offline   Reply With Quote
Old 06-29-2013, 07:47 PM   #114
robispec
Drives: Black frs project
custom racing solution
robispec is offline   Reply With Quote
Old 07-01-2013, 06:08 PM   #115
DSLeach
Drives: None
Originally Posted by sw20kosh View Post
5 gal/h nozzle takes a while (~30 mins) to deplete my tank when constantly on. During daily driving it only comes on when you really need to accelerate so the 3 gal tank I am using lasts an eternity.
On the track, I find the meth injection is on about 50-60% of the time. For a 20 min session I would probably only deplete the tank 1/3 of its volume.
As for the position of the nozzle, you have it backwards. You want to spray onto the screws or rotors to make them more efficient (cooling them down and sealing them better).
Most of the WMI applications put the spray after compression and, if intercooled, after the intercooler. I built a blown Mustang about 12 years back using an Eaton roots blower and intercooler. Using a smaller pulley, I could generate 12 lbs of boost but the intercooler exit temperatures were getting pretty high and particularly so after a couple full throttle runs (heat soak). So, I put in a WMI with two nozzles directly into the lower intake after the intercooler. Worked like a charm and dropped my air intake temperature by 60 degrees. The beast made silly power after tuning and was pretty hard to drive on the street.
I have read of some WMI applications with the spray before intake compression but typically only for high boost applications. Is there no concern with differential cooling of the blower rotors/screws? The tolerances are pretty tight and even a little warping due to uneaven cooling could cause interference between the rotors.
Have you tried spraying after compression to see if there is a real benefit in spraying before compression?
I'm not yet an FR-S owner. I've driven the car but found the stock power level underwelming. Now that there are a few aftermarket SC applications available, I'm going to reconsider the FR-S. I'm an old guy that enjoys hot rodding.
DSLeach is offline   Reply With Quote
Old 07-01-2013, 06:15 PM   #116
sw20kosh
Drives: 2013 Black FR-S
http://www.alcoholinjectionsystems.c...icle_info.html
I have spoken directly to Rodney at AIS and he guarantees that pre-blower works better than post-blower.
@robispec has a buddy who has dealt with positive displacement sc's for a long time and who says the same thing. Maybe Robi can chime in here.
Old 07-01-2013, 07:02 PM   #117
swift996
swift996's Avatar
You could always tap 4 ports in the intake runners, but it seems like the benefits of running pre-supercharger are quite good.
sw20kosh - are you running on EcuTek?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-01-2013, 07:07 PM   #118
sw20kosh
Yes and yes.
The Following User Says Thank You to sw20kosh For This Useful Post:
swift996 (07-01-2013)
Old 07-01-2013, 08:50 PM   #119
sw20kosh
Look what I got in the mail today! Time to open up this exhaust system (ear plugs ready).
EL Borla Header not pictured.
Thanks to @No Limit Motorsport for this sick Private Label Mfg OP and DP. They even threw in a furry animal friend for extra cushioning/packaging. Top notch!
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
FrX (07-03-2013), No Limit Motorsport (07-02-2013)
Old 07-01-2013, 09:00 PM   #120
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Man you better drive at like 2k RPMs through SF lol. The cops are sticklers there.
denkigrve is offline   Reply With Quote
Old 07-01-2013, 11:21 PM   #121
Dodzilla
Drives: 2013 Subaru BRZ
Running dual cats looks like a mistake to me, too much restriction. The 2nd one isn't even properly flanged.
Dodzilla is offline   Reply With Quote
The Following 6 Users Say Thank You to Dodzilla For This Useful Post:
akuhei (07-02-2013), armythug (09-22-2013), Panman (07-02-2013), s2d4 (07-05-2013), sw20kosh (07-02-2013), swift996 (07-02-2013)
Old 07-02-2013, 08:11 AM   #122
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
What an awesome cat!!!!
No Limit Motorsport is offline   Reply With Quote
Old 07-02-2013, 11:23 AM   #123
sw20kosh
Omg I got joked!!!! Lol two cats. I get it now...
Old 07-02-2013, 11:41 AM   #124
swift996
swift996's Avatar
Please elaborate?
He's talking about the actual cat (the meow type)
The Following 3 Users Say Thank You to swift996 For This Useful Post:
FrX (07-03-2013), sw20kosh (07-02-2013), v1ru5 (07-02-2013)
Old 07-05-2013, 04:11 AM   #125
sw20kosh
Just flashed the new base tune for 91 octane. Filmed my test runs. =)
2nd gear
[ame]http://youtu.be/AsazKY-TTII[/ame]
3rd gear
[ame]http://youtu.be/Qpg8Jb1tEeo[/ame]
4th gear
[ame]http://youtu.be/uW_mioxB9Us[/ame]
This is not the meth tune.
Hitting a maya dyno tomorrow to see what things look like on a graph. Dynojet at the end of next week.
Then putting on the exhaust mods, smaller pulley and bigger meth injector nozzle. See where that takes me.
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
colHolm (07-05-2013), djdnz (07-05-2013), robispec (07-05-2013)
Old 07-05-2013, 01:37 PM   #126
robispec
so you are coming down for the cup?
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 12:49 AM
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! Visconti Forced Induction 67 04-03-2013 03:56 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
